Question about Dell 1815dn All-In-One Laser Printer
Clean underside platen glass dell 1815 printer
There is foggy stain on the underside of the dell 1815 printer platen glass.. how do i remove this scanner glass to clean it?
3 Suggested Answers
  • 279 Answers
SOURCE: Dell Photo All in One Printer 964-scan/copy problem
This sounds like a problem I've had with a Lexmark scanner. It turned out that there was a switch on the bottom of the scanner that would lock the mechanism in place for shipping. Do you see anything similar on this unit, or am I barking up the wrong tree?
Posted on Aug 28, 2007
SOURCE: MFP 1815 D Unlock Scanner message
Inside the print tray (where the paper comes out) on the upper right there is a blue lever. Pull it toward you and that will unlock the scanner. I just did this and restarted my printer and it worked! Hope this helps!
Posted on Aug 04, 2009
Scanner window is cloudy on bottom. needs to be wiped clean
if you are a technical kind of guy you may want to download the service manual from MAISE MANUALS to see the correct proceedure to remove the platen glass without damaging your scanner!
attempting to do this without good instruction will most definatley be a bad day for your printer this job would likely take me about 3/4hr to complete as to remove the glass several covers need removing.
Jan 14, 2014 | HP Photosmart C6180 All-In-One InkJet...
How do I remove the glass from my HP 3210 all-in-one printer? I need to clean the underside of the glass. Thanks
Remove the 2 #10 torx screws which are in front of the glass area. Remove the platen cover by lifting it straight up (after opening it) and pressing in on the two spots marked on the hinge. The platen cover can now be lifted out of its hinge slots. Unplug the wire which powers the platen cover light and set the cover aside. Now remove the three additional #10 torx screws along the rear of the machine. The whole top including the glass can now be lifter up and off the machine. Clean the glass with a good glass cleaner and a soft cloth or lens paper. Make sure there is no lint on the glass and reverse the order to reassemble it.
Nov 28, 2010 | HP Photosmart 3210 All-In-One InkJet...
I have a ricoh 2232c. Do you know how I can clean
In order to clean the optics, you have to remove the two optic covers (one over the **** glass on the left and one on the rear side of the main platen glass). Each cover should have 2 or 3 screws.
Clean the **** glass and platen glass with alcohol and a lint-free rag (both sides) and blow compressed air onto the mirrors, lamp, and reflector. It's a good idea to turn off the copier before doing this.
When reassembling, clean the white strip on the underside of the **** glass cover as well.
May 08, 2010 | Ricoh Aficio 2232C Color Copier
Dell 1600n printer, how can I clean the platen glass?
you will need to take your printer plastics off to clean.4 screws on back panel take out then one screw on left side cover.take out paper tray open toner door 4 screws to remove,turn on side and on bottom there are 3 tabs both sides to remove side panels.one side has a speaker wire to unplug.take off display cover 3 screws to take out.lift off top cover and remove 4 screws 2 each side lift off platen and clean. reverse the order to put back together.take your time and be careful good luck
Mar 11, 2010 | Dell 1600n All-In-One Laser Printer
How do i clean underside of platen glass Canon MP160
for mp160, flip the cover open, the one that you open to gain access to the ink cartridge. you will see two screws at the underside of the scanner base. unscrew both. gently pull down at the front control panel and pop up the front lip of the plastic that holds the platen glass. then, at the back of the printer, adjacent to the paper loading tray, just below the platen glass cover, you will see two clip like stuff. remove the tray by pulling it upwards vigorously but firmly. then, get a flat screw driver to pry these up to release the lock. then, facing the printer, gently pull the whole of the platen glass, together with its plastic frame, towards you. do this while gently rocking the platen glass up and down, or left and right. to return the platen glass, reverse the process.
Jan 12, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Head unit wont scan
Clean the underside of the platen glass, be careful to remove the screws, also there is a plastic cover at the top of the platen under it there is a white correction plate clean this plate with cloth.
Feb 06, 2009 | Sharp AL 1631 Copier
HP 6110 scanner glass is cloudy
Here is how, but it seems a lot of work.
- Remove all the torx-screws
- Remove the little glass on the left side
- Remove the Control Panel Cover (lifted it a little with a screwdriver and released two latches)
- Remove the Control Panel itself (another two latches&move to the left)
- The whole top of the 6110 is attached to the bottom with 4 latches. I remove that, turn it around and clean the glass.
Note: The cables between 6110-bottom and control panel/feeding unit are long enough to set those things aside.
Dec 06, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Dell 1815 dn printer scanner issue: single line appears in scans
Do you get the same line when you use the adf for other purposes?
If so, check the scanner glass just before the platen for something like white-out on it. Clean both the scanner glass and platen glass with Windex.
That is a common problem on all ADF scanners.
Good Luck
Nov 15, 2008 | Dell 1815dn All-In-One Laser Printer
How to clean underside of platen?
The underside of the scanner glass can only be reached by a a canon service tech. The compartment is supposed to be sealed and dust-free, so if it has gotten dirty, you should send the unit back to Canon for servicing.
Feb 07, 2008 | Canon imageCLASS D320 All-In-One Laser...
Dell 1815dn All-In-One Laser Printer Logo
229 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
