Question about SAMTRON 55V 15" CRT Monitor
Monitor Problem My monitor screen sometimes shows a red tint while sometimes it behaves normally.Secondly, the On-Screen Display is displayed on the screen automatically and it stays on till the system is on.
  • sonusony39
    sonusony39 May 15, 2012
    monitor display not working
  • sonusony39
  • 348 Answers
There may a dry solder inside monitor or signal cable may disconnected internally move it if display changs then cable is faulty replace it
Posted on Nov 11, 2008
Yellow screen
There are a variety of problems that can happen to the display monitor of an Acer laptop.
The most common problem is the screen fading or becoming too hard to see.
This can be corrected by adjusting the brightness levels.
Another common problem involves incorrect color, which can be resolved by adjusting the display color settings.
Yet another big problem is the display freezing or appearing jumpy, which can be resolved by updating the display driver.
Hold down the "Fn" key.
Tap the right-arrow key to brighten the display screen.
Tap the left-arrow key to darken the display screen.
Release the "Fn" key to save your display settings.
Color
Right-click on the desktop and click "Graphic Properties."
Adjust the screen resolution by clicking "Display Settings" and choosing a resolution setting from the drop-down menu.
Click "Apply" to check the resolution of the display.
Click "OK" to save the resolution settings.
Adjust the color of the screen by clicking "Color Correction" and moving the brightness or contrast slider to the right or left.
Click "Apply" to check the color resolution of the display.
Click "OK" to save the color settings.
Click "OK" to exit the Graphic Properties application.
Update the Display Driver
Right-click on the desktop. Click "Personalize," "Display Settings" and "Advanced Settings."
Click the "Intel Graphics" tab and choose "Monitor Properties."
Click "Driver."
Click "Update Driver" and choose "Search Automatically."
Click "Install" to install the updated monitor driver. After the driver has been installed, click "OK" to restart the laptop when prompted.
Yellow screen
Yellow tinting in monitors can be caused by either a software calibration issue, bad cables or a worn out display and backlight.
Before you assume that the issue is a hardware one, determine if there are software settings that affect the color or if the cables are working correctly.
After checking these items, and if the yellow tint only occurs on one monitor and you cannot eliminate it, the problem is a display hardware issue and it is less expensive to replace the monitor.
Unplug the power cord from the monitor and replace it with another one.
This is a standard power cord used in printers, monitors and desktop PCs so you can trade it for a cable from another device.
Turn on the PC and monitor to see if the yellow is still there.
Turn off the computer and monitor.
Replace the video cable with another VGA cable from another monitor.
Use one from another computer before going out to buy one.
Restart the computer to see if the yellow tint is gone.
Right click any area on the desktop and click "Properties" from the list of options that appears.
Choose "Display Settings," then "Advanced Settings."
Select "Monitor" and click the "Calibrate Color" button.
Wait to see if the yellow tint goes away.
Locate the temperature color settings on the monitor.
Adjust these to see if there is a change in the color.
A warm color setting will give the screen images more of a yellowish tint.
Click on the "Start" icon, then click "Control Panel" and "System and Security" and choose "Device Driver."
Locate the video driver and click "Update."
Select the option allowing Windows to connect to the Internet to find an updated driver.
Wait for the update to complete in a few minutes.
Expect the yellowing issue to disappear.
Connect the PC to another monitor to see if the same problem occurs.
If the yellow tint does not appear on the newly connected monitor, the problem is a bad backlight or display and the monitor should be replaced with a new one.
http://www.adobe.com/education/pdf/cib/ps7_cib/ps7_cib17.pdf
Jul 21, 2013 | Acer Computers & Internet
My hp pavillion dv7 1245dx screen has a red tint in the background?
Your lcd screen is bad. It's either the lcd screen or the video card inside the computer, but most likely the screen. You can isolate the problem by connecting an external monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok without the read and green tint then your video card inside the computer is good but your lcd screen is bad. If the Borrowed monitor displays the same red and green tint then the video card inside the computer is bad.
It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
Jun 05, 2012 | HP Computers & Internet
Screen is rolling constantly
. Sounds like its time for a new lcd screen. Try plugging an external monitor to the laptop and see if it behaves the same way. If the external monitor scrolls, then you more than likely have a Video Card problem. If the external monitor displays without scrolling then your lcd screen is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display
May 01, 2012 | Dell Inspiron 9300 Notebook
Screen is rolling
May 01, 2012 | Dell Latitude D530 Notebook
The pc is ok and log in normal, but the screen is red. Is this the card or can I fix it
This problem is typically a monitor problem. Firstly check all the connecting pins of the monitor vga cable where it plugs into your display card. Sometimes these pins are either bent or pushed into the plug and do not make proper contact with the card pin socket.
The quickest way to determine the fault would be to plug in another monitor & see if you get the same red screen. If the other screen also shows up red, you can safely rule out a faulty screen & just replace your display card. My guess is that the other screen will display correctly & you will have to repair or replace your own screen.
Let me know if you need any further assistance.
Best wishes,
Graemevm
Mar 04, 2011 | LG Studioworks 99T Monitor
Red tint on Viewsonic P930b
We do a lot of LCD monitor repairs and usually when you get the red tinted display it means the backlight tube is going out. This part is like a very small fluorescent tube just like in you office lamps. The tube is part of the display section and is very hard to replace. You can check the power supply first just to be sure. We have a dis-assembly/repair guide on our web site at: www.ccl-la.com/badcaps.htm If you find any bad capacitors you can change them and check but I would be it is the backlight tubes, if so just replace the monitor.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Jul 20, 2009 | ViewSonic VX924 19" LCD Monitor
My display has a red tint to it
Try adjusting the color properties of the monitor using the controls located on the front of the monitor.
If you can't correct the color, then it's a problem in the color circuit. As an ex tv repair guy I can tell you it may cost more than the monitor is worth to fix it unless it's still under warranty.
Jul 13, 2009 | Dell Computers & Internet
Monitor Problem
please clarify your problem.
what video card are you using??
Oct 22, 2008 | Computers & Internet
Problem with my monitor display
1.cheeck VGA cable
2. check any Loose contacts in video section(Neck board)
Jun 12, 2008 | IBM E74 17" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
83 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
Richard Lilja
Richard Lilja
William Miller
William Miller
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
