Toshiba 65HX81 red blinking led
Can you send me the step by step for this issue?
  • 1,694 Answers
If HV comes up briefly,then TV shuts down = possible bad yoke and CRT...
If open fuse F850 / F851 etc = bad convergence IC's STK392-110
Either way = a major repair ! HTH.............................T.
Posted on Oct 22, 2008
Toshiba 65h14
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.Viewing it in "Mosaic" or "Sidebar" will make surf easy.
Blinking codes details to many popular brand TVs are given.Surf the site with patience.
Aug 09, 2014 | Toshiba 65HX81 65" Rear Projection...
Red light blinking and no picture on Toshiba Model 65HX81 how do we fix?
Red power light blinking is shutdown--protective mode.
Before buying a remote I would see what is wrong with set.
The most common reason on this model is a short in the convergence circuit--uses two chips----method to see if they are shorted is to locate (not real easy on this model) and unsolder all 18 pins on each chip--if set turns on then(will look bad) one of the chips is gone and both need replacement.
The other issue this set has is bad Hyper boards that cause noise when cold and operate after warmup---more expensive to fix than a convergence problem.
convergence chips used in this set look like these
Mar 30, 2012 | Toshiba 65HX81 65" Rear Projection...
My toshiba 65hx81 cut out lastnight. All I have now is the red flashing pwer light. Where do I begin? Do you know what the issue might be? Thankis, Kyle
Frist Kyle count the number of blinks on the set when it shuts down, this is an error code related to the problem area., The most common failure in this model is the deflection power supply board. This board provides high voltage to the picture tubes and related large signal circuits. You may want to check the horizontal output transistor for shorted condition, if it is found to be shorted replace it an the flyback transformer as these two work to gether to produce the horizontal frequency to produce the high voltage.
Oct 18, 2011 | Toshiba 65HX81 65" Rear Projection...
Toshiba 65HX81 No Power Issue
ur ignition card/panel is burned change it!!
Aug 16, 2008 | Toshiba 65HX81 65" Rear Projection...
Red line will not focus
needs convergence rebuild
call qual tech
Aug 03, 2008 | Toshiba 65HX81 65" Rear Projection...
Toshiba 50HX81 Power LED Flashing
Check any/all soldered-in micro fuses....F850,F851 etc.
Re-check your work......
solder jumper wires on signal board or fuse (s) may blow......T.
Apr 20, 2008 | Toshiba 65HX81 65" Rear Projection...
Picture went off then Red light blinks all the time
Not an easy fix....requires chassis pull, careful soldering and
replacement of parts and fuses.....would you like step-by-step?
Jan 12, 2008 | Toshiba 65HX81 65" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
