Question about Microsoft Xbox 360 Console
The disk is not spinning and the band is fine
When i put a disk in it makes some strange load up noises but dosent spin the game at all but the band is ok as i have recently replaced it.
  • amypeal
    amypeal Feb 07, 2012
    it dosent matter what game i put in it just doesn't load anything not even dvd's or cd's
    Problem Solver:
  • 7 Answers
Have you checked to see if the turn for the laser is working? It won't read if the laser doesn't move. Check to make sure the teeth are good on the laser wheel and double check that it is the right position, if when you changed the belt you may have knocked something else off that is for the laser mover.
Posted on Feb 07, 2012
5 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: disc dosent spin
I just solved this problem, very simple actually. Possibly can happen when the drive WILL close, but then loud noise as it tries to spin the disc up. Open the drive up (4 little screws on the bottom) and lift the lid up. If you look on the top white magnet spinner, the bottom side of the magnet system broke off of the disc motor. It will look like a little metal ring stuck to the white spinner thing whatever it's called. I popped that off and examined it, then used some krazy glue to stick it back on the motor spindle and it's away and going now. The reason the drive will not close, is because when the little magnet first breaks off it can get misaligned then when it tries to shut it gets in the way. The MAY be the cause to the problem. I fixed this issue today with mine, hitachi drive.
Posted on Jan 11, 2008
kleeper
  • 87 Answers
SOURCE: Xbox 360 disk spins while ejecting
Don't open the tray when a game is running. Instead press the (x) button in the middle of the control then press 'Y' exit to the dashboard. This way the disk will stop spinning before you take it out.
Posted on Oct 22, 2008
repairtech99
  • 767 Answers
SOURCE: Disk won't spin
You got a bad spindle motor .
you can D.I.Y if your good at that sorta thing.
Buy a new drive and swap the old drive P.C. board into the new one , Cost 30.00- 40.00
if you have a shop doit 75.00 90.00
Posted on Jul 02, 2009
SOURCE: I moved my xbox360 while disk spinning in it,the
The users manual for the xbox 360 says to never move the console with a game inside. In doing so, you probably knocked the disc off the spindle causing it to grind against the laser and laser assembly. The ticking noise is probably from the motor that moves the laser back and forth across the disc. A spring may have come loose from the motor causing it to click as the screw occasionally slips from the guides. This should not cause a problem, however the plastic inside the motor may wear out causing the "open tray" error after some time in which case a repair will be necessary.
Posted on Oct 04, 2011
Hoover AM1100 Washing machine, wont final spin.
The noise, is it a grinding noisy like worn bearings?
put the washer on drain only - is the pump working ok, take the filter out to see if it is turning ok, does that make a strange noise?
If the pump is fine, its back to that noise, it could be be a faulty tacho on the motor ( regulates the spin speed) or motor bearings - has the motor spindle a lot of play on it?
Let me know how you get on and good look!
Nov 09, 2009 | Washing Machines
Help!!!
hi
i think that your playstation has worn out and i personally would be going onto a site like ebay and buying a new ps2, you could pick up a cheap second hand one for 50 bucks
Aug 29, 2009 | EA - Electronic Arts Rock Band
Disk won't spin
Jul 02, 2009 | Microsoft Xbox 360 Console
On the seledction menu - no option to play the game in the machin
Hi this problem is not your update follow those my instructions to see if this is your problem
Hi my name is Juan and the problem you got is with the bluray laser lens they have stopped reading games you can check this out put a cd on your ps3 and at the same time place your ear on top cover and will heard 3 clicking noises of the laser but make no noise because this clicking noise is so fine that you need to make no noise it goes click click click you will hear it but make sure you put your ear on top cover at the same time you insert the disk it takes about 3 -4 seconds for the clinking noise after you have insert the cd some lasers they do try to read and they make the disk to spin off and on some they do make the disk to spin normally but nothing happen and the solution is to replace the laser lens I am a ebay trusted power seller and I can get you one if you want to
Mar 17, 2009 | Sony PlayStation® 3 (60 GB) Console
Playstation 3 Blu Ray drive not working
Hi my name is Juan and the problem you got is with the bluray laser lens they have stopped reading games you can check this out put a cd on your ps3 and at the same time place your ear on top cover and will heard 3 clicking noises of the laser but make no noise because this clicking noise is so fine that you need to make no noise i goes click click click you will hear it but make sure you put your ear on top cover at the same time you insert the disk it takes about 3 -4 seconds for the clinking noise after you have insert the cd some lasers they do try to read and they make the disk to spin off and on some they do make the disk to spin normally but nothing happen and the solution is to replace the laser lens I am a ebay trusted power seller and I can get you one if you want to
Mar 16, 2009 | Sony PlayStation 3 40GB System
My ps3 will not read my game nor dvd
Hi my name is Juan and the problem you got is with the bluray laser lens they have stoped reading games you can check this out put a cd on your ps3 and at the same time place your ear on top cover and will heard 3 cliking noises of the laser but make no noise because this cliking noise is so fine that you need to make no noise i goes clik clik clik you will hear it but make sure you put your ear on top cover at the same time you insert the disk it takes about 3 -4 seconds for the cliking noise after you have inserd the cd some lasers they do try to read and they make the disk to spin off and on some they do make the disk to spin normally but nothing happend and the solution is to replace the laser lens I am a ebay thrusted power seller and I can get you one if you want to
Mar 15, 2009 | Sony Playstation 3 (PS3) Console
My playstation 3 wnt read games is there anything i can do to fix
Mar 15, 2009 | Sony PlayStation® 3 (60 GB) Console
Da disk dosent spin
I suggest checking on another disk, if not disk works then it is your console.  Most likely if it is your console you will need to take it into a tech guy to get some pieces replaced.  This might cost more then the console however.
Dec 03, 2008 | Sony PlayStation 2 (PS2) Console
Not loading game
the reason it makes the "grinding" noise is because the motor that moves the lens to read the disk is dieing, this generally happens when you have played your ps2 for a long time, this only happens to older consoles.
Nov 01, 2007 | Sony PlayStation 2 (PS2) Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
