Question about Sabrent ECS-U35S USB 2.0 External Drive Case
It does't work if i use windows7
Problem with ASUS P5QC Motherboard, cannot detect any usb device (hard discs). The lights on the devices show that there is power, but Windows 7 cannot 'see' them. Keyboard, mouse and usb stic
If same usb port work with other devices then suggest to check the disk management first then device manager. If it is not listed in disk management or you are not able to access it then open device manger and check under disk drives. If it is not listed in device manger then I suggest to test the external harddisk on another PC. If that also fails then you either have a bad hard disk.
Ref: http://pcsupport.about.com/od/windows7/ht/disk-management-windows-7.htm
Ref: http://pcsupport.about.com/od/windows7/f/open-device-manager-windows-7.htm
Dec 23, 2012 | ASUS P5QC Motherboard - Intel P45, Socket...
Xante cl30 printer drivers for windows7 32bit & 64bit
go to www.xante.com -->support -->drivers & docs -->legacy products -->cl30
Aug 20, 2012 | Xante CL30 HSE Laser Printer
Trying to install Bible Navigator, using windows 7 and it won't load corrrectly. Is it compatible with Windows 7?
have you tried to install it thru the add & remove program in the control panel?
if you have & it didn't work -- try this---
go to my computer
go to the drive it's in
right click on the drive
click on explore
look for a setup or install icon & click on it & see if it will install that way
I had to install windows7 upgrade this way on my laptop
good luck
Sep 11, 2011 | Csdc Bible Navigator - Lifeway Christian...
My a4tech pk-635M is not working with windows7 operating system, how can I fix this problem.
Have you installed the driver for the device yet? If not, go to this page & click on "Driver for PC" & follow the installation instructions.
If you've already done this before, just uninstall the current driver installation, re-download the file and reinstall it. If the issue persists, try a different USB port and as a last resort, test the camera on a different computer.
This device should have no problems working with Windows 7 unless there's something wrong with it.
Aug 13, 2011 | A4tech PK-635 Webcam
E studio 161 does not work with windows 7 please help I have driver of windows xp
Toshiba e-studio 161 drivers are available Toshiba Official Support
Click 'Support & Drivers' (Top Right Corner)
From the page that appear Choose B/W Copiers
then Choose e-Studio 161
Select the drivers and download for your Operating System (i.e. Windows 7)
Also, Below is the direct download link for Windows 7 Drivers
E-studio Drivers for Windows7 (32Bit)
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 28, 2011 | Toshiba e-Studio 161 Copier Copier
Sabrent ECS-U35S USB 2.0 External Drive Case Logo
26 people viewed this question
Top Sabrent Computers & Internet Experts
isaac johny
isaac johny
WTF Chuck.....
WTF Chuck.....
Martin Murray
Are you a Sabrent Computer and Internet Expert? Answer questions, earn points and help others
