Question about Panasonic Audio Players & Recorders
Speaker fixings do you need special brackets to fit to wall
    Problem Solver:
  • 16 Answers
You can put your speakers on the floor, or place them on a stand
I dunno anything about mounting them
Posted on Feb 07, 2012
How do fit a wall bracket on 50 in techwood tv
TECHWOOD 50inches TV Wall Mount Bracket TV BRACKETS TV WALL BRACKETS...
You need to get a proper bracket for the TV. Some TV units use a vesa mount but the Techwood uses a much larger mount. If you look in the manual for the TV, it will call out the bracket size in mm. You can order and go from there. Fairly simply process.
Semper Fi,
Z
Jan 30, 2018 | Televison & Video
Can a Sony bravia kdl-32s2010 be fitted to the wall on a bracket as it looks like all the connections at the back would be behind the bracket plate if one was fitted
It can for sure.
https://docs.sony.com/release/KDL26S2010_instal_wall_mount_bracket.pdf
I'd just find one that works. Some have vertical mounting brackets that may avoid the connections and others are flat plates that might interfere.
You can also use spacers to keep the plate off the actual rear surface. I've used plastic spacers to give me additional room for my hand between wall and TV on the one wall mount that I have that doesn't have an arm to swing it out from the wall.
Mar 28, 2017 | Sony BRAVIA KDL-32S2010 32 in. LCD...
We have a tevion 42 inch TV with floor standing speakers can we fit them to either side of the TV?
There is no reason why you cannot attach the speakers to the wall on either side of the TV. Professional brackets are available to do this at any good hardware or home entertainment store.
Unlike the old CRT (glass screen) TV's, LCD and LED flat panel TV's are not affected by the magnets in speakers ?
Apr 24, 2016 | Televison & Video
Over range microwave doesn't fit in the space outlined by the installation template
You missed something while reading the installation directions but that won't fix it. since you already drilled holes in the wall lower the mount down as needed then drill new holes in the mount to match the holes you drilled in the wall. The problem would have been worse if you were off left or right... up and down is easier. Remember you maybe just not dropping the microwave low enough to fit in the slot at the bottom of the wall mount before you tilt the micro up.. check it one more time...including the directions before you re-drill
Sep 26, 2015 | Bosch 30" 500 Series Over-The-Range...
Elan wall speaker mounts
Try Radio Shack, Best Buy, Sears, or eBay.
Apr 13, 2012 | Elan SEL350 Speaker
How do I wall mount the phone
Most new phones come with a special wall mount bracket included in the box.
If you no longer have this bracket then you may be able to order a new one similar to the one advertised at the following link:
http://www.nec-dsx.com/nectewamokit.html
Good luck.
Joe.
Nov 22, 2011 | Lands Phones
I have a wall bracket on the laundry but hjow do I get the dryer on to the bracket
Is the wall dryer bracket, the correct one to fit your hover
May 28, 2009 | Dryers
How do I remove a plasma panasonic mounted on a wall.
if it is a swing bracket 4 screws on back bracket holding it in need to be removed, if it is flat wall bracket lift strait up the wall to remove.
hope this helps
daniel
Jan 11, 2009 | Panasonic TH-50PX75U Plasma HDTV
Rear speakers in audi 1999 audi a4
You don't want to fit that - it's the factory amplifier for the rear speakers (the rears are amped, the fronts are not). You need to run new wires from the head unit back to the new rear speakers so that the speaker-level outputs from the new head unit are used to drive the new speakers.
Dec 16, 2008 | 1999 Audi A4
How to fit wall bracket to tv
the bracket should have instructions. the set will have screw holes on the back to bolt to the bracket.
more detailed info needs to come from the bracket MFG
Dec 05, 2008 | Televison & Video
174 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
