Goodman gmh95. The fan runs, cuts out, starts, cuts out as it nears set temperature.
We have a goodman gmh95, 1yr old. The fan runs, cuts out, starts, cuts out as it nears set temperature. Our heater was installed 2/25/11. The fan (blower) runs when the unit heats up. When the temp of the room approaches the temp of the thermostat, the blower starts to cut out (similar to an engine about ready to die) and starts up again. This can repeat itself several times until the room temp is met. This never happens when our heating contractor comes to check the unit. It also does not happen when he by passes the thermostat. We even moved the thermostat to another location...the problem still exist. Do you have any recommendations?
  • Heating & Co... Master
  • 1,870 Answers
Seen many bad blower motor modules. The motor is likely good the "brain," maybe not. Had a bad blower motor module on a Lennox that was actually causing the tstat to go into a time delay recently. The newer the machine the crazier things are becoming. If under warranty you'll likely get the motor and module together. This is where I'd start. Good Luck.
Posted on Apr 07, 2017
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 50 Answers
Have you checked the diagnostic LED on the unit? Should be visible through the blower door.
    Master:
  • 523 Answers
If that's a variable speed motor(?), I've seen them do some strange things. Not that scenario that you have though. If it's under a parts warranty, have your tech start changing some things out, motor, control board to start with. It appears that your thermostat may be loosing contact? I know he bypassed it but how? And was the bypass for a few minutes or so? Or that you're issue seems to occur after 5-15 mins of operation, and that just happens to be a long enough run time to closely reach the set temp. at the thermostat. And that getting close has nothing to do with it, but the 15 mins of runtime is a better description. So have your tech over, warn them it may take 2 hrs, and pay him to hang around a catch it acting up. And set your tstat to allow it to get cold inside so it will run a lot when he gets there. Also, when it acts up, turn your fans' AUTO/ON switch to on, and see if it qits acting up. Not sure what that will answer but it may help you tech, depending on how it's wired. Hope this helps!
SOURCE: Heater element ignites, but turns off before gas begins flowing which stops the process.
clean your flame sensor with a piece of wool
Posted on Feb 27, 2007
  • 579 Answers
SOURCE: Dayton 3E227A Heating Cycle
The sensor for the thermostat is probably going bad or has bad connections. It is (or thinks it is) heating up fast and therefore shuts of the heater.
Posted on Dec 31, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: goodman heating element does not light
The flame sensor is not sensing flame. Inspect the system as it is tying to start and see if the flames are traveling to all burners and hitting the sensor. If not, clean the burner flame rail (the trough the allows the flame to travel from one burner to the next) or if it is hitting the sensor, clean the sensor with steel wool and check all connections from the sensor to the control board.
Posted on Jan 21, 2008
Accurate Joe
  • 61 Answers
SOURCE: heat pump auxiliary heat does not turn on
Turn up your outside thermostat in the outside unit.
You should have about 3 degrees difference in one stage to the next. So I would change the thermosat with one that has three stages of heat.
Posted on Nov 30, 2008
gtmerkley
  • 190 Answers
SOURCE: I have a Goodman GMH95/GCH9 furnace, the
open the front door to the furnace to access the controls there should be a red button try pushing it to reset
Posted on Oct 10, 2009
Goodman gmh95 furnace wont ignite
try the pressure switch you may be able to jump it out and see if it lights
Oct 01, 2016 | Goodman Heating & Cooling
Air handler fan cuts on runs a few minutes and then cuts although thermostat is set to off.
your thermostat could be wired in to a energy recovery venilator which will bring the unit on for a certain amount of time every hour some thermostats have recirculate mode which will do the same thing to help filter the air
Apr 16, 2013 | Goodman Heating & Cooling
I have a 16 SEER Goodman air conditioner and during the morning hours, temperature ranging 75 degrees outside, the compressor comes on but not the outside fan. It only runs for a minute and a half then...
The fan is shutting off in order to maintain head pressure when the outdoor temperature is low. This is common on 16 seer and above systems. It helps your system be more efficient.
Jun 06, 2011 | Goodman Heating & Cooling
Furnace will not shut off after the setting is reached. have changed thermostat. Temperature reading goes down on thermostat, furnace still runs. Model : Goodman furnace,gmh95/gch9
Check if your thermostat is set on 'o fan' setting.
If it is, trey to set it on 'Auto-fan' instead.
since it seem as if the heating does go off,only the fan may be running continuously.
this is possible if the thermostat is incorrectly set or installed.
good luck.
Jan 30, 2010 | Goodman GMS90703BXA Heater
GOODMAN CPLT36-1 WITH HONEYWELL VISION PRO STAT 8000
what is the trans former voltage needs to be 26- 28 v. and is the board fused max 3-5 amp fuse I know it is on of the two check all of your wiring. good luck Tom
Jul 11, 2009 | Heating & Cooling
Electric furnace won't shut off
It sounds like a bad or badly miswired T-stat
Jan 20, 2009 | Goodman CLQ36AR49 Air Conditioner
Electric furnace runs but won't shut off on heat setting
I would insist that Sears either have a Senior tech come out and fix it or return it to the state it was prior to them touching. Then call some one else. Have them involve the Goodman rep in your area.
Furnace starts properly, then shuts down, led flashes 8 times
The first thing to look at is the flame sense rod.
Shut off power to the furnace, remove, clean sensor with steel wool or sandpaper then reinstall the sensor. Reapply power and it should run properly.
Jan 10, 2009 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
