Light print on scx4100, toner is full but the print is very light
  • tim dunmyer Oct 22, 2008
    The page had been very light, as if the toner was out. I've filled the cartridge and even stirred it up to make sure it was flowing. I just ran a system data list and it printed dark like it should and sent another test page and it printed fine.
    Just tried a page from excel and it did fine also.
    The toner saver was off, so I don't know why it was so light, until now.
  • jason Feldman May 11, 2010
    did you check to see if somehow the econo mode got turned on? it is usually under the print options
    Problem Solver:
  • 9 Answers
So the problem has corrected Itself?
Posted on Oct 22, 2008
Lexmark E260dn toner light is still on after changing the toner cartridge
Toner light is ON, I would assume that the light is solid and not blinking. You can press and release to clear the light sequence and continue processing the print job. With the printer turned off, remove the toner cartridge and shake it to extend its life. Check the replacement toner cartridge if it is the one suitable for your region.
If the blinking light is on Toner Low, press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, the photoconductor is almost full and should be replaced.
For further assistance, please call Lexmark Technical Support.
Apr 12, 2011 | Lexmark E260dn Laser Printer
I have an MFC Brother printer and I cant copy or print...it says waste toner full??? How do I fix this problem?
What model MFC Brother Printer do you have? The waste toner is left over toner from each print or copy that isn't used. It collects in a different spot in each printer. Usually the waste toner container is with the regular toner cartridge. The printer is able to detect when the waste toner is full by a light sensor in or near that container. Sometimes excess toner collects on the sensor itself and causes it to think the waste toner is full when it actually isn't. Try finding the waste toner container and empty it or replace it. clean the sensor that is on or near the container. it is likely a small black plastic piece that has 2 or 3 small wires coming from it. The model of printer will help to identify where the container is.
Jan 14, 2011 | Office Equipment & Supplies
Brother Printer HL 5250DN
A solid red STATUS light with a solid yellow TONER light indicates toner out...replace according to pg. 63 in the manual.
It can also indicate a cartridge position error. Take the DRUM UNIT out of the machine and re-install.
A solid red STATUS light only means:
Front cover open
Fuser cover open
Dust on drum
Too many trays
Buffer error
Print overrun
Memory full
Download full
Font full
See pg.48 ofthe manual.
Oct 02, 2009 | Sport & Outdoor - Others
Paper light is on, won't print, but it is full of
I have an HL-1440. The problem was an empty toner cartridge. Got a new one and it prints like a champ again. Good luck.
Aug 05, 2009 | Brother HL-2040 Laser Printer
Software cd missing
Here's the link for you:
http://www.samsung.com/us/support/download/supportDown.do?model_nm=SCX-4100&mType=DR&vType=L
Just choose the driver for your operating system and you should be printing in no time. :)
Dec 12, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Print page on SCX4100- streaking lines
Clearly bad toner cartridge. After long periods of time, the cleaning blade dries out. This cleaning blade works just as the wiper blades of your car. When they wear or dry out, you get streaking water lines in the windshield. Most manufacturers print an expiration date on the consumables wichi you can check before purchasing. Also try not to stock more consumables than those you plan to use within 6 months.
Nov 03, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Printing Too Light
9 times out of 10 when a copier is printing light it is NOT the toner.
when the toner is low the machine will display a message.
can you tell me how many pages this machine has done?
(hold the stop button to get a meter reading)
May 07, 2008 | Copystar CS-1510 Copier
No print in right side.
pls give me sumsung scx 4100 printer driver
Feb 04, 2008 | Samsung SCX-4100 All-In-One Laser Printer
SAMSUNG SCX 4100 PRINTING PROBLEM
I am facing the same issue, but its related to Copy (not Print).
The carriage/CCD Light in the scanner is stuck in its original position, causing a scanner error, and all I get are 3/2 vertical lines on the page. Some time I also get an empty page out.
Jan 29, 2008 | Samsung SCX-4100 All-In-One Laser Printer
56 people viewed this question
jasbo
jasbo
