Question about Uniden SC230 UASD
There is no sound on my uniden sc230 scanner. No sound on the head set or scanner speaker. Is this scanner broken or I am programming it wrong?
Mechanic688
  • 204 Answers
SOURCE: programing for uniden bearcat scanner bc 144xl
danval, I looked up a pic of your scanner and it is pretty straightforward. If it is the 16 channel I was looking at, here is the step by step programming.
1- Push manual button to go to the channel you want to start programming.
2- Enter the freq number in.
3- Push the E button to enter it in the memory.
4- To review what you programmed, push the Review button.
5- Use manual button to step to next channel and start over from #2
That should get you started with the scanning hobby.
The scanner has a Priority button that when activated will stop scanning and go immediatly to the priority channel if someone keys their mic.
If you need freq's (or more of) for your area, go here and click on your state and county and it'll give you a complete listing.
http://www.radioreference.com/apps/db/
Hope this helps you out, let us know,, Mechanic
Posted on Feb 12, 2008
SOURCE: Programming a scanner
To program a BC 70XLT turn the scanner on and hit the man key.
enter the channel you want to program (ie 1) hit the man key again then enter the frequency you want to scan (IE 450.625) then hit the E key to enter the freq into the location if you want to sequence to the next channel then hit the man key again enter the freq and hit the E key.you can go through all 20 channels this way.
Posted on Oct 12, 2008
  • 31 Answers
SOURCE: Trouble programming my new Uniden scanner
Email me and let me know what area you live in and give me an idea of what you would like to listen to. I may be able to help.
elijam1
elijam1@ameritech.net
Posted on Jan 14, 2009
SOURCE: Need Program for Uniden BC246T scanner
scannow.org it is a free programming software
Posted on Apr 08, 2009
  • 16 Answers
SOURCE: Uniden UBC72XLT scanner problem.
The cheapest solution would be to directly program the frequencies that are available in your area, usually this is public information with the exception of high security channels, you can call each location and ask them what frequency they broadcast
Posted on Jun 07, 2009
Got a uniden bearcat bc560 xlt police scanner comes on but no sound out of the external speaker or the other speaker what's wrong with it
It sounds like it is broken! Also, the squelch could be set too high, the speaker may be shot. You can rule out the speaker being shot by putting a set of headphones into the external speaker jack. If you hear something, even loud his, then the speaker is shot. Make sure that the squelch is turned all the way down.
Dec 08, 2017 | Uniden Radio Communications
Reset programmed
If you refer this inquiry directly to Uniden support, you will get a solution
May 07, 2013 | Uniden SC230 Handheld Racing, Nascar...
Uniden bcd396xt scanning but no sound coming from scanner
BCD386XT No sound. If it is actually stopping on an active broadcast and if you have the volume turned up (press down on volume button and release, then rotate to adjust) then the most likely cause is a failed speaker. Try a set of headphones in the jack on top by the antenna, if you have sound there it is most certainly a bad speaker. It is a very tiny speaker that is as thin as a nickel, many have been broken by a simple jar or by being played too loud by the hearing impaired. It is not hard to change but basic soldering skills are required. the speaker is available from uniden parts.
Apr 05, 2013 | Uniden BCD396XT Handheld Scanner
Scans fine but no volume
broken wire to speaker, damaged speaker, bad volume control, it gets worse from there and requires a electronics specialist
Jul 09, 2012 | Uniden Vintage Works Bearcat Bc145xl16...
While listening to my scanner every so often, does not seems to be a specific interval, maybe 3 or 4 seconds usually, I get a silent pause missing conversation. For instance the ambulance dispatcher might...
sounds like you have another channel set for priority and it is scanning back to check that channel. In the manual mode scroll thru channel's until you find one set with a "p" or "pri" on the screen. Hit the priority button and this should resolve the problem.
Sep 09, 2011 | Uniden SC230 Handheld Scanner
My old scanner had 20 banks of 10 freq. each, am having trouble understanding the instructions for the SC230. Is there a site or booklet that has the instructions spelled out simplier.? thanks Ed...
Wow, Uniden did their best to make the SC230 manual confusing, didn't they? Here's a link to a much easier to read/use manual that was put together by an SC230 owner who couldn't figure out the factory document. I hope it helps.
http://marksscanners.com/230/230.shtml
Bill B.
Listening in since the 60's
Mar 29, 2011 | Uniden SC230 Handheld Scanner
Bearcat BC144XL Scanner ~ no sound
Try it with an external speaker. The external speaker jack receives the audio from the scanner before it goes to the internal speaker. If the jack thinks there is still something plugged into it, the audio to the internal speaker is interrupted. If the jack is stuck, it may still work with an external speaker.
Aug 30, 2009 | Uniden BC248CLT Base Scanner
Cant find codes for my scanner its a uniden handheld but i cant find the codes for my area witch is blair county can you help me
Do a google search for radioreference.com. Choose your state from the data base site then your county.
Aug 03, 2009 | Uniden SC230 Handheld Scanner
Scanner sc 230 uniden
1. Cellular is blocked out on most scanners. You might find a mod on the internet to unblock it....but
2. Most cellular now a days is digital anyway, so even if you could listen to the frequency, it would just be noise.
Geno
Feb 25, 2008 | Uniden SC230 Handheld Scanner
Computers & Internet Logo
Top Uniden Computers & Internet Experts
Eric Sutherland
Are you an Uniden Computer and Internet Expert? Answer questions, earn points and help others
