Question about Jet -JTAS-12XL-3 Tablesaw 5HP/3PH/230V LFR
SWITCH NOT TURNING OFF
Had to switch off at breaker box
  • 2,176 Answers
There is more than likely dust/dirt in the switch and won't allow it to break contact when turned off. I would recommend replacing the switch. BEFORE removing anything make a note of all wiring. Most local repair shops should be able to match the switch up for you. UNPLUG TOOL before attempting any repairs.
Posted on Feb 08, 2012
Intermittent Intermatic Pool Timer T40003RT3 The pool timer is 220v but only one 110v 20amp breaker in the breaker box to the pool equipment and when it is off the pump will not run in manual mode.
http://waterheatertimer.org/How-to-wire-Intermatic-control-centers.html
http://waterheatertimer.org/Intermatic-control-centers-and-manuals.html#RT3
RT3 series has T104 240 volt timer -or- T103 120 volt timer, -plus- low voltage transformer for pool light.
The circuit breaker can be used for transformer, or another outlet or nearby light etc, or it can be used for a T103 120 volt timer.
To trace the wire back to breaker box.... open you main panel and start turning off breakers one at a time and label the panel.
See if you have single breaker or double breaker supplying power to pool equipment.
Gene
Water Heater Timers Save Money
Jun 10, 2015 | Intermatic Timer T40004RT3 300 Watt Pool...
Whirlpool dryer ler6620pq1 starts and dries fine..however, you have to place something in front of start knob or it shuts off. works normally as long as something in holding start knob in
There are centripetal contacts in the motor that have to work or the motor wont stay running (spinning).
CHECK THE POWER IN YOU BREAKER BOX.....
220 volt dryers have 1 (large) breaker or 2 (small) breakers (tied together) in you breaker panel. If there are 2 breakers tied together, it is possible that only one has tripped causing you to lose a phase. That could cause weird issues like you are experiencing. Try turning off this (double) breaker and then back on again.
If it's still working the same way you may have a bad motor. Check the parts / troubleshooting site below if it's still not functioning properly.
" If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. "
Dec 01, 2014 | Whirlpool Dryers
Is there a fuse or breaker on a Panasonic CW1803SU Air Conditioner?
If there's no power up on the unit, you can check your breaker switch box to see if there's any tripped breaker switch. If so, turn it off, and turn it back on. In some cases a sub-panel is installed somewhere else to provide power to the unit. Normally that's where the breaker switch will be in that scenario. If after doing that it keeps on tripping it, or it just won't power up, then you might have some electrical components inside the unit that might be damaged, like a capacitor, or the compressor itself. Sometimes when the compressor breaks it stops turning and overheats, causing other parts to burn also. To fix this you will need to call a professional.
Jul 07, 2014 | Panasonic Heating & Cooling
Lights and outlets on one side of room work,outlets on other side of room do not work. no juice to either outlet.
Have you checked the breaker box? Usually this is a thrown breaker; flip the switch, by turning it completely off, then back to on.
Sep 17, 2013 | Water Heaters
Lights not turning on
Check wiring, check wire nuts, check bulbs. it will be something simple.
Loose neutral wire.
Loose bulb, 3-way switch wired wrong.
Loose wire on breaker.
http://waterheatertimer.org/How-to-wire-switches.html
http://waterheatertimer.org/How-to-wire-GFCI.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Aug 25, 2012 | Electrical Supplies
I have a circuit breaker that controls a light switch and all the outlets in one bedroom and controls half the outlets and a light switch in another bedroom. None of which work now. I have replaced the...
One single cable runs from the circuit breaker to a junction box in that area of the house.
The cable has a black Hot wire, white Neutral wire, and bare ground wire.
Once the cable arrives at junction box, it can split up 2 or 3 directions.
Each successive box receives a cable that feeds back to the first junction box.
Chances are the junction box is on the ceiling. And it will be the ceiling box that is closest to main breaker box.
Junction box can also be a switch box. In that case it will be switch box closest to main box.
Find the junction box, as point of organization.
Open junction box and separate all black and white wires.
Turn power on and see if breaker sets.
That will tell you if problem is between main box and junction box.
Junction box wires are separated.
Tape tester leads to wood sticks to keep hands away from power.
