Question about Orion STV2763 27" TV
Remotes not working
The remote that came with our tv isn't working. We did the following: changed batteries (yes their good), purchased a universal remote. The tv will turn on and work with the buttons on the front but won't go higher than channel 13. Neither remote can work the tv. We need to get to channel 60 for our DISH programs. Any suggestions???? Thanks
  • mlaa67 Aug 20, 2008
    My Cox Cable remote used to work w/ my Orion 27" tv (power on/off, volume button, channel button), then it would only work intermittently.  Now it won't work at all w/ my Orion.  I tried the original remote and it never worked.  HELP!
Well as far as not being able to go past channel 13 that could just mean changing a setting on your tv. Just go to the menu and then to channel setup and there should be a spot where you can change your channel mode. Changing the mode to 'cable' should allow you to access higher number channels.
Posted on Feb 28, 2008
    Novelist:
    Champion:
  • 275 Answers
Ice man is right. Try cleaning the contact pads with denatured Alcohol. It should work
Posted on Apr 04, 2007
  • 68 Answers
Well, sometimes the universal remote does not give you the whole functions, so it is better to work with the original one. you could fix it thought. here is how. most of the time, it just need cleaning. so get some denatured alcohol and clean the pc. do not apply any alcohol to the rubber button, that will ruin them. put it back together and give it a try again..good luck
Posted on Apr 02, 2007
I can't get my older garage door remotes to program with the new unit.Do I have to buy new remotes?
SORRY TO SAY.THE ANSWER IS YES.
THE NEW OPENERS ARE NOT ON THE SAME FREQUENCY.
YOU CAN PURCHASE REMOTES THAT WILL WORK WITH BOTH OLD AND NEW OPENERS (DUAL FREQUENCY).
BUT, OLD REMOTES WILL NOT WORK WITH THE NEW OPENERS.
Dec 29, 2014 | Craftsman Sears Liftmaster Garage Door...
TV isn't responding to the remote
Hello, sorry to hear that you having issues with your remote or TV.
First, comes the most common questions but its worth a shot, Did you replace the batteries?
Second, You could try and clean the infrared eye on the tv with a moist cloth to make sure the window on it is not dirty or blocked from the line of sight of the remote.
Also check you batteries once more, also take the batteries out of the remote and push on the buttons as one ore more could be stuck causing the remote to malfunction.
Worse cases are bad remote or bad control board in the TV witch cause it not to respond to the remote. First check the remote very well. You could also replace the remote at www.remotes.com or purchase a universal remote as well.
Only if the new remotes do not work you would call it a bad control board in the tv witch could cost around $90 to replace if there are part available.
Most cases would be the remotes batteries or connectors itself or batteries incorrectly installed.
Thanks for using Fixya.com
Regards
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 14, 2011 | Sylvania 6419TD 19" TV
Same problem as above.Disney p1310ATV lost the remote. No Phone # in orginial manual.Television system NTSC (American TV Standard) I have tried other universal remotes also I have a Sony RM-V210 universal...
there may be a problem with the tvs remote sensor. most universal remotes you dont even have to enter any codes you just have to follow the same steps to enter the code but instead of entering a code all you have to do is press the channel up button after following all other steps, just keep pressing up until it turns the channel on the tv then press enter or similar button after it changes the channel and this should lock in the code without entering a specific code.And if all other remotes only half the buttons work on if it happens with every universal remotes then it probably a problem with the remote sensor or the tv . Good luck too ya!!!
Jan 02, 2011 | Disney 13" TV
Trying to get the remote to work on my symphonic
Change batteries?Take it aparts,clean it with Q Tips
with some rubbing alcahols in the rubbers knobs and
clean the films between the circuits board.Don't work after this.Buy a new remote at this website.1-800-remotes Factory Original.Yes,universal remotes it cheaper,but causes univeral codes,more headaches later.
Oct 21, 2009 | Symphonic ST420FF 20" TV
Older person cannot handle two remotes
You can program most satelite remotes to work on any device. Most are universal. If not, I suggest purchasing a universal remote. You can view remote codes online to program your device to your remote. New ones come with instrucions and codes.
Let me know how I can further assist you if necessary
Aug 18, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Where can I purchase a Lithium battery 046067 for an MX 3000?
Do you favorite search engine and type your model number and then batteries. What I got is www.buy.com
Aug 18, 2009 | Universal Remote Control MX-3000 LCD...
My recently purchased L32HD41 TV was purchased as a floor model and did not come with a remote, and we cannot get the universal remote to work
Follow the directions closely use all the codes
Go to 1-800-Remotes Factory original order one they have thousands of remotes.
U can order the remote ur tv came with.
Aug 13, 2009 | RCA L32HD41 LCD TV
Remote is no longer working
i need a universal remote that can work for a jwin dvd player
Feb 03, 2008 | Jwin JD-VD502 DVD Player
Program universal remote
check remote first, and replace ir ditector in the tv...
Sep 28, 2007 | Orion1934 19" TV
Orion STV2763 27" TV Logo
136 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
