Question about Mirage LF100 Subwoofer
Mirage LF100 Subwoofer is humming/buzzing whenever switched on regardless if connected to a source or not. LED on front panel does not illuminate.
  • steve_kovari
    steve_kovari Feb 09, 2012
    The internal fuse checked out good. The subwoofer does provide distorted sound when connected to a source.
  • 3,799 Answers
This sounds as if a component has blown on the crossover board. (Probably a capacitor.)
Posted on Feb 09, 2012
3 Suggested Answers
  • 31 Answers
SOURCE: Constant noise from Mirage NanoSat 5.1 System Subwoofer
sounds like an earth fault either with the plug circut or more likely with the power board of the unit.
Posted on Jan 06, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have a Mirage Omni
Disconnect all inputs. If it still buzzes there's probably a broken ground somewhere inside it. Technical know-how necessary to proceed.
Otherwise, the buzz originates externally and leaks in through the cabling.
Posted on Jul 07, 2011
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
Loud buzz in sub woofer, soundbar sounds fine
How to Stop a Subwoofer Hum - HowStuffWorks
electronics.howstuffworks.com/how-to-stop-subwoofer-hum.htm
Would you like to learn how to stop your subwoofer from making a consistent low-frequent hum or buzz? Read this article to learn how to stop a subwoofer hum.
Aug 03, 2015 | Audio Players & Recorders
I have a Boston Acoustics VR-500 Subwoofer with a problem. As soon as anything is plugged into the line level RCA jacks, the subwoofer produces a loud buzz/hum. I have tried connecting it to the subwoofer...
I'm thinking you have an open shield ground on the RCA input side. Connecting speaker inputs possibly restores the ground. Try connecting the high level inputs then disconnect the remote end of the cables (floating the grounds).
Then get out an ohmmeter and find that open circuitor or bad solder joint between RCA ground and real ground in the speaker's amplifier. Or.... if speaker ground kills the hum and you want to use RCA Line Level input to the sub, just connect one minus speaker output on your source amp to one minus on the sub's amp.
Mar 01, 2011 | Audio Players & Recorders
I recently connected my satellite reciever to my
Iassume you mean you hear the buzz independently of the audio program - simply connecting the cable causes the buzz?
If tanything in the mix is powered from different AC sources you may have a different ground potential. Sometimes manipulating the orientation of one or more ac plugs will solve hum problems.
Apr 02, 2010 | M&K Sound Mp Series MX-350 MK II THX...
Jan 06, 2010 | Mirage NANOSAT 5.1 System System
Hooking up my Digital audio subwoofers
How did you connect it to your receiver?
Jun 14, 2009 | Mirage LF100 Subwoofer
Fuse blowing out
you must check your cables first and try witth anoher cables if the problem remained you will have internal problem inside and needs to fix in service center
Sep 10, 2008 | Mirage LF100 Subwoofer
Yamaha RX-V1200 subwoofer connection to Mirage BPS-150i subwoofer
just connect your subwoofer mono RCA to your amp sub single out rca connector. you do not need to megre all those 4terminals into one. in fact internal circuit of those 4rca are merging inside to one since the sub uses only a single amp. 4inputs was meant for sources with multiple sub out
Nov 02, 2007 | Yamaha RX-V1200 Receiver
Mirage LF100 Subwoofer Logo
596 people viewed this question
Top Mirage Audio Players & Recorders Experts
Ben Armstrong
DaveMc3
DaveMc3
berggei
Are you a Mirage Audio Player and Recorder Expert? Answer questions, earn points and help others
