Major DNS error
I've already had a computer repair person spend several hours on this and couldn't fix it.
My HP desktop is running XP Media Center edition. I'm on RoadRunner hard-lined to a modem and router (not connected wirelessly). All the equipment is fine, but I can't connect to the internet...or so it seems.
If I type in a web address, such as google.com, etc. I get a "cannot connect to the internet" error. But if I type in the google IP address into the address bar, it connects fine. So for some reason, the DNS is not converting is my guess.
I tried everything I could before having someone else look at it. When I tried the system restore, it gave me an error message saying it could not go back to the date I chose. I tried several. None worked.
Also, there is a Windows SP3 that is trying to download the update and has not been able to. That was around when the problem seems to have started so I don't know if that triggered the problem or just is another symptom.
So far, the computer guy removed my Norton's to see if that was preventing the download. He tried uploading the SP3 update via CD-ROM (unsuccessful). He determined the equipment is all working properly but can't figure out why the IP addresses work and not domain names.
He suggested I back everything up and start from scratch...use the system console to "wipe" everything (my computer didn't come with a restore CD and he says its partitioned on the hard drive) and go back to bare bones.
So my questions are:
1. Is there no other option?
2. If I did this, will it really work, theoretically?
3. How do I do it?
Thanks in advance.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 164 Answers
Solution #1
Method 1: Configure Windows Firewall to enable HTTP traffic loadTOCNode(3, 'resolution');To configure Windows Firewall to enable HTTP traffic, follow these steps: 1. Click Start, click Run, type Firewall.cpl, and then click OK. 2. On the Exceptions tab, click Add Port. 3. In the Name box, type HTTP. In the Port box, type 80.Note This procedure enables HTTP traffic. If you also require HTTPS traffic for Secure Sockets Layer (SSL) sites, repeat these steps, but type HTTPS in the Name box, and then type 443 in the Port box. Method 2: Configure network settings loadTOCNode(3, 'resolution');To configure network settings, follow these steps: 1. Click Start, click Run, type Firewall.cpl, and then click OK. 2. On the Advanced tab under Network Connection Settings, click your network connection, and then click Settings. 3. On the Services tab, click Web Server (HTTP), and then click OK.
Note If you must also enable HTTPS traffic for Secure Socket Layer (SSL) sites, click both Secure Web Server (HTTPS) and Web Server (HTTP).
Solution #2
1. Click Start, click Run, type Certmgr.msc, and then click OK. 2. Locate and then right-click the certificate that you want to export, point to All Tasks, click Export. 3. Click Next. 4. On the Export Private Key page, click Yes, export the private key, and then click Next. 5. On the Export File Format page, click Personal Information Exchange - PKCS #12 (.PFX), click to select the Include all certificates in the certification path if possible check box, and then click Next.
Note Do not click to select the Enable strong encryption (requires IE 5.0, NT 4.0 SP4 or above) check box. 6. Follow the directions on the screen to complete the Certificate Export Wizard. 7. On the client computer on which you want to import the certificate, click Start, click Run, type Certmgr.msc, and then click OK. 8. Expand the certificate store into which you want to import the certificate. Typically, you want to import the certificate into one of the following certificate stores: • Personal • Trusted Root Certification Authorities • Intermediate Certification Authorities 9. Right-click Certificates, point to All Tasks, and then click Import. 10. Follow the directions on the screen to complete the Certificate Import Wizard.
Solution #3
To resolve this problem, modify the host header. To do this, follow these steps: 1. Start Internet Services Manager, and then expand the Web server that you want. 2. Right-click the Web site that you want, and then click Properties. 3. Click the Web Site tab, and then click Advanced. 4. Click the host header name that you want to modify, and then click Edit. 5. In the Host Header Name box, type a name that does not include white spaces, and then click OK three times.
Posted on Oct 22, 2008
    Scholar:
  • 87 Answers
1. There are many options!
2. Yes, Probably, but perhaps not. "You don't know, what you don't know!"
3. Reloading from scratch on an HP is dependant on the model.
Now if you would like to try some other options,
You say you are connected to a modem and a router. Your modem is a router for all intents and purposes even if it has only a single lan port. If your using a second router, you are double NATing. The second router should not be configured as a gateway but as a router. Then your DHCP assigned IP addreses will be correct as well as defaualt gateway and DNS settings.
