Brother mfc 9320CW leaving magenta stripe down the left side of the page
SOURCE: Brother HL-3040CN printer is printing a yellow
Hey, i had this problem with the cyan colour and it is easily fixed. You take out the problem cartridge and under it, youll see a green tab that you can slide left and reight. you must make sure this tab is at the "home" position. ie, all the way to the left until it clicks into place. http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/000000/000065/faq000065_049.html?reg=eu&c=eu_ot&lang=en&prod=hl3040cn_all&Cat=7 This shows a picture about half way down the page of what it should look like. this solved my problem:) cheers!
Posted on Apr 08, 2011
  • 990 Answers
SOURCE: Black stripe down middle of page when copying
open the top cover on the left hand side glass plateform with a narrow piece glass clean it with alcohol.
Posted on Dec 13, 2008
faxman789
  • 297 Answers
SOURCE: Magenta Dots vertically on Left margin of page
That is referred to as a repeating defect...most likely caused by a defect on the magenta drum unit. Here is a link for information on how to repair this problem:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000016/faq000216_016.html?reg=us&c=us&lang=en&prod=mfc9440cn_all&Cat=3
Posted on Jan 17, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: Brother MFC 9840CDW when printing is leaving what
The problem you are describing sounds exactly like what I have seen from numerous Brother Drum Units. I would say it is very likely this print quality problem is coming from the drum unit. About $150 from lots of sources on the net. They are good for 17,000 pages so depending on how much you use the printer, I would get a drum unit and replace it. Here is a picture of what the drum unit looks like.
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Oct 21, 2010
mariolands
  • 2296 Answers
SOURCE: first it was putting magenta stripes down each
1. There are some options in the menu to clean the printhead, refer to user manual for the instructions.
2. If that won't fix it, check the cartridges to see if there is any toner leaking out of them.
3. If none of the above fixes it, you might have to replace the print head.
Posted on Nov 11, 2010
My brother printer is leaving a large bold black line across the page
Across the page means a light burnt drum. The drum units are light sensitive and if they have been left in the sunlight for too long the photosensitive film has been damaged. The only thing to do is replace the damaged drum unit. If it was down the page then that will be a different fault and easily repaired.
Aug 27, 2014 | Brother MFC-9320CW Color Laser Printer -...
Scan problem
What is it scaner or paper problem?
If it is a paper problem take out all of the paper and return few pages in the tray. Try and print out something.
But I still thing that you will have trouble.
If the things I tell you don\'t wotk you may have to change a spear part like drum unit or a toner cartridge.
Sometimes if the drum unit is at it\'s life end you may experiance this problem.
May 16, 2012 | Brother MFC-9320CW Color Laser Printer -...
Need to know how to replace my cartridge
Replacing the toner cartridge is an easy task.
Check out this link and replace your toner cartridges by yourself.
Hi, my printer Brother MFC-9320CW enters in sleep mode every 30minutes. Any cloues how to clear the timing?
try fixing the SLEEP menu.
Follow the steps I found:
Enter Menu and navigate to General Setup. To enter press OK. Use up or down arrow buttons to go to Ecology and again press OK. Enter Sleep Time menu and enter 0 if you don't want your brother to enter sleep mode. Press OK and exit printers menu.
May 06, 2012 | Brother MFC9320CW All-In-One Printer
Check toner level on brother mfc9320cw machine
On the Brother MFC-9320CW you can check the toner settings through the printer directly. Go to your printer and press the "Menu" button (located in the center, slightly under & to the left of the screen). Then arrow down and click on "6. Print Reports." Select "Ok." Then arrow down and click on "5. User Settings". Select "Ok". Press "Start" to print the report. On the last printed page will be a list of toners and the bar will show you how much toner is left. Hope this helps.
Mar 21, 2012 | Brother MFC9320CW All-In-One Printer
We have a Brother mfc-9320cw printer that is printing with a thick and ugly crust of ink on the right edge of every 8.5x11" sheet we print. What is causing this? We've replaced the belt. It...
This happened to mine, only my thick edge was blue. My problem was that the little green slider that cleans the wire on the toner holder was pushed to the wrong side. (Sorry, can't remember technical term for the green thing or the wire! It has an arrow on it and it's pretty easy to spot.) Push it all the way back to the left until it clicks and it should fix the problem.
May 25, 2011 | Brother MFC9320CW All-In-One Printer
Right side of every page has pink strip down page
Either your magenta cartridge is leaking out of the right corner or you have a defective magenta drum.
(maybe it got scratched when changing the cartridge?) If it's the magenta drum, you have to replace all the drums since they come in one unit. OEM part only.
Nov 20, 2009 | Brother MFC-9840CDW Laser Printer
Dec 13, 2008 | Brother MFC-7820N Printer
2,040 people viewed this question
k24674
