Question about Kitchen Ranges
Creda 950dl shower not getting hot
I had an over heating light come up on this shower after checking i was advised that it was the thermal cut out i replaced this and the over heating light has now gone but the shower works but it barley gets luke warm and only for a minuite then goes cold the shower is only 14 moths old any ideas ?please
  • 171 Answers
SOURCE: Plumbing - no cold water from cold water tap
Hi blondi_1452,
I'm Harvey the Master Plumber.
Your question is: Why would the cold line water be luke warm?
In 30 years I've seen this maybe 10 times. It is relatively rare. But each time it was a cross connection between the hot and cold water lines. It could be this fixture is close to the hot water heater or the cross cnnection is in a faucet or it is in the way the water lines are piped. Anyway I would have to closely inspect the system while running the water in the fixtures in different combinations. Once the cross is located the easiest fix at this point is installing a check valve at the right point. You might consider utilizing thr Repair Directory to find a repairman. Make sure he has solved this type of problem before.
Feel free to contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 14, 2008
  • 18 Answers
SOURCE: FEF352 - Burners will not heat up.
sounds like a power issue if it is all 4 burners otherwise if it is only one or two it is the infinate switch that controls the burner. if it is all 4 then pull the range out and open the panel that covers the cord connection and check for burned wires. next reset the breaker and try burners again
Posted on Jan 31, 2009
  • 56 Answers
SOURCE: Shower will not get hot enough
i have no experience in fixing showers however mine once did this when i remodeled my bathroom so i called one of the guys that was workin on it and he told me that he had takin something out what looked like a gasket and said it was a scald preventer and from then on my shower has been fine hope this helped
Posted on May 19, 2009
SOURCE: warmer lights up but not getting hot - Rangemaster Toledo XT
Hi Sally
I havd exactly the same problem. I contacted Rangemaster/Aga support line (0845 603 5312 if in warranty, 0870 789 5107 if not) and they told me the heating element was shot.
My cooker is 2 1/2 years old, so out of warranty, but they were good enough to send me a new cooker top (top left hand side only of course) free of charge!!!, I just have to get it fitted.
You have to replace the whole left hand side of the cooker top too - the burner that the wok goes on!
Good luck
Posted on May 31, 2009
rick_stokes_
  • 61 Answers
SOURCE: warm water only
You can eliminate the shower control knob possibility by turning on your hot water anywhere else in the house. If you get hot water in other places, then it could be the knob causing it. A substantial lime buildup in the tank can also cause poor heat transfer from the elements to the water.
Posted on Sep 19, 2009
Where will I find the heat reset button on my tcm580 condenser dryer
Hello Mandy, I am not sure what you mean by a heat reset button; perhaps explaining what the problem is, I may be able to assist you. Are you referring to the dryer motor's overload reset button? As a safety feature, a dryer has a high-limit thermostat and either a thermal fuse or thermal cut-off fuse.
In the event of poor air flow where there is no proper ventilation to the heating element- the internal temperature of the dryer exceeds its high-limit, the dryer will shut-down; once it cools off, you should be able to run it again.
However, if the thermal fuse (located on the blower housing) or the thermal cut-off fuse (located on the heater housing) goes, the dryer heating element will will not heat up or the dryer will stop running altogether.
Please note, a dryer will have either a thermal fuse OR a thermal cut-off fuse, but not both.
By-the-way, there has been a recall on certain models of HotPoint Creda, and Indesit tumble dryers due to a fire hazard risk; I am sending you the link...If your dryer is manufactured by HotPoint model TCM580, then your dryer maybe affected. Read the info in the link- it'll give you instructions on how to determine if your specific dryer is affected and what to do.
http://www.which.co.uk/news/2015/12/113-hotpoint-indesit-and-creda-tumble-dryer-models-pose-fire-risk-426557
http://www.itv.com/news/2016-04-18/hotpoint-dryer-fire-risk-which-models-are-affected
Feb 15, 2017 | Dryers
Overheat light won't turn off, strange boiling sound.
it may have calcium build up in the valving.. may need to run some chemical thru it..
Jan 25, 2014 | Home
Shower will not heat up. Creda Aqua 9.5e - was working fine but now no red neon indicator and cold water only. I have checked power going into unit and is ok.
May have a tripped thermal overload or blown fuse. Some overloads reset automatically but some will have a red button to reset it with. Some have to be replaced.
May 02, 2010 | Water Heaters
My creda 950 t shower is pissing water out of it
If this is for a hot and cold water shower, you have to
replace the mixing valve to get the right result. However,
if you can get a repair kit for your hot and cold mixing
valve, you may repair it. And get it done.
Nov 24, 2009 | Plumbing
Bosch PowerStar125 won't heat and I can't get one element to work
It sounds like you have a copper canister unit. Ohm out the elements in that one canister. the directions are on the websight for bosch, or I can walk you through it. But you will need a digital multimeter to do this. If you have a blown element in that one canister, then the tco will not reset.
Jan 01, 2009 | Bosch PowerStar AE125 AE125 Whole House...
I have a Triton topaz 100i shower, recently the water would not heat up, when i opened it the thermal cut out was in pieces, i have now replaced this, but now, no water comes out at all. If i short the...
its the thermal cut-out... when there is something like limescale that causes the temp to get over 50c - the thermal cut out is
activated... it has to be replaced... which u can buy it from triton or get an engineer out to replace it
tip... make sure u clean the shower and shower heads often with a limescale remover....
Apr 22, 2008 | Heating & Cooling
Kitchen Ranges Logo
121 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
