Question about E-Machines T2742 PC Desktop
No input signal from t2742 to monitor keeps going to sleep
Connection and monitor work fine on another computer
  • 4 Answers
Sounds like your video has gone out. Good thing is if it is onboard you can just add a new video card.
Posted on Jan 06, 2015
2 Suggested Answers
  • 415 Answers
SOURCE: Computer not communicating a signal to monitor
You can fix that by getting a new graphics card
I'm assuming you have a T3830 emachine.
here's the link to replace video card
http://downloads.emachines.com/userguides/8511279_eM_NG3_chassis_HW_ref_en.pdf
Mark
Posted on Apr 09, 2009
No input signal on monitor-not connected to tv-computer works fine except for the no input signal
no input or signal means that the monitor is not receiving any signal from the CPU and if the power light is amber then and the cpu works fine then there could be a problem with the cable connecting the CPU and the monitor ...check the cable.
Mar 03, 2014 | Dell Computers & Internet
How do I fix the error no vga input signal no dvi input signal monitor going to sleep
Check if you VGA is properly settled in the PCI slot. Try to take it out, clean the slot for dust.
If that doesn't help, it is well possible that you VGA is not working any more.
Jun 10, 2012 | HP Computers & Internet
HP w2207 no vga input signal, no dvi input signal monitor goes to sleep
There is no signal coming from your PC.
excuse some of the solutions as sounding dumb, but we have to explore all possibilities.
Check the power cable going into the computer
Check the power input disconnect switch on the back of the power supply and make sure it is on
If the pc is plugged into a power bar, make sure it is turned on and the breaker isn't tripped
press power on the PC and make sure the lights are coming on.
now for the solutions that may actually help.
disconnect the power from the PC
if the video is on a card, remove and re-seat the video card
hook the power back up, connect the monitor and try again.
the CMOS on the computer may need to be reset.
I hate totally clearing the CMOS, so what I usually do is remove 1 stick of ram and power up. If the system is alive again, power down, put the RAM back in and power back up.
If that doesn't work, turn the system off, put the CMOS jumper to the CLEAR position for 15 seconds, put it back to the Normal position and then power back up.
Basically, if the monitor works on your friends system but not on yours, the the problem is your system, not the monitor (assuming it isn't working fine til it gets into windows...if that's the problem, you have a driver or configuration problem)
How to fix my monitor when its in sleep mode
I assume this is a Desktop computer:
The Monitor receives, graphics or text from the PC (personal computer) and displays it on the screen.of the Monitor.
If you see a message on the screen that says * NO SIGNAL * in most cases the Monitor is good, and the Monitor is either not connected to the PC or there is a problem with the PC Check the connections and the video card.
The problem could also be related a failure of the motherboard, memory or the processor
Let us know..
Nour Sabre
www.aaatvservice.com
May 21, 2012 | HP W2007 LCD Monitor
My vs19 monitor will not come on. says vga input/ no input signals and then goes to sleep. I checked all connections and all are ok. Happened about 2 months ago but has worked fine since. Is there a way...
It's not your monitor. It's your computer.
If you see a display on the monitor, it means it's working. (and you do)
Your computer is not sending a signal to the monitor. If you are working with a laptop, you can just press the Fn key/special function key combo to send the signal to the external monitor.
If you are using a desktop, then you need to do some troubleshooting.
Jun 03, 2011 | HP Computers & Internet
Monitor Hp w1907 has no input signal, how do I get connected and keep it from going to sleep
If you set the PC to go to sleep after certian amount of time than it will not put out signal to the monitor. You need to go to display properties (right click on the desk top)/screen saver -power/set the display to never turn off.
Nov 30, 2009 | HP w1907 LCD Monitor
No Input Signal, Monitor Going to Sleep
if you have twisted od bent the cord to much the wires could have broke inside the cord.
Jul 31, 2009 | HP w1907 LCD Monitor
My W2207 monitor keeps going to sleep
Hi,First there is no signal from the PC . check if the display card has come out while moving the monitor, or just reinsert the display card in the PC , then boot the pc .
Jan 14, 2009 | HP w2207 Monitor
Monitor going to sleep at startup
try changing the video card of your computer..
Aug 27, 2008 | HP vs19 (Silver) 19" LCD Monitor
No Input Signal
Dont Panic it is Nothing...
Your Monitor is safe...
If it say "no Input signal" - "Check VGA cable"
it means that the Monitor is finding signals from the computer,and the cable is either not connected or unsecurely connected.
Jul 18, 2008 | Chi Mei Corporation 221A Monitor
E-Machines T2742 PC Desktop Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