Turn power ON and test each wire in junction box to bare ground wire.
Tester will light up on Hot wire.
Test Hot to each other wire in box, except bare ground, and tester lights up on Neutral
This identifies the cable that comes from breaker box.
Now, reconnect cable from breaker box to one of the other sets of black and white wires located in junction box.
Check if breaker resets.
If breaker resets, see what circuits are working, and you can eliminate them as suspect.
Remember each successive box in a circuit has 1 cable that connects back to main breaker box
Going 1 box at a time, and disconnecting black and white wires, will eventually lead to the suspect.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 05, 2011 | Electrical Supplies
A light circuit doesn't work (no lights on) with good bulbs. Circuit has 4 switches, no outlets. The breaker does not trip (swapped breaker, no change). At each switch ,115 VAC across switch terminals,...
If I understand correctly you have a circuit with 4 light switches.
None of the 4 switches work, yet all 4 test for 115Vac.
Test each screw on switch to bare ground to get reading.
This problem could be loose neutral wire inside the switch boxes or anywhere along the line, or inside breaker box. Check white wires.
All 4 switches connect back to breaker box on white neutral wire that connects to neutral busbar inside breaker box.
http://waterheatertimer.org/240-v-water-heater-circuit.html#120-240
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on circuit or any do-it-yourself project.
Feb 10, 2011 | Cooper Wiring Devices COOPER WIRING SINGLE...
How do you wire a GFCI light switch and outlet combination? There are 2 black wires coming out directly from the back of the switch side.
If I understand correctly, you are replacing a single switch that has two wires.
You want to install a switch/plug-gfci similar to one shown below.
You are working on wires inside a box:
To wire this kind of device you need at least 2 cables entering the box.
Each cable has a black-white-ground wire.
Cable 1) One cable comes from breaker box. This is the Hot cable
Hot cable has black-hot-from-breaker & white-neutral-from-breaker
Cable 2) One cable goes to the Load (light, fan motor). This wire is controlled by the switch. This is the Load cable
Load cable has black-to-load & white-to-load.
Leviton combo GFCI and Switch
There are 2 screws on either side of switch
There are 2 screws to either side of plug
There are two wires on back of device
2 screws on either side of switch: there is a brass-colored screw and silver-colored screw.
Black-hot-from-breaker connects to brass colored screw on side of switch
White-neutral-from-breaker connects to silver colored screw on side of switch
2 black wires on back of device
Black-to-load connects to black wire on same side of switch as brass-colored screws
White-to-load connects to black wire on same side of switch as silver-colored screws
2 screws on either side of plug
These screws are used when your box is a 'junction' box that feeds wires forward to another box ... for example you have 4 receptacles in a room, the cable enters first box and then goes to the next box and to the next box. Suppose your switch was one of the boxes. Wire arrives from a previous box (this is the Hot cable, every box has 1 Hot cable). Your switch box sends one cable to the Load (light, fan etc), but it also sends another cable to the next box which has a receptacle or another switch.
If your box has a third cable that feeds forward to other boxes, then the screws on either side of plug are used. The black-to-next-box goes to brass screw. The white-to-next-box connects to silver screw.
And all further boxes and devices are protected by the GFCI device.
If you need more information, please answer back and I will help.
Oct 24, 2010 | Cooper Wiring Devices ACE6001V-K "ACE"...
Kitchen lighting problem.
Open neutral. check the fixture/switch closest to the bkr panel that is not working for a bad connection in a wire nut, if not there, move to next fixture/switch closer to the panel
Feb 10, 2009 | Whirlpool Gold Series GI15NDXT 15"...
Fan will not turn off
You should have a power disconnect within 10 ft of the unit.
Follow the high voltage power wire. The box you are looking for is typically gray brown or black, has a small door that flips up, and either a pull out switch or a breaker style switch inside.
They are usually mounted on the wall of the house near the unit.
Sometimes they are found in an outdoor panel box near the meter. Those are breakers.
Always test for power after turning it off just to be sure.
Dec 25, 2008 | Heating & Cooling
Jet -JTAS-12XL-3 Tablesaw 5HP/3PH/230V LFR Logo
109 people viewed this question
Top Jet Saws Experts
woodzowl307
Are you a Jet Saw Expert? Answer questions, earn points and help others
