Question about Whirlpool Refrigerators
Whirlpool ET8CHMXKT05. Drain from freezer to pan is clogged.
Draining water under the crispers
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool GD25DF auto defrost drain problem
There is a drain hole in the back of the freezer on the bottom. Get back there with some hot water. Most of the time it is just lime build up. Unless you know what feel back there. Another way is to move the freezer out and from the back side you can see the drain line. It just pulls right off
Posted on Feb 11, 2009
wheelshot
  • 102 Answers
SOURCE: Water draining under crisper bins & onto shelves. Try again
Your drain tube is stopped up. Take the panel off in the freezer section and chip away the ice in the pan below the coil. When you get to the drain hole pour hot water in it until it free flows. You will need a towel in the freezer to catch the excess water. Run some extra hot water through it to assure that you clean the drain out good.
Posted on Apr 01, 2009
  • 44 Answers
SOURCE: teacuptess my GE top freezer Refrigerator has water under Crisper
Could be but more than likely the drain is clogged. Open fridge door look at the top back to see if you can see water running down back of liner.
Posted on Jun 06, 2009
  • 48 Answers
SOURCE: water pools under the crisper drawers and looks as
Mine clogs with a soft fungus mat but rust actually sounds better. I run a stiff wire like an unwound hanger into the hole and open it up so the water will drain onto the tray made to collect this water underneath the fridge. Last time I left the wire in place with a long handle and I haven't had water to mess with for many months now. My hole is between the two crisper drawers and when I get into either of them the wire gets a jiggle and I guess that's all it takes to keep the hole clear so the water can drain like it's supposed to.
Otherwise the fungus builds and builds until it sluffs off as a wad and plugs up the works on a regular basis. Too funky for sure.
Posted on Jun 21, 2009
Maytag317
  • 1136 Answers
SOURCE: whirlpool fridge ET1NHMXKT00 water accumulates under the crispers
Hhi, Yes the drain is plugged. remove the floor panel in the freezer and then the rear panel. Locate the drain hole (right side of drain pan) and melt all the ice. there is an after market drain heater kit that you will need to buy and add to the defrost heater.
It is a design problem. Part# 819043
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jun 25, 2009
Water leaking on inside - top shelves
The drain for the freezer is clogged. Unplug the frige and let it defrost. Pull the cover from the bottom front and note the drain pan. water should start draining into pan as the freezer defrosts. If Not the drain may be blocked. To access the drain remove icemaker then rear panel of freezer carefully, unplugging fan and ground wire. Look for drain in the middle under the coils. Look on outside back for the drain hose, this will help you locate the drain. Clear the drain of ice using hot water. You will hear it drain down the drain hose to the pan below.
Mar 29, 2010 | Whirlpool Refrigerators
Ice builds up in freezer bottom pan, not going down the drain tube. Is this an indicator of the defrost timer not working correctly, and if so where is the drfrost timer on a ETIFTTXKT02 model?
Defrost timer is working or there would not be water/ice in the bottom pan (as you describe it.). Check that the drain tube from the pan to the bottom evaproation tray under the refrigerator is clear of restriction.
Dec 14, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool fridge ET1NHMXKT00 water accumulates under the crispers
Vic
Jun 25, 2009 | Whirlpool ET1NHMXKT Top Freezer...
Water pools under the crisper drawers and looks as if it is draining from the upper freezer down the side of the refrig door, looks like the little hole under the crisper is clogged with rust?? It is a old...
Jun 21, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Water collecting under crisper drawers.
When the refrigerator goes into defrost mode there is a drain tube that allows water melted off the evaporator coil to go into the drain pan that you found empty. That drain tube is clogged.
May 02, 2017 | Whirlpool ET1MHKXM Top Freezer...
Water is not draining into pan. it is going inside fridge under
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Mar 17, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Mar 15, 2009 | Frigidaire FRT21H8 Top Freezer...
Freezer drain plug
Self defrosting refrigerators as well as freezers all have a defrost drain system. This drain system can become plugged or frozen causing defrost drain water to back up into the refrigerator or freezer compartment. The water may gather under the crisper drawers on top freezer models. On side by side, bottom or stand alone freezers ice will build up in the freezer at the bottom and eventually leak out the door.
Plugged Defrost Drain - Freezer on Top (Water under the crisper drawers)
At the top of the refrigerator next to the temperature controls there usually is a cup-like part that carries the defrost drain water into a tube and out the back of the refrigerator to a defrost drain pan behind the unit. Pull the cup out of the tube and clean the cup with hot water and soap. If there is no cup, pull the refrigerator out away from the wall, go behind it and disconnect the drain tube to clear it. If the drain tube is not accessible from the back or the drain can not be cleared from there the main back panel in the freezer can be removed to access, thaw and flush out the drain under the cooling coil.
Use a turkey baster to flush HOT water into the tube to clear any obstruction. The water squirted into the tube should end up in the defrost drain pan.
If the tube will not clear with hot water try blowing it out with compressed air.
Put the cup back on and make sure it is all the way on or in the tube.
Plugged Defrost Drain - Side By Side, Bottom-Freezer Refrigerator or Stand Alone Freezer
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models, the pan is accessible without removing the back panel and others are not. After you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster to squirt HOT water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
http://www.repairclinic.com/Whirlpool-Refrigerator-Parts
Jan 26, 2009 | Whirlpool ET9FTKXK Top Freezer...
Water under crispers in my fridge
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 13, 2009 | Refrigerators
Refrigerators Logo
134 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
