Question about Sony KDF-E50A11E TV
Kdf-e50a11e diagnostic codes
Tv switches itself off and the red light flashes 3 times quickly then pause then 3 times again i checked the lamp door and it seems to be closed properly i replaced the bulb 6 weeks ago
  • Sony Master
  • 8,617 Answers
3 blinks is indicating the lamp has burned out. Aftermarket lamps tend to fail quickly. Only use oem replacement lamps for your sony. You can get replacement lamps from www.tvrepairworld.com
Posted on Feb 08, 2012
  • 135 Answers
SOURCE: CHANGE A LAMP
Check the owners manual for instructions. If you don't have it download one from Sony's support website.
There is an external cover over the lamp that is removed with thumb screw(s). If the lamp has a lever, simply lift it and pull. If it is secured with an allen screw, unscrew it and pull the bulb out. Note the lamp orientation and put the new one back oriented the same way. If the old one gets disoriented after you take it out, just match up the high voltage connector inside the TV with the one on the lamp.
Posted on Nov 10, 2008
rockitman187
  • 2559 Answers
SOURCE: kdf-60xs955 red continous blinking lamp light
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced.
Please rate this a fixya
Posted on Jan 30, 2009
  • 5 Answers
SOURCE: replaced lamp; now to doesn't work
I had the same problem and I didn't have the lamp housing all the way engaged. once I slid it all the way in it came on.
Posted on Jun 12, 2009
SOURCE: kdf-50e2000: Shuts off by itself, lamp blinks 4
I just had this issue. I think this solution worked for me. (We'll see after watching for a few more hours.) The TV was intermittently cutting off and then turning back on every 90 seconds or so. It was as though the power was barely breaking contact every once in a while. Kind of frustrating considering that it is a $1000 TV.
The fix I used is in this thread at the URL below. There is a photo of the problem source. I do not think you need a new $160 lamp. The problem is a little "switch" that makes contact between the lamp and the ballast (power regulator).
http://www.agoraquest.com/viewtopic.php?topic=34458&forum=34
The "switch" is not so much of a switch as much as a thin piece of metal that makes contact with the lamp. See the photo in the discussion thread. I bent it out about a quarter of an inch and then reinstalled the lamp. So far so good.
I will post again if the problem crops up again.
Posted on Jul 07, 2009
HDTV GURU
  • 261 Answers
SOURCE: Hello! .. I have a
How many hours are on the set? It sounds like the lamp is going bad, and won't let the power supply turn it on... Give that a try first and we will go from there. Good luck HDTV GURU JAY
Posted on Mar 18, 2011
My kdf-e42a10 tv won't come on flashes green 7 times then flashes red 3 times.
The 3 blinks is lamp door not closed, what it really means is the door may be warped from the heat of the lamp===the door has a plastic peg on the back that when the door is in place engages a lever just behind the door. If the door is even a little bowed=three blinks.
Engage the lever with something not metal and see if set comes on, if it does replace the door.
Apr 08, 2012 | Sony KDF-E42A10 42 in. LCD Television
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
Good afternoon, I have a Sony TV KDF-LSD E50A11E overhead projector, a few months now I've changed the bulb and turn on the TV and some time it turns itself off and the red light blinks 2 times,...
it could be a cooling fan or power supply problem or a switch on the saftey inter;lock on the lamp door
it will require some trouble shooting if your having problems finding some one in your area contact sony for a referal to a servicer in your area
Jun 05, 2011 | Sony KDF-E50A11E TV
Heard a pop. Checked and had to replace the lamp. Now when turned on the power-standby flashes green, then flashes red, but TV never comes on.
How many times red light flashing?
This is an error code and red flashing count indicates a particular problem in specific section of tv, please count how many times red light flashing after 3 seconds long pause and post here to suggest a solution.
Thanks.
May 28, 2011 | Sony KDF-E50A10 50 in. LCD HDTV
Hi, Our Sony Bravia TV model number KDF E50A11E is not working. There is a red blinking light flashes three times and then goes green and then red blinking again after about 3 seconds. Is this a bulb...
On that particular model I believe there is both a lamp indicator light and then the power indicator light. If it is lamp related the lamp indicator light (LED that looks like a sun in a cup...) would be on.
If the power indicator light is flashing red to green, that is a self diagnostic code, and you will have to contact an authorized Sony repair fascility for them to translate the problem. The error codes are not listed in the user manual, since most are not user serviceable.
Mar 01, 2011 | Sony (XL-2400) Projector Lamp for...
KDF-50a12U Powers off then standby light blinks 3 times
Please recheck Lamp Cover and make sure it is fixed in its space securely as 3 times red blink shows lamp cover error.
There is small safety switch in TV cabinet under lamp cover that has to be pushed by lamp cover if it is fixed in its position properly. That switch is not being pressed by lamp cover and causing this error.
Thanks.
Oct 19, 2009 | Sony BRAVIA KDL-40V3000 Television
Red blinking light three times pause then three
Make sure that lamp door is fixed securely and pressing lamp door switch as 3 times blinks shows lamp door switch is not On.
May 13, 2009 | Sony KDF-50E2000 50" HDTV
SONY GRAND WEGA KDF55WF655
tv turned off black screen and red light flashes 6 times over and over again
Feb 28, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Feb 13, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony KDF-E50A11E TV Logo
631 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
