How to fix error code 00020009 Flash memory SUM error on epson stylus pro 7000
Inky
  • 691 Answers
SOURCE: epson stylus photo 895 error code
1Eb means no black ink, 1Ec means no colour. Change the cartridges and you should be good. you will need Epson cart numbers: T007 Black T008 Colour
Posted on Sep 28, 2007
Basti
  • 1447 Answers
SOURCE: Epson Pro 7600 Service required error
If you are getting that error try this
Check to make sure the locking bracket and screw have been removed from the print head.
Turn off the printer.
Open the lower cover on the front of the printer and remove the bracket and screw holding the print head in place.
Close the printer cover and turn on the printer.
The Pause light, begins flashing and the printer starts charging the ink delivery system.
If a different error then update me, thanks!!
Posted on Apr 17, 2008
  • 33 Answers
SOURCE: Epson Stylus pro 4800 field repair manual
Epson is pretty cautious with their proprietary materials.
Posted on Nov 12, 2008
You need to be able to clear the counters in the printer that tell the printer to stop working.
In order to do that you must
1. Turn printer off
2. you must hold down the "Paper Source, Paper Feed, Select Feed, Cut/Eject" buttons all at the sime time while you turn the printer back on.
3. From there navigate through the menues to clear the counter that pertains to you or all.
(Error 00000101 is pertains to the print head motor)
Word of warning -
Those counters can be a pain as they cause the printer to stop working however you do need to get your printer serviced by a tech as soon as you can because the error is a warning, reset the counters lets you finsih a job, but if it goes unserviced too long it will actually break down all togther.
So even after you rest the counters you absolutly must get your printer serviced soon.
Posted on Nov 21, 2008
exil0r
  • 118 Answers
SOURCE: clear the Carriage Motor Counter epson stylus pro 4800
look for that here
Posted on Mar 26, 2009
Message is Service call error 00010014 I have an Epson Stylus pro 9800 and I am getting a message saying: Service call error 00010004 error 00010004 SERVICE CALL 00010004DescriptionFailure of ...
Epson Stylus Pro 4400/4800/4880 Error Codes
Maintenance Request Codes:
• 0002 - CR Motor near end of life - Replace carriage return motor ASAP
• 0006 - Battery shut off - Replace RTC back-up battery
• 0040 - Cleaning unit near end of life - Replace cleaning unit ASAP
• 0080 - Date not set - Set the date through the printer control panel
• 0088 - RTC backup battery not installed - Install RTCbackup battery
• 0100 - RTC backup battery pressure is temporally low - wait for a while
• 0200 - The number of ASF paper feeding has reached predetermined value
• Service Call Codes
• 00000101 - CR Motor reached end of life - Replace carriage return motor
• 00010000 - PF encoder check error
• 00010001 - PF motor is out of step
• 00010002 - PF motor overcurrent has occured - Replace PF motor
• 00010003 - PF motor out of postion time-out error
00010004 - CR encoder check error - ensure enoder strip is clean & dust free
• 00010005 - CR motor out of step - click here for more info
• 00010006 - CR motor over current
• 00010007 - CR motor out of position time-out error - Replace the board assembley, main
• 00010008 - Servo interupt watchdog time-out error - Replace the board assembley, main
• 0001000A - Carriage home position detection error
• 0001000C - PG home position detection error
• 0001000F - CR motor PWM output faulty
• 00010010 - PF motor PWM output faulty
• 00010012 - CR overload (high sensitivity) error
• 00010013 - PF overload (high sensitivity) error
• 0001001B - Head Driver (TG) temperature error
• 0001001D - CR servo parameter error
• 0001001E - PF servo parameter error
• 00010020 - CSIC reading/writing error
• 00010022 - Ink type error (setting on printer body side)
• 00010023 - RTC analyzing error
• 00010025 - SCIS ROM communication error
• 00010026 - RTC communication error - click here for more info
• 00010028 - Head error - replace print head
• 00010029 - Unidentified NMI
• 0001002A - CR ASIC ECU error - Reinstall/update firmware
