Question about Frigidaire Freezers
Kenmore Manual defrost freezer model # 20328 stopped working.
It does not run right now. Is it worth having a tech come and check it out or is there something I can check to see if it is fixable? It's about 20 years old. Tech visit would cost about $56 and wonder if it's better to jsut put that towards new freezer? Thanks
thebartman58
  • 4 Answers
SOURCE: my freezer
is there a temp control on this unit ?if so check the setting .if not and it is on and running but not cooling ,you have a bigger problem ,freon leak or other ,good luck
Posted on Nov 29, 2007
Master_Tech
  • 770 Answers
SOURCE: Compressor Stops on Kenmore Chest Freezer
The thermostat needs to be replaced part # 216230400 it is $59.51 at www.sears.com (parts) or it is $52.45 at www.apdepot.com this will fix ya.... both will ship direct to you. If you have to leave you can unplug unit and jumper out the thermostat 2 wires plug back in. This will make the unit run 24/7 until you get the part but it is better than losing the food
Posted on Feb 12, 2008
aborcass
  • 2651 Answers
SOURCE: Frigidaire Freezer Model FFU20F9FW1 defrost problems
you say when you advance the defrost timer , id assume turn it ever so slightly the machine kicks on ad begins to freeze again?? then prior to advancing timer i would expect the unit to be totally dead(stuck in defrost mode).no fans,compressor or anything. that suonds like a bad timer or chck the wires going into the timer
Posted on Mar 05, 2008
22yooper
  • 828 Answers
SOURCE: Freezer won't run
There is no reset switch. There is a thermal overload protector mounted on the compressor. Does the compressor hum and then give a click sound. If so your compressor has failed. If the compressor is cold (Room Temperature) and it does not try to run your thermostat may be bad. If so remove the temperature control and jumper the two main wires that connect to the control. Unit should be unplugged to do this operation. Insulated the wires so they do not contact any metal surface. Plug the freezer back in. If it runs and cools replace the thermostat.
Posted on Jul 06, 2008
jcpark50
  • 52 Answers
SOURCE: freezer won't start after defrost cycle
It might be the timer motor, if it doesn't run. neither does the timer. Easily replaceable and cheap. good luck. John
Posted on Nov 07, 2008
Old Kenmore frostless upright freezer 19.6 cu ft. Model 38202. It is running but not freezing. Is it worth a service call?
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Check cold control (thats where you turn it colder)
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME If this was helpful
Jul 31, 2011 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Need manuel for a Kenmore frostless quick freezer model #253.9280410
I don't have a manual but these are fairly simple. On the back inside below is a defrost heater and terminator sorta like this:themobilian_747.jpg
The cold control maintains the temp and their is a timer that either puts it in run for 10 hours or defrost for 21 minutesthemobilian_748.jpgThe compressor relay goes out on these. The defrost heater or defrost heater termination themostat can cause defrost failure if bad.Not much to these babys.
Jan 07, 2011 | Kenmore Freezer 11.6 cu. ft. Upright...
My upright freezer model number 20328 is not getting cold what can I do?
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 07, 2010 | Kenmore Freezers
Defroster get red hot
Kenmore Frostless Upright freezer model# 23971. The alarm sounded, all contents in freezer is frozen solid. We turned the alarm off, but the red light continues to blink. How do you reset the alarm and stop the red light from flashing? It has been 3 days now and every time we have check to see if the contents has started to defrost, there is no signs of defrosting, everything inside of the freezer remains frozen solid.
Sep 01, 2010 | Kenmore Freezer 20.6 cu. ft. Manual...
Freezer is on and just stopped working
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 16, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Kenmore Freezer Model 253.26732104 Compressor
the defrost timer may need reseting. when the defrost is on, it cuts power to the compressor so they don't run at the same time. it's usually behind the bottom front grate on the right side. also check the main circuit board. there's a fuse on it.
Jul 31, 2009 | Kenmore Freezers
Kenmore model No. 253 11312100
Hi, No this freezer is not a self defrosting model. If it is defrosting while the compressor is running, you have a major problem.
If the compressor is not running, check the outlet for 120V and then check the thermostat to see if it is in the on position. If the control is on but the compressor os not running, check it for continuity. It must show closed while in the on position.
I hope this helps. Please let me know if I can assist you further.
Vic
Jun 19, 2009 | Kenmore Freezers
Kenmore Upright Freezer Alarm
I think problem its not with thetmostat but the compresor work but not correctly not have enought power to create pressure.
May 12, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore upright - wont defrost, runs continuously and wont freeze properly
well don't be surprised, these electronic fridges run on dc electronics also and are sensitive to power surges. is this the freezer because there's no thermostats just the limit control. use a surge protector on the outlet to protect the electronics. if your still having problems get the limit sensors changed first (if applicable). if you want to go the safe way, I'd consider buying a surge protector and connecting it to the power.you can e-mail me with any questions @ hvac.tech7872pr@gmail.com
Jun 14, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
109 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
