SOURCE: SP-250 power supply problem
When you pull the trigger the wire should feed imediately, if it dosn't then this will give you the problem. first check the clutch on the wire spool, this is in the centre post that the spool goes on the nut/screw should allow the wire spool to turn easly without tention,
if the spool runs on adjust the cluch. Check the shaft that the rollers are atached they should be held with key-way to stop them slipping, re-adjust the WFS ensure the wire feeds fast or slow as you rotate the WFS control and ensure the wire feeds instantly, lastly make shore the rollers are correct: the right size
SOURCE: clarke weld 85 en welds when gun trigger is not operated
hello make sure its not set on auto or the pin inside the set is not bent good luck
shaun
SOURCE: Welder not welding
SOunds like your ground is not connected solidly either inside the machine or at the ground clamp. Check to make sure the ground wire at the clamp is not broken then make sure the ground wire is connected solidly inside the machine.
SOURCE: power mig astro power 110 burns wire off at tip
I have the same welder. Worked well for 15 years until the drive bearing stopped spinning. I cleaned and oiled the bearing and it has been working like a coon on the farm since. Nice 120 volt welder....
SOURCE: wire broken off inside of liner in mig gun hose
about the only thing to do is take the gun of the unit ,place it straight in line on the floor or bench and try to hand feed the wire back the other way.good luck,this will be a lucky thing if it works.i dont understand how the wire broke off in the first place.