• 0001002B - PF ASIC ECU error
• 0001002D - Cleaning unit has reached end of life - replace cleaning unit
• 0001002F - 360 DPI writing time-out error
• 00010030 - Multi sensor error
• 00010031 - ASF phase detection error
• 00010032 - ASF drive switch error
• 00010033 - Eject phase detection error
• 00010034 - Eject movement error
• 00010035 - Pump phase detection error
• 00010036 - Type-B board installation error
• 00010037 - Head thermistor error - Replace print head
• 00010038 - Transistor thermistor error - Replace board assembley, main
• 00010039 - PG adjustment value incorrect overwrite error
• 0001003A - PG adjustment value outside range error
• 0001003B - Cutter installation error 1
• 0001003C - Cutter installation error 2
• 0001003D - Cutter installation error 3
• 00020000 - NVRAM error - Replace board assembley, main
• 00020002 - SDRAM error - Replace board assembley, main
• 00020003 - Boot program SUM error - click here for more info
• 00020009 - Flash memory SUM error
• 0002000A - Program load error
• 0002000B - The internal memory is insufficient
• 100000E0 - CPU address error (load)
• 10000100 - CPU address error (store)
• 10000180 - CPU reserved command code exception error
• 100001A0 - CPU slot undefined command exception error
• 100001C0 - The AC power is shut off
• 100005C0 - CPU DMA address error
• 10000xxx - CPU error
• 0003xxxx - Debug orode
• 0Dxxxxxx - An error code for debugging
• 0Exxxxxx - A time-lag of the RTC timer
Mar 24, 2018 | Epson Office Equipment & Supplies
I am getting the error message code 154E - is there anyway to fix this without getting it serviced?
According to:
Error Codes Epson Stylus Pro WT7910 Code 154E
you have a "Velocity deviation error"
meaning that the print head isn't traveling at the correct speed. Clean and lubricate the shaft it runs on, the above site also suggests replacing cutter unit and/or main board.
Jun 15, 2015 | Epson Stylus Pro 4800 InkJet Printer
What is service call error 1000c means?
SERVICE CALL 0001000C
Problem
PG origin sensor malfunction (may indicate PG motor malfunction)
Solution:
Make sure there is no ink or dust on the surface of the sensor. If this
does not solve the problem, check the PG sensor connection. If there still is a problem, try the following.
Replace the PG sensor
from: Epson Stylus PRO Color Large Format Inkjet Printer 7000 Service Manual...
Jun 06, 2015 | Epson Stylus Pro 7500 InkJet Printer
How to removed error code 0002 on epson stylus 7800
problem with epson stylus pro 7880
how to removed error code A0000170
Oct 02, 2013 | Epson Stylus Pro 7400/7800/9400/9800 Matte...
How to remove and clean epson stylus pro 7000 printer head its cloged
Welcome to FixYa!
If you have not used your printer for a long time, the print head nozzles may be clogged. Perform a nozzle check and clean the print heads.
Use the Epson Printer Utilities to do a nozzle check and to clean the printer head.
Reference Manual of Epson Stylus Pro 7500 InkJet Printer:
http://files.support.epson.com/htmldocs/pro75_/pro75_u1/INDEX.HTM
Comments and rates are appreaciated.
Thanks for using FixYa.
Jas
Feb 23, 2011 | Epson Stylus Pro 7500 InkJet Printer
I have an Epson Stylus Pro 7000. I am running MAC OS 10.5.8. The printer is hooked up via USB. The printer shows up in my available printer list, but when I send the file to print, I get an error "Printer...
Try a new USB cable and plugging into a different port. Make sure the cable is fully seated. If you have a USB hub, try a direct connection.
I hope this helps.
(I'm assuming the printer is on and has no blinking lights.)
May 17, 2010 | Epson Stylus Pro 7000 InkJet Printer
Epson stylus pro10000 problem service reg
SERVICE REQ. 00020000:NVRAM ERROR
SERVICE REQ. 00020001:NVRAM COMPARISON ERROR
SERVICE REQ. 00020002:SDRAM ERROR
SERVICE REQ. 00020003:FLASH MEMORY ERROR
Problem
Abnormal detection in a corresponding element
Solution
1. Once save parameter to Flash memory card and install it to the printer again.
2. C362DRV board. replacement
Feb 18, 2009 | Epson Stylus Pro 10000 InkJet Printer
52 people viewed this question
k24674
jasbo
jasbo
