TX-P37X10B HOW DO I CHECK THE AUDIO INPUT SETTINGS ON MY TV
2 Suggested Answers
SOURCE: Lost audio on my Westinghouse
My daughters tv was working fine then all of a sudden the sound went out?
Posted on Apr 20, 2015
Hookup Audio to new Samsung 52"1080 TV LN52A650
The best way is to check the user manual. If you dont have i can provide one.
Sep 02, 2008 | Onkyo TX-DS575 Receiver
All plugged in but no pictures to tv
Bypass the video / audio of the DVD to the TV and see if the input works on the TV. If so the connection of the home theater must be checked once again.
Connect the video and audio correctly and switch to the same function connected in the rear panel. If there is no video or audio or one of them then the digital logic switching circuit can be faulty. Since most of the selection is done through LOGIC GATES this IC could have failed.
You will need to use a logic tester to trace and confirm if the rest of the amp works fine.
Also try changing the input ports.
Jul 27, 2011 | Onkyo Tx-sr507 A/V Receiver
[TX-DS595] My Video 1 stopped working, no audio, (Right before the super bowl!) yet I get audio on DVD & Tuner. What could be the problem? Thanks, Ira S. Cohen
Well, what's on Video 1 and is IT okay?
You don't say if you're using the analog audio associated with Vid 1 or if you have digital audio coming in and assigned to Vid 1. Check the cables. If using the optical, make sure it has no small-radius bends.
If analog audio, try another input - video 2 or 3.
If you have Cable/SAT TV as the source, what's going on with ITS audio settings?
http://www.retrevo.com/support/Onkyo-TX-DS595-Receivers-manual/id/365dj195/t/2/
You can always run that RCA cable pair from the source to theTV as a test for audio, too.
Feb 05, 2011 | Onkyo TX-DS595 Receiver
How do I get my Samsung TV audio to output though my onkyo tx-sr608?
If it is a relatively new TV you should use an optical digital audio cable. These are often called "toslink" cables. Plug one end into the "digital audio out" port of your TV, and the other into a free toslink port on the receiver (there are two on the back and a third on the front of the 608).
You should then change the settings on your samsung tv to: - turn the digital audio (s/pdif) output on - allow bitstream output over s/pdif - turn the tv speaker off I am not sure which model Samsung you have, so I can't go into great detail, but I'm sure you will be able to find the relevant settings, most likely under "sound" in your system menu.
lastly, you will probably want to use the input assign page of the onkyo on-screen menu to assign whichever input you use to your TV, and change its name accordingly.
Jan 09, 2011 | Onkyo TX-SR608 Receiver
Hi, I am having trouble connecting my Nintendo Wii to my Onkyo TX-SR507
Take the adapter cable from the Wii that plugs into the back of the Wii and converts the output(audio/video) into RCA style pin plugs, you will have: RED=right channel audio, plug it into any of the red audio INPUT on your Onkyo, then you will have WHITE=left channel audio, plug it into the other white INPUT jack next to the red plug on the Onkyo, then you will have YELLOW= video(picture) that will go directly to the yellow video INPUT on the back or side INPUTS of your TV.
Then when you want to play the Wii, set the input mode on the Onkyo to the inputs that you connected the red and white plugs into, then change the input on your TV to which ever the input is labeled on your TV in which you plugged the yellow plug into, you now will have sound comming from your Onkyo and the Wii up on the TV screen ready to play. Good luck!
Jan 27, 2010 | Onkyo Tx-sr507 A/V Receiver
I can't get the tv volume to work when using my onkyo tx-sr806. What might be the problam?
I assume you are looking to have sound from the television through the speakers that are connected to your receiver?
If that is the case then make sure you have connected the audio out from the television to the audio input for what might be labled monitor or TV/SAT. Then turn the volume on the televsion all the way up and switch the input on the receiver to TV/SAT.
Jun 17, 2009 | Onkyo TX-SR604 Receiver
I have "Onkyo TX-SR304E" and PS3. Will this rcvr support PS3 in all means? Is there any special setting hat I ned to follow to get the best from my rcvr as well as PS3? Pls advise. Your help much...
what u can utilize on your tx-sr304 is the optical input at the back of the receiver. connect an optical cable from your PS3 into the receiver then follow these steps:
*make sure that the digital input on the front panel of your receiver matches where you placed the optical at the back of the tx-sr304 (either OPT1 or OPT2)
*all you have to do is keep pressing the digital input at the front panel until it goes to OPT1 or OPT2 (preferrably stay on DVD mode)
AFTER completing this go to your PS3 settings:
go to settings / then go to sound settings / then audio output settings / then set it to DIGITAL OUT (optical)/ then play and enjoy.....ü
Mar 05, 2009 | Onkyo TX-SR304 Receiver
Cable connection to Onkyo TX-SR605 7.1
You will have to connect your coax to the tv coax input.You can view cable this way.To use the hdmi input to tv,you will have to change your input settings back and forth on the tv menu from hdmi to rf input.There is no way to hook your cable to the txsr.
Oct 22, 2007 | Onkyo TX-SR604 Receiver
Onkyo TX DS797 no sound from cable TV
Have you made sure the receiver's INPUT SELECTOR is set to "Video 2"? I know it seems like a stupid question, but worth mentioning as many folks would set the receiver on TV, which would not work unless the signal was also plugged into a "TV input" in back of the receiver. If your setting is correct, try running the TV cable sound temporarily into the receiver's DVD input, which we know does work. If you still don't get cable TV sound when the receiver is set to "DVD", then you have a problem with the TV cable audio portion. Most receivers would fail completely, rather than have only one input fail, so my guess is that there is a hookup or switching error somewhere.
Feb 15, 2007 | Onkyo TX-DS797 Receiver
32 people viewed this question
 Grubhead
Grubhead
