Question about Gucci Watches
Gucci 3300M men's watch links - Gucci Watches
5 Suggested Answers
escapement
  • 2334 Answers
SOURCE: REMOVING LINKS FROM FOSSIL ARKITEKT MENS WATCH
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 09, 2009
escapement
  • 2334 Answers
SOURCE: need to resize watch braclet on a mens invicta watch
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Apr 02, 2009
SOURCE: How do I open my gucci watch to change batteries?
Get a #0 1.6mm precision Phillps screwdriver (these are brittle) or similarly strong, thin piece of steel.
Hold the watch upside-down across your index finger while gripping the straps tightly between your index finger and thumb on one side, and index finger and middle finger on the other (ie. squeeze the strap around your index finger).
On the underside of the watch, stick the tip of the screwdriver under a square slot where the watchband is connected at an angle perpendicular to the strap. Firmly pry upwards on the cover on one side, then the other, until the cover pops off.
The battery is a Renata 379.
To put the cover back on, align the square slots precisely with the ends of the straps (keep these out straight), then firmly push the cover straight down until it "snaps" shut.
Posted on Jul 25, 2009
  • 65 Answers
SOURCE: How to Open a Gucci watch
Most watches are either screwed on and typically have a series of small notches around the circumference of the case back. A special tool is generally called for. Otherwise they are "snap back" . These are simply pressed on. To remove you can carefully use a regular knife in the absence of a "case knife". There is usually a small gap/groove/notch area to insert the balde and lift the back off.
Where can I find extra links for a Gucci 3600M mens watch?
At Gucci where else ! Look for Gucci on line , or Top End Watch Retailer
Mar 16, 2015 | Gucci Watches
I just bought a Gucci 8905 YA089303 and the second hand jumps about every 4 seconds. Is this fixable?
You are witnessing what is called the EOL or end of life indicator. Relax, it's your battery not you! Better watches have this feature. You will notice the time remains correct even if the seconds hand jumps 4 seconds. Some watches it is 2, some 3 seconds.
Mar 16, 2011 | Gucci 8905 Mens YA089303 (18965)
Need to know what battery is needed for Gucci 1500L.
The battery requirements are: 364 / LR621 / AGI 13mAh - these are the same battery with different names. Hope this helps.
Nov 12, 2010 | Gucci 1500 1500.21531 Wrist Watch
(21540) Wrist Watch: spare links for gucci 8600m mens steel strap...
Where can I find links for my Gucchi watchstrap 9700m
May 17, 2010 | Gucci 21540 wristwatch
PAOLO GUCCI WRIST WATCH
here is the website to mail them your watch and they will fix it and mail it back to u tats the best way i would've tell u where to go to get it fix if i knew which state u were in but i dont so the best thing u can do is mail them
http://www.bestfixwatch.com/Shipping.php
Jan 15, 2009 | Paolo Gucci Men's Black Dial Silvertone...
Watch band broke on Paolo Gucci Womens watch PG873WS
I have here the official website of Gucci for your ready reference. You can run through below link to find assistance. Kindly change the country from where you are.
Gucci
Sep 07, 2007 | Gucci PG873WS Wrist Watch
Watches Logo
320 people viewed this question
Top Gucci Watches Experts
Lawrence Oravetz
John mullen
Are you a Gucci Watch Expert? Answer questions, earn points and help others
