Question about HP Pavilion Media Center m8530f Desktop/Phenom X4 9550 Quad-Core/5120MB PC2-6400 DDR2 SDRAM/750GB 72...
Remove heatsink how do i remove the heatsink?
  • 77 Answers
There is usually 2 clips on heat sinks which can be accessed on the sides of the heat sink itself, you'll need to move the latches from the lock position to the unlock position.
If there aren't latches on the sides of the heat sink then it may use push clips that hold it to the motherboard, those can be accessed by removing the motherboard and squeezing the plastic clips together with a pair of needle nose plyers. The clips will be located on the underside of the motherboard.
Posted on Feb 07, 2012
  • p1chil
    p1chil Feb 07, 2012
    It has the two latches, and one side has a lever. When I move the lever to the unlock position, it loosens up, but I don't know how to remove the latches.
  • Bubbly Bullseye Feb 08, 2012
    I'd need a picture of the heat sink to give you more advice, preferably up close showing the latches.
    Normally you 'teeter' the latch. Most heat sink latches look like an M with hooks on the bottom | |'s you normally will push one side down and push in the direction of the latch arm to release it. Difficult to explain but easy to do.
Asus m32 loud fan
Fan speed does increase for a reason.....heat. Check you BIOS settings and verify that the CPU temp is not getting too high. Desktop computers are dirt magnets. It is common for the CPU heatsink to get clogged with dust and dirt. This will reduce cooling and increase heat, eventually to the point that the fan will speed up. Get some electronic duster (canned air) and blow out the fins on the CPU heatsink. DO NOT remove the heatsink from the CPU. There is a special compound that is on the heatsink surface that allows proper heat transfer from the CPU. Removing the heatsink means that this compound is disturbed and would need replaced. Most users do not have this compound and thus should not remove the heatsink to clean. If the heatsink is so clogged that you cannot get the dirt out with canned air, you may be able to remove the fan from the heatsink, depending on the fan/heatsink design. Then you can use a brush to get into the fins to clean them.
Apr 18, 2015 | ASUS Computers & Internet
Tip
How to Remove CPU Heat Sink Fan of TOSHIBA A45 LAPTOP
STEP 1Always start laptop dis assembly with removing the battery.
STEP 2
Remove six screws securing the hard drive cover and the heatsink covers.
STEP 3
Remove one screw securing the hard drive to the laptop base.
Disconnect the hard drive and remove it from the hard drive bay.
STEP 4
Remove three screws securing the CPU heatsink to the system board.
Carefully lift off the heatsink off the laptop CPU.
STEP 5
The heatsink is 100% clogged with lint.
If your heatsink is clogged, clean the heatsink with a canned air to prevent your laptop from overheating.
on Dec 15, 2011 | Toshiba Computers & Internet
Lenovo chipset heating problem
If this is on a desktop lenovo and if it is a slightly older board you may have to remove the heatsink and RE-DO the heatsink compound as there was a common issue with some boards.
NOTE some heatsinks were soldered in and if you are not happy with removing those then a good friend who is knowledgable will be able to help out there.
It isnt a big job but often fixes issues.
If however you are really talking about the CPU heatsink then once again it is pretty simple to do yourself but make sure you clean ALL the old heatsink paste off with isopropynol.
I use CERAMIC heatsink paste (white stuff) as it lasts longer and conducts heat better for lower overall temps.
Oct 03, 2011 | Intel Motherboard
Toshiba Satellite L500D is shutting down by itself OVERHEATING Clean the fan with compress Air ....> NO GO Need help Please or Any other Suggestion
Disassemble the laptop and remove the heatsink.
Remove all the dried up heatsink goo that's on the heatsink and processor.
Squeeze a small amount of QuickSilver heatsink compound onto the middle of the processor top.
Place the heatsink on the processor and move it in a couple small circles before locking the processor heatsink back in place.
Clean the air vents and cooling fins well while the unit is open.
This should fix any overheating issues you are having (assuming the fan is OK)
If the fan isn't running, replace it.
Jun 24, 2011 | Computers & Internet
You have to put a lot of weight on the heat sync for it to boot up
I would assume that it's the cpu heatsink? Actually, it's a bad thing to put extra weight on the heatsink for it may damage the processor. The spring and locking mechanism of the heatsink is just enough to transfer the heat from the processor to the heatsink. Problem maybe on your processor not properly seated on the slot. Remove the heatsink assembly, and release or remove the processor from the slot. Check if there's a foreign object in the slot, a brush will do the cleaning. Reinstall the processor and the heatsink assembly.
Sep 06, 2010 | Dell Dimension 4700 PC Desktop
Cannot remove the fan and heatsink
The heatsink is probably stuck on with the cooler compound. If it's really stuck on, then I would release the CPU brace as well and pull the CPU out with the heatsink. Then carefully wedge something sharpe between the heatsink and cpu, like a razor blade and slowly push the blade through the compound until it's unstuck.
Thanks Mark
Apr 16, 2010 | ASUS P4S800-MX Motherboard
Need to remove cpu fan
STEP 2
STEP 3
STEP 4
STEP 5
Mar 08, 2010 | Toshiba Satellite A45-S150 Notebook
How do i remove the processor on a dell optiplex gx 280 from the heatsink and repaste the processor seems to be like glued to the heatsink?
The heatsink compound does act as a weak glue over time. To remove the heatsink, twist gently after removing the clamps, to release the junction. The CPU should stay in it's socket. Scrape off the old compound and add new and re-install the heatsink.
Sep 23, 2009 | Dell Pentium IV 2.8GHZ Processor Unit...
Ea7ecp@hotmail.com
Changeing a cpu is a simple process.
First step, remove the cables and open the case.
locate the cpu - heatsink
it debends on what kind of heatsink it has, simply turn the lever
or use a screwdriver to unhook the metal connector. If you don't have enought room you might need to remove the powersupply first.
handle the cpu with care, ones the heatsink is removed you can
pull up the lever next to the cpu to unlock it
now you can remove the cpu with your fingers by the edges.
place it in a safe location, and go ahead install the new cpu.
optionally apply some thermalpaste and attach the heatsink
and the power connector for the heatsink fan.
you are done.
Jun 11, 2008 | Soltek SL-85DRC Motherboard
ASUS NCT-d
Hi, have you tried removing the CPU and using a Air Jet Spray can to clean all contact pins and pin holes? The problem sounds like a loose chip. So also check all on board chips are seated, including RAM chips. Air spray can be bought from most Computer stores. Goodluck mistyman
Sep 09, 2007 | ASUS NCT-D (90MSV430G0UAY) Motherboard
HP Pavilion Media Center m8530f Desktop/Phenom X4 9550 Quad-Core/5120MB PC2-6400 DDR2 SDRAM/750GB 72...  Logo
77 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
