Question about Lakewood Oil-Filled Electric Radiator Heater
Lakewood heater got so hot - thermostat dial melted and fell off
Our Lakewood Oil-Filled Electric Radiator Heater got soooo hot last night that the thermostat dial/control melted right off the heater. If I hadn't seen the dial on the floor (when I woke up for one of my many bathroom trips, we could have burned to death if it had caught on fire! Freaked me out so bad, then just made me mad. We have gotten good service from this heater, until now. Is this something that happens often with a Lakewood (or other similar heaters)? Thank you!
KSD301
Try Grainger - snap disc controls.
Also, see my post, in response to "The heater does not work when switched on I have", under this same topic, 'Problem with: Lakewood Oil-Filled Electric Radiator Heater'.
Nov 07, 2012 | Lakewood Oil-Filled Electric Radiator...
My Lakewood heater turns on but will not produce heat. Any ideas as to what is wrong????
Same symptom on my oil-filled Lakewood model 5500. Used an ohmmeter to check it out and found that 1) the thermostat is defective and potentially a fire hazard due to intermittent operation. 2) Then I learned of reports about some Lakewood oil-filled heaters squirting hot oil and injuring people, and 3) the manufacturer subsequently going out of business. Three strikes and you're out.
I cut off my heater's power cord and threw the whole thing away, and recommend others to do the same.
Feb 07, 2011 | Lakewood Oil-Filled Electric Radiator...
Can I replace the element in a Lakewood Oil-Filled Electric Radiator Heater?
Sorry... but they are not replaceable....
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Feb 02, 2011 | Lakewood Oil-Filled Electric Radiator...
Lakewood oil filled radiator heater repacement switch
Here is a tip about space heaters that will also help you...
heatman101
Jan 26, 2011 | Lakewood Oil-Filled Electric Radiator...
My lakewood oil-filled radiator heater has a smell of oil? or something. What is it and is it dangerous. Could it be electrical?
The heater is filled with oil and it is leaking....you will need to dispose of it and buy a new one... it is not repairable...
heatman101
Jan 04, 2011 | Lakewood Oil-Filled Electric Radiator...
Lakewood heater model 6500 the top high low knob melted and started smoking. i immeadiately removed it andsaw the melted plastic.the unit seemsto still work fine. is it safe to use?
you can still use this heater, but continue to monitor its operation. If it gets hot enough to start smoking again, discontinue use and purchase a new one. Your safety means EVERYTHING!!!!!!
Nov 27, 2010 | Lakewood Oil-Filled Electric Radiator...
My lakewood electric heater plug gets hot and starts melting, I have to use a three prong adapter to plug this in..can u help?
Sounds like heat element is defective drawing too much current. Make sure you are not using an extension cord on this heater, it has to be plugged directly into wall socket. Post model number on here so we know what unit we are dealing with.
Oct 09, 2009 | Lakewood Oil-Filled Electric Radiator...
Lakewood Oil-Filled Electric Radiator Heater Logo
153 people viewed this question
Top Lakewood Heating & Cooling Experts
jay kaye
jay kaye
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
