Question about Sonata Boating
Mercury outboard 90 hp no spark - Sonata Boating
captainjeffq
  • 52 Answers
SOURCE: need oil change in water
If its a 2 stroke, there is no oil to change, if its a 4 stroke, you can pump the oil out with a small diameter tube pump.Depending on the motor, you can get it through the dipstick or the fill opening. If you need to change the gear oil, there is no way to change it while in the water. Stop by a marine supply store and get some oil absorbsion pads (diapers) in case you happen to spill any oil into the water
Posted on Apr 14, 2009
  • 187 Answers
SOURCE: 1994 40 hp mercury force outboard with no spark
If the fuel was not treated with a fuel stabilizer than you probably have a varnish build up in the carburetor. This varnish will clog fuel needle valves and jets. You need to disassemble the carb to clean the jets and needle valves. Sometimes cleaner is not enough you need to us compressed air to blow out the jets. Good luck.
Posted on May 13, 2009
SOURCE: 9.8 hp mercury outboard shutting off in low idle speed.
My problem ended up being the spring on the reed valve being weak.But at the same time and while I had already had my carb broke down I took a can of carb cleaner to it and cleaned it. In order to replace the spring on reed valve you will have to buy a new one, but don't worry I only payed about $6.00 for mine. You may also look into replacing your primer bulb if you haven't already because may allowing air to build up in your gas line while you are basically idiling.Once you get the carb straightened out you may have to reajust it again. If I might be able to help you again you may contact me at j_speaks@yahoo.com.
Posted on Jun 16, 2009
  • 5501 Answers
SOURCE: mercury 90 outboard transmission slipping
Check your prop hub. The rubber isolator is probably bad.
Posted on Jul 06, 2009
bytestream
  • 70 Answers
SOURCE: my mercury 9.8 hp 110 starts but only stays running at half choke
Sounds like it needs a fuel pump kit, and possibly also a carby kit.
take photos as you are pulling the fuel pump or carby apart, or get a service manual for the outboard. The dealer might photocopy the pages you need if you ask nicely.
Posted on Jul 25, 2009
Electric diagram mercury 90hp outboard 1987
Kevin,
Here you go. This is for the 90-115-140 hp models 1980 (ser# 5594657) and up years.
maxrules.com/oldmercs/Wiring/1966ona/37.pdf
Hope this helps get you back on the water. Happy boating.
Fred-
Sep 26, 2016 | Electric Boating
1985 mercury 150 hp outboard V6 black-max.Where can I get a free service manual. I really only need the wiring diagrams. 1985 mercury 150 hp V6
go google and type in--- mercury outboard motor manuals --and there are pages of download manuals
if there is not one for your engine then alter the url question to --manual for mercury outboard engine 150hp v6--and see what comes up.
Sep 22, 2015 | Boating
How can I get an owners manual for an outboard motor
call your nearest Mercury dealer and ask him to order one
Sep 13, 2014 | Boating
Why won't my mercury optimax 150 outboard start?
your owners manual should tell you what the beep code means.or call a dealer and ask them.
Jun 08, 2014 | Boating
Free Mercury Outboard ONLY, 2-40HP 1965-1989 Repair Manual 1-2 Cylinder, 2 Stroke
I have a problem with my 2 stroke 20hp mercury 1989,when I run 10-90% throttle it's works fine but when in 100% its only runs in 90% and doesn't sound normal like it's not burning right.
May 11, 2012 | Seloc Mercury Outboard Engine Repair...
2stroke 8 HP mercury outboard,newish engine no spark
Clean or change the Spark Cables>
to cleab the pull them out and with antirust spray and clean
May 06, 2010 | 2009 Mercury Mariner Hybrid
I have a 1990 90 HP mercury outboard. It is rough idling and surg
I have a 90 hp force ob. when i run it with the ears she runs fine lets me bring the throttle all the way up. when i but it in the water thru the wake area i can do 4 mph once i'am out of the wake area and give it the gas she dies, any ideas
Apr 20, 2010 | Raymarine Linear Feedback Unit For...
Boating Logo
445 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
