Question about Clarke Power Products Clarke 130EN Wirefeed Welder - 110 Volts, 130 Amps, Model# WE6523
Can not get a spark
I have a clark weld 130 and cn not seem to get it to spark
    Genius:
  • 1,212 Answers
Check internal fuses and breakers first. Then see if the contactors are closing. If they are not check the 24 volt contacter for coil continuity. If that is okay, check for voltage at the wire feed motor with an analog meter. Put it in a plstic bag and tape the bag where the test leads come out- there is a big magnet in the movement. Keep the meter in the bag to protect it, but check the motor to see if it is seeing power impulses from the control board. If it is not gettin pulsed power when trigger is pressed, suspect a failure of the SCRs on the control board.
Posted on Feb 08, 2012
4 Suggested Answers
SOURCE: clarke en 130 parts
Check out http://www.toledoblade.com/apps/pbcs.dll/article?AID=/20090430/BUSINESS03/904300333 and be angry with the bank, not Clarke.
Posted on Jul 25, 2009
luxur4
  • 92 Answers
SOURCE: Have Clarke MIG 130 EN. replace Power Cable Assembly 23000054
Your local welding supplier would be you first choice. you will be able to fit an alternative power cable, dosn't have to be Carke,
Posted on Jan 26, 2010
kel1guy2002
  • 3740 Answers
SOURCE: i have a Clarke weld
I do not know of a US source for these Clarke EN130 Wire drive wheel parts. I don't know of any interchangeable subs either. Your welder was made in Italy and the wheel drive is metric.
This is probably your best bet in trying to find any parts for it:
http://www.clarkeinternational.com/shop/search/filter/EN130/page/1
Not sure if you knew this:
Clarke Power Products Files in Toledo
Clarke Power Products Inc., a wholesale distributor of power equipment from Perrysburg, Ohio, filed a Chapter 11 petition on Jan. 8, 2009 in Toledo, saying it owes $7.9 million to the secured creditor Key Bank.
Court papers say assets of $13.8 million are comprised of accounts receivable, inventory and cash. Clarke’s products include air compressors and power tools.
The case is In re Clarke Power Products Inc., 09-30071, U.S. Bankruptcy Court, Northern District of Ohio (Toledo).
Thanks for choosing FixYa.
Kelly
Posted on Sep 05, 2010
I need clarke mig welder partes for the gun on a 130en. I can't find them any place, can you help me find them. Thank you.
Hi:
It will be better to adapt a new gun. Go to your nearest Praxair (www.praxair.com) store and ask for a tweco mini gun with a clarke adapter. Tweco accesories are available at ALL welding stores and it's a cheap gun also.
May 24, 2011 | Clarke Power Products Clarke 130EN...
Clarke 130en Welder settings for Welding aluminum with .030 wire on 1/4" sheet aluminum
try 75 25 argon helium gas or straight helium helium makes metal melt hotter
Dec 11, 2010 | Clarke Power Products Clarke 130EN...
Need a new torch assy for my clarke 130.
Go to your nearest Praxair store and ask for a tweco mini gun with a clarke adapter. Tweco accesories are available at all welding stores.
Dec 02, 2010 | Clarke Power Products Clarke 130EN...
I have the clark en130 i want to weld stainless what do i need to add
Just a trimix gas, if you are using solid SS wire. If it is core shielded SS wire, you are all set up.
Trimix gas it's a mix of Argon, helium and CO2.
Dec 01, 2010 | Clarke Power Products Clarke 130EN...
Getting lots of splatter weld will not hold
Check polarity of machine.
Solid wire with gas assist will need straight polarity ground clamp to negative side.
Flux core wire no gas, need reverse polarity; ground cable to positive side.
Oct 27, 2010 | Clarke Power Products Clarke 130EN...
What gas do i use for welding mild steel .I have argon and co 2 canisters
Can use argon/co2 mix or CO2 the wire usually has the gas named on the lable
Aug 26, 2010 | Clarke Power Products Clarke 130EN...
Jan 22, 2010 | Clarke Power Products Clarke 130EN Mig 110...
Need a owners manual for Clarke 130EN mig
Try ClarkeInternational.com in the welding section...they have the manual though it is the British Version.
Aug 19, 2009 | Clarke Power Products Clarke 130EN...
Clarke en 130 parts
If you are just looking for consumables you can get parts online at
www.welding-direct.com/fistmiggunre.html
May 08, 2009 | Clarke Power Products Clarke 130EN...
Clarke Power Products Clarke 130EN Wirefeed Welder - 110 Volts, 130 Amps, Model# WE6523 Logo
133 people viewed this question
Top Clarke Power Products Welding Tools Experts
 Kenneth
Kenneth
Wade Mobley
Wade Mobley
Are you a Clarke Power Products Welding Tool Expert? Answer questions, earn points and help others
