Question about Sanyo 09KHS51 Ductless Mini Split Air Conditioner
Goodman mini split
I have old model Goodman mini split. WMH24-1A model. Dry mode and Sleep mode lights are blinking. I turning of or disconnecting unit it coming back to same blinking lights. What I need to doo. Thanks.
3 Suggested Answers
SOURCE: goodman mini split model # wmh24-1a error code
It's not an error. you have it set in auto mode and it is cooling. when it switches to heat the lights will switch as well. Set to cool only and it should go away.
Posted on Jul 04, 2011
SOURCE: I have a goodman mini
To change from Cecilius to Fahrenheit on the remote control, hold both the + and the - simultaneously and this will enable you to toggle between C and F. You will need to do this each time you change your batteries.
Posted on May 12, 2012
What remotes are compatible with a Goodman WMH24-1A?
If it's a mini-split them all parts have been discontinued and goodman no longer manufactures mini-splits.
Sep 24, 2013 | Amana Heating & Cooling
What does code blinking five times mean
need to read inside diagram, will tell u what lights mean.
Jul 10, 2013 | Goodman Manufacturing MSG12CRN1N -...
Unit wont start and error code led is blinking five times
Check the unit from the outside. This happened to me: 1.) The unit was not raised off the ground 2.) Rodents had chewed on it. Or it could be: 3.) Replace batteries 4.) The unit will not work off season when it gets too cold to use the cool air option.
Blinking dry indicator goodman split unit
follow this instructions:
http://www.ehow.com/how_5365971_troubleshoot-split-air-conditioner.html
God bless you
May 09, 2012 | Heating & Cooling
Goodman mini split model # wmh24-1a error code snowflake light stays on and 4th light from left blinks. i need to know what that means?
Apr 28, 2011 | Soleus Mini Split Air Conditioner
I have a mini split air conditioning system...The four lights on the system continue to bliNk and i can't it on... What may be the problem?
PCB or your remote malfunction.Try with other remote. If it works, remote problem, otherwise, repair/replace PCB
Jan 15, 2011 | Goodman Heating & Cooling
I'm trying find out if my old goodman unit was a
Hello WESLEY The unit mod# is 3 ton.If the inside part has an 048 number means together it produces 3.5 ton.If inside is 036 it is 3 ton together.If it is a split.If it is a package it is 3 ton.
Aug 02, 2010 | Goodman Heating & Cooling
Goodman A/c not working. cannot find manual. landlord away
Try replacing the batteries first. The blinking may be the battery indicator.
The fact that it blows air when you turn the thermostat to cool tells me that the thermostat is probably working. The problem is most likely outside at the condensing unit. There are lots of potential problems that could be found out there. Sounds like you will need a technician.
Jun 25, 2008 | Goodman CLQ36AR49 Air Conditioner
Sanyo 09KHS51 Ductless Mini Split Air Conditioner Logo
997 people viewed this question
Top Sanyo Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Tim Whalen
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
