Panasonic vcr FJ630
Dear Ashburton,
It appears problem lies with clock circuit since clock cannot be set. Possibly one of the two crystals on pc board?
Regards, Leon
  • leonvd Oct 24, 2008
    Dear Ashburton,
    Any idea where I can offload a circuit diagram for the Panasonic FJ630 VCR?
    Regards, Leon
  • 417 Answers
That is a possibility.
Posted on Oct 23, 2008
Why does it shut down in VCR mode?
it possibly could be . most things that have batteries need then to work correctly .
Dec 30, 2015 | Panasonic PV-L858 Camcorder
Once the VCR is turned on, it turns itself off.
If there is a mechanism fault on the VCR then the VCR will shut itself down. It sounds like the mechanism might be jammed, it's trying to move to the right position, when power is applied but can't so it stops. One thing that might be wrong is the mode switch might be faulty. This will cause all sorts of thing to happen, including putting on the timer record light even when none has been set.
Feb 16, 2014 | Panasonic PV-V4523S VHS VCR
Panasonic =iv NV-MV40 , how to set the clock please
You can download the user manual for free from the Panasonic website.
Apr 03, 2011 | Televison & Video
This is stupid but I lost my manual and can't figure out how to change the time on my Philips DVP3050v
I assume you wish to set the VCR (model DVP3050) clock. This is easy, just follow these instructions:
  1. Press VCR, then press DISC/VCR MENU so MENU appears. If the clock has never been set, the CLOCK SET menu may appear when you press DISC/VCR MENU. If so, follow the instructions from step 3 on this page.
  2. Press \/ or /\ to select CLOCK SET.Then, press >.
  3. While the MONTH space is flashing, press \/ or /\ until the month appears.Then, press >.
  4. While the DAY space is flashing, press \/ or /\ until the day appears.Then, press >.
  5. While the YEAR space is flashing, press \/ or /\ until the year appears.Then, press >. The day of the week will appear automatically.
  6. While the HOUR space is flashing, press \/ or /\ until the hour appears.Then, press >.
  7. While the MINUTE space is flashing, press \/ or /\ until the minute appears.Then, press >.
  8. While the AM or PM space is flashing, press \/ or /\ to point to AM or PM. Your selection will flash on the screen in the AM/PM space.
  9. Press CLEAR/RESET or > to start the clock.
And you can now have an online manual, click here. (Adobe pdf required) Directions on page 22.
Lots more Info
Nov 07, 2010 | Philips DVP3050V/37
The LP on my Panasonic NV FJ-630 VCR doesnt show a
I know of four places that deal in Panasonic parts and they are all on-line!
Number one is Grandata, 2 is Willow Vale, 3 is CPC.
The fourth one I have just checked on and they have the upper cylinder unit in stock at £47.99 plus P&P!
And they are Curry's Partmaster.
You might want to try the others just in case they do it cheaper, but I find that Panasonic heads tend to be all around that sort of price.
May 08, 2010 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
I HAVE A PANASONIC VCR ITR WORKS FINE, BUT THE
If you go into the menu you should see clock setting,there will be manual or auto,set to auto and the clock will set its self,even if the vcr is turned off.
Oct 09, 2009 | Panasonic DMR-E75V DVD Player/VCR
Zenith XBV443 DVD Player / VCR Combo - Set Clock Manualy
I have the Zenith xbv613 model DVD/VCR player and also need to change the clock set up. For the xbv613 I had to switch the player to VCR. The menu button did not bring the clock set up in DVD. When I switched to VCR and hit the menu button the clock set up showed, where I used to right arrow button to change the time. Hope this helps.
Sep 24, 2008 | Zenith XBV443 DVD Player/VCR
Nv fj630 can't power up
Had the same problem with my one. After a lot of time spent testing etc and finding no low volts of any value present and looking on the web, I found that Panasonic tend to use a similar design of power supply for a lot of models and there appears to be, after a number of years in use, a weak link in the design/use with the voltage regulator. For this model, the regulator generic part number is STRG 6352 and the Panasonic part no is C5HACZZ00002. In the UK it is available from:-
http:/www.chsinteractive.co.uk/electrical-components/misc/nvfj620b-c5haczz00002-ic-pana.htm
If you need a service manual for this model, which is helpful for checking things/disasembly/assembly, you can obtain a free one from:-
http://www.reptips.dk/Reptips/NV-FJ620.pdf
As a note the panasonic replacement from chs came with the pins bent correctly, so it fitted directly after I had cut the old one out.
Best of luck!
Aug 31, 2008 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Setting clock on video player
Do you still have the remote for this unit?
Apr 24, 2008 | Televison & Video
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
