Question about Electrical Supplies
Pressurewasher 6hp wont stay running
    Problem Solver:
  • 11 Answers
You may of already tried this but is there a water flow back connection on the hosepipe? has it been connected to the end that fits onto the pressure washer? we had this same problem when it was connected the wrong way round... the flow back stop connection should be tap end...hope this helps...:-)
Posted on Feb 08, 2012
My 2stroke 6hp mariner s idle is way too fast
Adjust the tickover speed. There are lots of videos here. There is a screw stop on the linkage. If operate the linkage by hand you will see it. The Evinrude video shows this well.
http://www.bing.com/videos/search?q=6hp%20mariner%20adjust%20idle&qs=n&form=QBVRMH&pq=6hp%20mariner%20adjust%20idle&sc=0-13&sp=-1&sk=
Jun 27, 2016 | Boating
I have a 2012 mercury 6hp four stroke that will not idle without the choke on
Hi, Lee and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting ***** set too low.
8. Air/fuel mixture ***** set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
Boat Motor Won Stay Running Watch This
Mercury Outboard Idle Adjustment
2010 6 hp Yamaha 4 stroke wont run with choke in Page 1 iboats Boating...
8m0055686r. google this for a free manual
Won Idle Here what did to fix it Yamaha Outboard Parts Forum
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 13, 2016 | Motorcycles
Suzuki outboad 6hp 4stroke
outboard motor yes ? only run in a tub or water attachment turned on before starting ! after 2 or 3 min the choke should be able to go off ! if not then remove the carb and clean jets etc with carb cleaner ! been stood a while ? fuel older than 5mths is off so replace also ! ??
Apr 20, 2014 | Motorcycles
Yard Machine rear tine 6hp tiller that wont start.
Ok, what's happening, is your carburetor metering hole is plugged. When you place your thumb over the carb, it draws fuel through the primer circuit to feed the engine instead. What you need to do, is clamp off the fuel line, take the nut off the bottom of the carburetor bowl, and clean that nut. Look closely at it; there is a hole that goes down the center of it, and a hole that goes through it side to side towards the bottom. These make a "T" shape inside the nut. You need to make sure that these are completely clear and clean. The one at the bottom is very small, and plugs easily. You usually need a small piece of wire to clean it, such as a single strand from a wire brush. You can use carburetor cleaner to loosen it up a bit, but the important part is to clean that hole out. You also need to make sure that the float moves freely up and down while you're in there. If it sticks in the up position, it will starve fuel as well. Also look closely at the gas that came out when you did this. Was there any water in it? If so, let a bit drain out before putting it all back together.(unclamp the fuel line). Hope you have it back online soon.
Mar 23, 2010 | Mtd Products Yard Machines 158CC Tiller
6hp craftsman air compressor runs to 3 or 4
make sure it is plugged into a 20amp outlet. and do not use an extention cord
Jan 16, 2010 | Craftsman Air Tools & Compressors
Mower wont keep running
recycler toro 6hp. 10 years old,little usage. Starts then stops, have to keep priming. Can anyone help?
Jun 14, 2009 | Toro Lawn Mower With Toro Power Tools
My Yard Machine W/a 6hp B&Sengine will crank & run on starting fl
Most likely you still have a jet inside carburetor that is clogged how did you clean it soak it in carburetor cleaner? Did you take out jets to make sure they are clean
May 05, 2009 | Briggs & Stratton 66set Panzer Tractor...
Craftsman 6hp 150psi 30gal won't keep running
It sounds like the internal circuit breaker in the motor is heating up and then the breaker trips to shut down the motor. This is the protection so you don't have a fire if the motor burns up. The smell you have is the coils in the motor. Sorry to say that you will need a new motor for this unit. I hope this helps out.
Jan 17, 2009 | Air Tools & Compressors
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
