Question about V180 Motorola OEM Cellular Phone Earbud Headset with Send/End Button Headset
Sound on turning on or off V180
How do I turn the sound off on my V180 when it is turned on or off?
0 characters
1 Points
Sound turning ignition
turn down volume before starting auto
Aug 14, 2014 | Headsets
Can't hear when someone is talking to me on my Blue parrot B250xt
be sure you have your media volume turned up. You can also call VXI they offet excellent tech support
May 21, 2014 | VXI Corporation Blueparrott B250-XT...
How to pair craig cma3532bt
To Pair:
1. Turn on your Bluetooth speaker/headphones (slide switch to BT)
2. Light should turn on Blue. If not, plug speaker into USB connector and light will turn Red to indicate it's charging.
3. Make sure Bluetooth is turned on your PC or Phone. Select device name: CMA3532BT.
4. Enter pairing code (passcode): 0000 or you can try: 1234
Jan 03, 2013 | Headsets
Have been told by numerous people that my headset sounds very garbled when I talk. If I turn it off and speak without the headset it's fine, so the problem is not the location. Sometimes, when I turn it...
Try deleting the headset from your phone's menu, turn your headset & phone off. Wait a few seconds then turn power your phone back up. Now try repairing the two and see if that makes a difference.
Good luck from Headsets Direct!
Jan 11, 2011 | Plantronics Voyager PRO Bluetooth Headset
How to pair nokia bh-104 with iphone
Ok.. you need to do the following:
1. Turn the headset off. 2. Turn on the Bluetooth on your iPhone (it will automatically start searching for Bluetooth devices) 3. Press and keep pressing the power button on your BH-105 Nokia Headset until you hear two sounds, the first is the one that notify's you that the Headset is turned on, keep pressing and you will hear another sound (like a beep), once you hear that second sound release the power button on the headset and voilaaa... your iPhone detected the Headset... Cheers...
May 23, 2010 | Nokia BH-104 Bluetooth Headset
It will not turn on after a full charge
Sounds like you have a bum unit.  Plantronics gives a 1 year warranty with every wireless product, I'd send it back.
Have you made sure that you're turning it on correctly?  You push the call answer button and hold it down for about 3 - 5 seconds before it turns on, until the blue light turns on.  Make sure that you don't hold it longer than that or it will go into pairing mode.
Apr 26, 2009 | Plantronics Discovery 925 Bluetooth...
Motorola H680 lost sound
try to turn it off and turn it back on, or maybe charge the headset.
Feb 16, 2009 | T-Mobile 81339TMIN T?•MOBILE BLUETOOTH...
Cannot hear but people can hear me with 330, No sound.
This may be a broken or loose wire in your headset that prevents you from hearing them.
Or the headset is not turned on. Press the call control button for 2 seconds until you hear a beep or see the indicator light glow blue to turn headset on. Your headset is out of range. Move the headset closer to the phone or Bluetooth device.
Jan 17, 2009 | Plantronics Explorer 330 Headset
Headset won't turn off
It sounds like you have a defective unit. When you close the mic boom, the headset should turn off.
Jan 04, 2009 | Motorola Mobility H710 Bluetooth Headset
No sound
Had the same problem with the BT250v 'connected' to my Nokia 6021. When connected to my notebook, the 250 did produce sound, so decided the Nokia was the problem. Fixed the problem by doing a full reboot of the phone like this:
Jabra: Turn off the 250
Phone: Delete the BT connection to the Jabra (in BT settings)
Phone: Switch off BT
Phone: Turned off the phone (I've even removed the battery)
Phone: Turned on the phone
Phone: Switch on BT
Jabra: Turn on the 250 for detection
Phone: Look for audio devices
Phone: Connect to Jabra
Problem fixed!
Sep 02, 2007 | Jabra BT250 Consumer Headset
Headsets Logo
Top Headsets Experts
Brian Sullivan
Brian Sullivan
Are you a Headset Expert? Answer questions, earn points and help others
