Question about Mitsubishi WD-60735 Projection Television
Do I need to order the housing with the lamp after burn-out?
I have a 60" Dlp Mitsubishi television and the lamp burned out (normal wear and tear). Do I absolutely need the lamp housing and lamp bulb or can i order just the lamp bulb? I see both listed but wasn't sure if i needed both.
  • Mitsubishi Master
  • 8,617 Answers
You can order just the bulb then install that in your housing. Being careful not to touch the new bulb with your bare hands as the oils from your finger tips will cause the lamp to fail prematurely.
Posted on Feb 08, 2012
Testimonial: "Terrific...Thank you so much...That was exactly what I needed."
  • 58 Answers
SOURCE: Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Posted on Apr 18, 2009
  • 1153 Answers
SOURCE: Replaced lamp and now can't get a picture
Hi Sally Jo, Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 934C148001. Hope this helps!
Posted on Sep 18, 2007
Slinteriors
  • 8617 Answers
SOURCE: green status light keeps blinking after lamp replacement
continuous blinking green light indicates that the capacitors have failed on the DM pwb. You need the V26 DLP DM repair kit which is available at the following link under their repair category.
http://servicemanuals.vstore.ca/
Posted on Sep 09, 2008
  • 668 Answers
SOURCE: Replacement Mitsubishi lamp busted again in less a year!
A Halogen lamp is a Halogen lamp. They are designed to last between 3000 to 5000 hrs.
You got a much longer life than expected on
the original lamp.
Posted on Jul 25, 2009
SOURCE: How do I reset lamp timer on Mitsubishi DLP TV?
I cant find the solution to reset my lamp hours, I replaced it, unplugged the tv like i was supposed to to. Its not reset. I have a 73" 1080p ...wd 73831 series
Posted on Aug 23, 2009
I have a mitsubishi 3d dlp tv model wd-73640. The lamp keeps burning out. We have replaced it 3 or 4 times in a year. Do you have any idea why this keeps happening?
These lamps should last around 5 years so I can understand your frustration.
Normally the lamp life is shortened by heat issues? Do you have enough space above, to the sides and back to let air flow in and out of the television? Are all fans working? Are the fans staying on for a while after you turn off the TV?
If you're using a power strip to turn off the TV the fans can't run when the television is turned off and it won't cool properly.
Oct 05, 2015 | Mitsubishi Televison & Video
Tv won't power on anymore. i get a solid red light. why?
Solid red light means the lamp has failed. Try replacing the lamp first. Mitsubishi DLP TV Bulbs
These folks have the proper lamp you need and have a 6 month warranty
Sep 16, 2015 | Mitsubishi WD-60735 60" DLP HDTV
My replacement bulbs keep burning out within 30 days. I took a closer look and there is a small square piece of glass that sits next to the lamp housing. It looks as if the light from the lamp goes through...
Something is definitely wrong if you are consistently only getting a month out of a bulb.
Either something is overdriveing the power to the bulb (unlikely) or there is a vibration or something is intruding on the bulb itself.
Good luck and let us know what you find on this.
Jan 08, 2015 | Mitsubishi WD-57732 Projection Television
Have a 65inch Mitsubishi DLP. acouple years old, just heard a loud pop,smelled like it was burning,it turns on but just sound????
hi,
Check the lamp of you tv. The lam is burned. that's why you heared a pop up sound and burning smell. Just check it and replace it. you will get the picture back.
ok
Apr 16, 2011 | Mitsubishi WD65737 65" DLP TV
Please Help. I have a 56" DLP Samsung and the lights just flash
Sounds like the lamp might be burned out. The Lamp should be replaced every couple years. If they are not replaced they will eventually burn out. Replacement is not that difficult and just requires a screwdriver. The lamp is located at the back of the DLP TV on the left side. The lamp can be purchased online from Samsung for about $130 dollars. You might be able to find a aftermarket one for less. Just use your telivision's model number located on the right side of the TV on sticker to cross reference the bulb that is needed or there might be a sticker on the back at the lamp housing that has the lamp part number. And make sure to spend the extra money and get the Lamp with the housing together. You can buy just the lamp for cheaper but that will require you to remove the old lamp from the housing and they are fragile. Much easier installation with the housing/lamp combo.
Jan 12, 2010 | Samsung DLP HL-P5663W 56" TV
Mitsubishi WD 62327 DLP TV
Can I ask where you got the capacitor kit from?
Aug 17, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Just replaced dlp lamp
From what I remember, when you turn on the tv, use the remote and when it asks if you replaced lamp say yes.
Jul 26, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-60735 Projection Television Logo
254 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
