Question about Hamilton Beach 48465 12-Cup Coffee Maker
Hamilton beach brewstation says pour water when full and will not brew
3 Suggested Answers
SOURCE: Hamilton Beach Brew Station
I am having this same problem.
Posted on Jul 30, 2008
  • 291 Answers
SOURCE: my hamilton beach brew stations quits after
You just need to run white vinegar through it. Put white vinegar in the same way you do water (but don't put any coffee grounds in the basket). Run it as many times as it takes to get all the vinegar out, and then run it again three or four times the same way. After it runs normally, run water through it until the vinegar smell is gone.
The cause of the slow brewing is that the water you normally use has some amount of hardness to it, and over time the hard water minerals build up on the heating element inside the machine. The buildup prevents the heating element from heating the water as fast as designed. The vinegar will dissolve the minerals and let the heater work at full capacity again.
If you want to avoid this in the future, just run the white vinegar through it once a month or so even if it's not running slow.
Posted on Jan 31, 2010
Hamilton beach brewstation will not brew
Can you define will not brew? Do you mean no water transfers from the holding tank to the brew carafe? Does coffee not heat up?
Apr 11, 2013 | Hamilton Beach BrewStation 47665
Shuts off before brewing
After you fill the top portion, do you pour the water into the bottom half of it? Sometimes after I fill up the bucket (that is the top half) I have forgottent to pour it into the bottom half and I have hit start and that is exactly what it will do.
Apr 18, 2012 | Hamilton Beach BrewStation
Hamilton Beach BrewStation 12 cup Coffee Maker, coffee leaks into the bottom water reservoir after brewing.
there is a small rubber flap valve in the tank. if you carefully clean that on a regular basis your problem should end.
Dec 26, 2011 | Hamilton Beach BrewStation
Hamilton beach brew station leaks water all over when filling the coffee maker - no problem once the coffee is brewed...why is the water leaking???
chances are, you're filling the machine up with too much water. look at the water resivoir and see if there's a hole somewhere toward the top or a marking indicating the water limit.
-Bam-
Grape Jelly
May 06, 2011 | Hamilton Beach BrewStation 47214 Coffee...
Why am i getting a pour water error message on my coffee maker
Found the answer in an Amazon review. Place a small bamboo stick in the water sensor located in the resevoir. The ERR code disappears and you can brew as normal. If you leave the stick in, measure water carefully as there is no auto shutoff.
Apr 02, 2011 | Hamilton Beach BrewStation 47214 Coffee...
Leaking Coffeepot
I have the same leaking problem. I just called Hamilton Beach and gave them the model and serial numbers. They are sending me a new "gasket" complimentary but she said if that doesn't work, I'll have to order a whole new coffee tank.
Jan 13, 2009 | Hamilton Beach BrewStation 47214 Coffee...
Stops brewing before all water empties from reservoir
I went to Hamilton Beach site and read the troubleshooting. I followed there cleaning instructions and reduced grind time on my coffee and the machine is working perfectly again. I stressed over this problem for a long time before following their operating instructions. Have had the machine for over two years now and it's back to working perfectly. i.e. Run a pint of white vinegar through it. Wait 30 minutes and run another full vat of water....wait again and run another full vat of water. If you're grinding your own coffee, you may be grinding it too fine. Otherwise Hamilton Beach recommends the kind of coffee to use. Also the problem maybe too dense of a filter. This is all info I got on the H. Beach troubleshooting site. Good Luck !!! Mine is back to working great !
Jul 24, 2008 | Hamilton Beach BrewStation 47214 Coffee...
My brewStation 47214 stopped pumping water today, even though the warming element continued to get hot. A half dozen screws later I discovered a second heating element inside the coffee maker. The internal element is what heats the water and forces it into the basket. This element was burned out, religating my brewstation to the garbage. Probably last 3+ years.
Jul 11, 2008 | Hamilton Beach BrewStation 47214 Coffee...
Hamilton Beach 48465 12-Cup Coffee Maker Logo
147 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
jason
80stech
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