Try this, do not use the WAN port for the second router, just plug it into one of the other ports. This will allow the router to work pretty much as a hub. If this works, reconfigure the router to be a router not a gateway.
Dns failed
dns.exe problems occur when important operating system files become misconfigured, deleted, or damaged. This is a common problem with computers that don't get maintained regularly. Eventually the system becomes overloaded with problems and begins to crash and display errors. You may also notice your system becoming very slow due to high CPU and memory usage.
Resolution
We strongly advise against fixing dns.exe errors manually. Doing so could take several hours, do more harm than good, and end up not even resolving the underlying problem.
The most recommended solution is to use a reliable software application that can quickly diagnose and fix dns.exe errors (and much more). Programs such as Advanced System Cure run a variety of troubleshooting and diagnostic tests on your computer in order to pinpoint and fix almost all known issues. The result is an error free PC that is actually much faster than before. And it is free!
Nov 13, 2013 | Computers & Internet
I have an HP m7570n media center pc (xp). The on-board sound card stopped working. After trying many things, I paid for HP support where they had me run a recovery (without telling me I would have to...
just boot the xp cd and try doing the repair process
but before doing it ...if your using the xp not from hp recovery go to the bios and disable any sata port
how to repair boot the cd then the three options comes after a long loading process press enter press f8 and then press r this repairs and replaces and also puts the missing driver files for the usb support that u might need
if not working after this ..download the needed driver from here http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=3185132#N1543
if not working after all these things ..then must a hardware problem...
Jul 22, 2010 | HP Pavilion m7570n (EX331AA) PC Desktop
Hp 7463 xp media center will not see hp thumb drives of 4 or 8g's. Even tried 2 different powered usb hubs. Only see error 22.
Hi turn off the computer and unplug the power cord for 2 minutes. Then replug it and start up the computer. That should solve it. If it doesn't then you have a software issue most likely a virus.
Jan 05, 2010 | HP Media Center PC 873n (P9875A#ABA) PC...
Icons and start up bar is missing
right click on ur desktop and click on arrange icons by then click on show icons on desktop if it is not already check marked.
Apr 24, 2009 | Microsoft Windows XP Media Center Edition...
E:\i386\winntupg\netupgrd.dll
http://www.fix-all-dll-errors.com/netupgrd.dll/
You can get the new dll from here...just follow the link & this will fix the problem :)
Mar 22, 2009 | HP Media Center PC 873n (P9875A#ABA) PC...
Computer hangs during pc recovery process
you may need to swap the disc from one cd-rom to another.
Mar 10, 2009 | HP Compaq Presario SR2011WM PC Desktop
Major HP crash
i think you got the wrong disks man, nothing to do with the motherboard.
a clean installation
it is recommended to this service at least
once every 8 months, it wipes all your hard
drive from data, programs, bugs, errors and viruses
this will 100% solve your problem guaranteed.
for xp, insert the xp installation disk
restart the computer and a message will
come up asking to press any key to boot
from cd. once you do that "i mean you press a key"
then a blue screen will load then asks you
to press Enter to install xp.
1. press enter
2. select the partion and press enter
3. select continue "it warns you to delete files"
4. select format "quick"
5. now let it do the rest and follow instructions
6. when the installation is finished you'll notice
its like new again, some computers will need
drivers which you can get from manufacturer
website. download and install them.
that's it but for a detailed information click here
Mar 08, 2009 | HP Media Center m1080n (PC099A#ABA) PC...
My computer keeps rebooting after if reaches windows xp logo
I also have this same problem about a constant reboot of computer and what I did is I replace the Power Supply and everything is already working , becauise this problem can be link in failing power supply already...
Hope that helps..............
Oct 05, 2008 | HP Media Center PC 873n (P9875A#ABA) PC...
Hp pavilion m7330n motherboard issue
The system in question requires motherboard model ms-7184 and can be found on ebay for less than $100.  If your repair guy used a different motherboard you will get the issues described and need to reinstall the OS.  It is impracticle to put any more than $200 in most desktop computers more than 2 years old, your repair guy should have advised you of this straight off.  Find a new person to take your equipment.
Jun 27, 2008 | HP Pavilion Media Center TV m7330n...
Computers & Internet Logo
David Payne
David Payne
