Ineed to know what error code 03-360 on a xerox workcentre 5790
  • 2072 Answers
SOURCE: xerox 390 error code 1
> Support & Drivers > WorkCentre 390 Laser All-in-One Support > Search Results > How To Clear a Fuser Error Message Solution: Perform a RAM Clear bttn_print.gifMake Printable bttn_email.gifEmail this page elem_1_spacer.gif Performing a RAM Clear will restore all of the WorkCentre's settings to the factory defaults. It will also clear all faxes in memory, Speed Dials, One-Touch Buttons, Group Speed Dials, your System ID, and any other stored information.
NOTE: If you are able to print, it is a good idea to print out your Phone Book before performing the RAM Clear, to assist you in reprogramming your Speed Dials and One-Touch Buttons. It is also recommended to print out your System Data List to assist you in reprogramming your system settings. If you are not sure how to print your Phone Book or System Data List, refer to Related Items at the bottom of this page.
To perform a RAM Clear:
  1. Press the [Menu] button on the Control Panel.
  2. Press the [#] key, then press 1934.
  3. NOTE: These buttons should be pressed quickly. If not successful, try varying the speed you are pressing the buttons.
  4. When this step is successful, the bottom right-hand corner of the LCD Display will read 'TECH'.
  5. NOTE: If you are unable to access Tech Mode, please refer to Related Items at the bottom of this page.
  6. Press the [Menu] button to start navigating the menu.
  7. Press the [Up] or [Down] arrow button until the LCD Display reads 'Memory Clear', then press [Select] button.
  8. The LCD Display will read 'US and Canada'.
  9. Press the [Start] button to clear memory.
Posted on Jan 19, 2008
  • 2072 Answers
SOURCE: LSU Error
I will simply send you what the documentation states ok?
Either a laser main board or loose connection to either.
  1. Check the wiring between the LSU and CN5 on the Main PWB.
    1. Install new components as necessary:
    2. LSU, PL 6.10 Item 1.
    • Main PWB, PL 1.10 Item
  • Posted on May 26, 2008
    • 2072 Answers
    SOURCE: workcentre c2424 is showing system error 39,003.40:117010
    That is a document feed or scanner fault. Often times it is simply that molex connector working loose. It is the connector mounted vertically next to the main power cord on the right rear side of the machine. That bottom screw can be dificult to tighten. What I would try first is to shut the machine off, unscrew and disconnect that conntecot totally then firmly slide it in and get both the top and bottom screwss tight. Like I said, the bottom thumb screw can be hard to tighten even with a screw driver because it is a pretty soft rubber the tighteners are made out of.
    If that doesnt work. go to the back and disconnect the document feed to scanner cables and reconnect. Other than that, you pretty much have to replace the feeder/scaner assembly since very very few parts are spared for that .
    Posted on Oct 23, 2008
    • 239 Answers
    SOURCE: CA1 error code on my xerox workcentre 416
    I hope this messege come through.
    This is a call for a Xerox service rep to visit the machine.
    First you need to know if it has the latest software on the machine. If it has old software, and a new laser is installed, the error code will come back again.
    You will need to have the right model for this machine and the right main board to match it.
    Best to place a service call and let Xerox handle it.
    Posted on Oct 17, 2009
    indus3
    • 212 Answers
    SOURCE: xerox workcentre pro 5225 exrror code 026-714
    the Xerox error code 026-714 means that the printer cannot access a remote proxy-server. if the printer has been configured to use this remote proxy instead of your local one (or none at all), none of the mentioned network functionalities will work supposedly.
    Posted on Apr 20, 2010
    Xerox workcentre 6015 ni error code 092-651
    Printer CM205 b error code 092-651
    Options My printer FUJI XEROX CM205b is showing an error code of 092-651 with a sub code of 2080000. I have no idea what this means or how to go about fixing it. this has been a great printer and would like to fix it if possible.
    Thank you for the help.
    Apr 12, 2014 | Xerox WORKCENTRE 6015/Ni Color
    Xerox workcentre 5765 paper jam message but no paper is jammed
    Check all the paper detecting sensors once more, may be there is something over the sensor.clean all the sensors with VIDEO 90. if after that problem persist please restart the machine and go for software and firmware upgrades.
    GOD BLESS YOU
    Oct 20, 2012 | Xerox WorkCentre 5765 5775 5790 Fuser...
    Error code 39,003,40;61256 on a xerox workcentre
    Here is the easy solution to fix the issue :
    Click on the link and follow instructions to fix the issue.
    http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
    Dec 02, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
    Error 016-311 xerox workcentre M128
    This error code means the Scanner is not installed. The reason for this code could be a bad or diconnected interface cable, or corrupt system software. Check the cables for connectivity. If the problem persists, it will probably require a call to Xerox service. 800-821-2797
    Nov 08, 2009 | Xerox WorkCentre M128 Copier
    H2 Blinking on the panel
    Error code means that:
    H2 Thermistor Open
    Part #
    Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
    Mfr Part #: RDTCT0128FCZZ
    Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
    139 people viewed this question
    jasbo
    jasbo
