I switched the camera on and it indicated memory card locked
SOURCE: Memory card locked
I just got done fumbling around with the same problem. All you need to do is take the card itself out of camera and there's a mini switch on the side of the card that slides up and down for lock and unlock.
you have to put a bit of tape around the bit were the little tab use to be.. This works epically if you have lost the tab from the card.
p.s. i did this with an SD card an it worked i don't know if it will work with any other types of card. good luck anywhos, try yahoo answers they seem to have alot of info too. (Y)
SOURCE: sandisk memory card
Has this card EVER worked with your camera? Since you didn't mention the model number of the Canon, it's possible that you have a compatiblity issue here. Most 4GB SD cards these days are actually SDHC cards, which store memory differently (in sectors, like a hard disc drive, rather than bytes, like your main memory). All SDHC compatible cameras also support SD cards, but cameras sold before the SDHC standard was created will not support SDHC memory cards.
There's a chance that Canon has a firmware upgrade to solve this. You would have to look on the Canon USA web site for this, based on the model number of your camera.
Take the card out. On the left side of the card is a tiny white switch. Reverse the position.
SOURCE: CARD LOCKED
There should be a small toggle along the end side (it is tiny and easily missed, but it is there, I just checked my memory card / mine is 4GB SD card from Sony) that you can swtich to unlock
and your images may come back that way.
Look for it this way, hold the card face down it should be on the back edge where you use your thumb or finger to push it into the slot on your camera.
