Question about Brother MFC 9880 All-In-One Laser Printer
Where can i find the on/off switch on a brotherMFC9880 printer
    Problem Solver:
  • 16 Answers
Check the manual, That would probably help
i couldnt see one by looking at pictures of it
Posted on Feb 07, 2012
Printer carriage is jammed (makes horrible noise)so won't return to centre for me to replace the ink cartridges. Just says erroe and refer to manual and i can not see an answer there. Thanks!!
Try this. Switch off the printer. Unplug the printer from the mains and also unplug the usb from the printer. Switch off your pc too.Try to move the printer carrier with your hand to a position where you can change the printer cartridges. After doing so, plug again the printer to the mains and also the usb. Switch on the printer and see whether it starts ok. Now switch on the pc also and if everything looks fine you may start printing.
Nov 24, 2015 | Canon Pixma MP990 InkJet Printer
Z6100 eeprom reset
you have to enter Service Mode , so can do Reset EEPROM
how to enter :
1. Make sure the printer is switched OFF from the power switch on the front of the printer and
NOT from the power switch on the back of the printer.
2. For Call Agents who will request the User to Perform certain troubleshooting action, hold
the Down arrow key and the Cancel key down and switch the printer ON using the front
power switch. Wait until you hear one beep (usually after 5 seconds) before releasing ALL
three keys.
Mar 28, 2013 | HP Designjet Z6100 InkJet Printer
My epson tx700 printer dispaly ink pad at end of life and printer not start
A fix from a forum:
Procedure 1 We found this procedure to work for the Stylus Photo 1270 type printer, and understand that it also works for the 870 range and even earlier models like the Stylus Color 740. The error is indicated on these printers by all four lights on the printer flashing. Even if you press the power switch on the printer, the lights continue to flash, and the printer does not turn off!
  1. Turn off your printer, ensuring that the print head is at it's home location and locked in place as normal;
  2. Power off the printer at the wall or by removing the power cable, for at least 20 seconds;
  3. When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer's power switch was 'on' - switch it off and return to step 1;
  4. Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down;
  5. When the paper-out LED flashes, release the buttons;
  6. Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button);
  7. The printer will now attempt to reset, including resetting the EEPROM memory and running a short (about 10 seconds) cleaning cycle.
Procedure 2
  2. Hold down the paper feed button only;
  3. Turn on the printer;
  4. As the paper feed light starts flashing, release the button;
  5. Immediately hold down the ink-drops button for some 10-20 seconds or until the printer springs into life;
  6. Allow printer to complete it's processing, then turn off for a few seconds, and back on again for a newly working printer!
Procedure 3 - for 1290 and possibly 890 printers 1290 printer with green (power / data) and red (ink / paper feed) lights flashing alternately:
  1. Switch off printer with panel switch;
  2. Switch off printer at mains switch - leave off for 20+ seconds;
  3. Hold down roll feed and sheet feed buttons;
  4. Switch on at mains;
  5. Switch on at printer panel;
  6. Continue to hold down roll and sheet feed buttons until both green and red lights flash together in synchronisation, not alternately;
  7. Switch printer off and then, after a few seconds, on again at mains switch;
  8. When red and green lights are both flashing in synchronisation, release the roll and sheet feed buttons;
  9. Press and hold down the ROLL FEED button (the one at the extreme left) and keep it down until the machine finishes whirring, cleaning etc and the green light comes on steady;
  10. Release the roll feed button and all should be well.
Apr 25, 2011 | Epson Printer
The ink pads are at the end if their service life.
Depending on what type of printer you have:
Procedure 2
Mar 13, 2011 | Epson Office Equipment & Supplies
My printer doesnt work it doenst switch on at all
If printer doesn't work and it doesn't switch on, I assumed that there is no power at all on the printer. Check the AC line voltage if it is correct.
Unplug the printer. Remove the LVPS/HVPS, and check the fuses for continuity.
• If open, then replace the LVPS/HVPS.
• If not open, then check the switch continuity across its conductors with the switch on.
Turn the switch off. Plug the AC line into the LVPS/HVPS, and switch unit on.
Please try reseat power cable. If this does not resolve the issue, you may need to replace the LVPS (Low voltage power supply) on your printer.
For further assistance, please contact Lexmark Technical Support
Feb 07, 2011 | Lexmark E260 Laser Printer
Showing ink empty when not
switch printer off. switch pc off, switch pc back on (you have now rebooted pc),when home page appears switch printer back on,good luck
Jan 17, 2011 | Canon PIXMA iP8500 InkJet Photo Printer
This may sound REALLY stupid but...how do you switch off the printer instead of using the main switch on the side of the printer? (I'm using HL 2142 Brother Laser Printer)
I plug my printer into a power strip that has its own switch. This saves on having to reach around the printer to get to the regular switch.
Aug 03, 2010 | Brother HL 2140 Laser Printer
I got error ox886a6916 - all lights are flashing
Try disconnecting the USB cable while the printer is on. Switch off the printer remove the cartridges switch the printer back on wait for it to go through the sequence switch reinsert cartridges switch on then reconnect USB
Jul 02, 2009 | HP Photosmart 2610 All-In-One InkJet...
One page jammed after switching off when 1 page printed. Orange light on
Hi ,
First off all u switched off the printer and on switch off mode press the green button and on pressing the button switch on the printer hold that button for 5 seconds and then release the button whenever u realese the button the printer start migrating . After migrating if the printer have same problem then u reinstall the printer driver and again reinstall the driver, after reinstalling the driver the printer will working fine .
May 26, 2009 | HP LaserJet 1010 Printer
Brother MFC 9880 All-In-One Laser Printer Logo
29 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
