Question about Harman Kardon DPR 2005 Receiver
Harman Kardon DPR 2005 turns on and lights up but switches off after a few seconds?
My amp will power on and light up, but then switches itself off after only a few seconds. Can anyone help? thanks
  • 1 more comment
  • adamcavalier Nov 09, 2008
    few seconds? problem, and notify you when a new solution is offered.
  • Anonymous Dec 03, 2008
    I have the same issue except mine lasts a few minutes and then shuts off. I've given up on it.
  • 40yearfan Apr 10, 2009
    Same as everyone else's. Mine will stay on for a few minutes and then shut itself off. If I try to restart it right away, it will shut off immediately, but if I let it set for a little bit, it will run for a few minutes again before shutting off.
markfreedman
  • 312 Answers
SOURCE: I have a Harman/Kardon reciever
Hi, I am beginning to come across this issue with Harmon/Kardon receivers repeatedly. I recently wrote a short article suggesting how to handle this. I'm not sure whether or not my suggestions will be effective. They would normally be generally correct for all receivers. I would be most appreciative if could you let me know what happens. Best Regards, Mark
Here it is with some technical explanations.
"What we are doing, in this case is looking for a shorted out speaker system, or wiring to speakers, or cables or components that are connected to the receiver that have a short circuit. This is what I would do if I were called to your house to debug your sound system.
Follow this procedure:
1 Disconnect one set of speakers at the back of the receiver and turn the power button on again. See if it stays on. If it doesn't go to step 2.
2 Remove the next speaker and keep repeating the test.
3 If it still stays off, disconnect all of the equipment connected to the unit, one piece at at time. After each time, turn the receiver back on to see if it shuts down.
Somewhere along the line, the receiver may not shut down. If that is the case
identify the the offending cable(or component that is connected to it) and replace or service it.
I hope this solves it for you. If not your receiver will unfortunately need professional servicing,
Best,
Mark
Posted on Jan 24, 2011
Duncan
  • 218 Answers
SOURCE: Amplifier/receiver switches off systematically after a few second of use
Sounds like a bad output channel is causing it to go into protect mode. Time to see a repair tech.
Posted on May 02, 2007
SOURCE: Harman Kardon AVR 120 turns off by itself after normal work for about 1 min
Followup on higlider's problem. Now it has to be turned on ten times before it stays on. Email from Harman Kardon only suggests taking it to an authorized repair shop. It is clear that it is not from speaker short or overheating, because it only happens when the rcvr is cold.
-higlider
Posted on Jan 05, 2008
im4um2
  • 77 Answers
SOURCE: When I go to power
Depending on your ablilities there might be a quick fix. It sounds like the contacts in your on/off switch are either corroded or worn out due to heat. Ensure the unit is unplugged from any electrical source. By opening up the unit you will have to detach the on/off switch, and by bending the prongs carefully, open the casing up. Clean all internal part using contact cleaner. If the contacts are worn or corroded, you can try replacing or what I did was added some solder to the contacts and put the unit back together reversing my steps.
Good Luck.
Posted on Jun 27, 2008
  • 382 Answers
SOURCE: How does the speaker wire physically connect to
You have 7 pairs of plastic binding posts.
Unscrew the post until it comes out an eighth of an inch.
You will see two spaces in the black plastic one at the top and one at the bottom of each binding post. That space is for the wire. Strip half an inch of jacket off your speaker wire and slip the stripped part inside the hole and screw the binding post down on it and it will squeeze the wire against the contacts.
If you find that difficult since the posts are so close tommorow, a "Banana Jack" may be put on the wire then pushed into the hole in the binding post.
It is difficult to describe in writing but onece you see it you will understand.
Black posts are the negative, they are all on a common ground. Coloured posts are positive.
Posted on Jan 01, 2010
HK DPR 2005 is shutting off by itself after running for about 5 seconds
when you connect any device you should always have the power off. if you connect while power is on you will blow that input up after time. sorry for the bad news
Apr 13, 2014 | Harman Kardon DPR 2005 Receiver
Harman Kardon AVR7550 turns itself off.
check to see if there is a reset switch inside on transformer bd. could be dirty. clean with contact cleaner.
Nov 26, 2011 | Harman Kardon Audio Players & Recorders
I have a Harmon Kardon DPR 1001 and I added an additional set of rear speakers and on the OSD it is not recognizing the speakers
Register and download the owner's manual and reference guide (service manual) for free at retrevo.com
http://www.retrevo.com/support/Harman-Kardon-DPR-1001-Receivers-manual/id/386ci259/t/2/
On page 19-20 you must tell it that it has surround back speakers (something other than NONE). They aren't just 'recognized'.
Apr 23, 2011 | Harman Kardon DPR 1001 7.1 Channels...
My Harman/Kardon AVR 140 is stuck on stand by mode
I have the same problem on my AVR 1550 - its been bugging me for ages then it works again, then it doesn't ...
Aug 28, 2009 | Harman Kardon AVR 140 Receiver
I have a Harman Kardon HK-3375 stereo receiver. I
A power switch either works or does not work. It does not power on and then mysteriously power off like yours is doing.
You have some sort of power relay that is being powered off after a few seconds.
I would check out the power supply for your anomaly. And no, it is not a simple fix like you are capable of performing.
Apr 01, 2017 | Harman Kardon HK 3375 Receiver
Harman Kardon DPR 1005 problems
Sounds like the power supply or associated module. Definitely fixable, but probably needs a technician.
May 13, 2009 | Harman Kardon DPR 1005 Receiver
Harman Kardon DPR 2005 7.1 back speakers out
Upgraded unit at local electronic store for discount. wanted something with more power anyways. Thank You for
Oct 05, 2008 | Harman Kardon DPR 2005 Receiver
May 01, 2007 | Harman Kardon HK 3480 Receiver
Harman Kardon DPR 2005 Receiver Logo
758 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
