Unable to add more match RAM using secondary slots
I currently am running with 4gb(2x2gb) sticks of GSkill RAM mentioned above in the Primary DIMM slots, when I try to add 2 more match sticks into the secondary, I get nothing. System powers on, but nothing. Tried resetting bios and clearing cmos, still to no avail. If I place one stick in Primary one and one stick in Secondary two, it'll start up, but try to add all four sticks and nothing. Any ideas or suggestions??
  • 807 Answers
You need the motherboard manual to make sure it can take more.
It may only accept 4 gig. For example: 2 x 2 gig strips or 4 x 1 gig strips.Or you may need to use single sided ram boards, chips on only one side. I know some motherboards do.
Posted on Feb 08, 2012
SOURCE: Secondary IDE not working
i have same problem with my intel d845gvsr and dont know how to fix it device manager shows secondry ide channel working properly but bios dosent detect any thing attached to it
Posted on Jan 08, 2008
  • 3 Answers
SOURCE: Secondary Video
You have to go into the CMOS to turn off the motherboard Video
Posted on Jan 14, 2009
indus3
  • 212 Answers
SOURCE: Primary ide slave no detedted secondary ide
you need to verify the jumper settings on the devices that are connected through the IDE flat cable.
picture: http://support.euro.dell.com/support/edocs/storage/P120718/drijump01.gif
set the jumpers in such a way, that on one flat cable there is both a master device and a slave device. if you're not sure what to choose as master, you can use the CS (cable select) setting on both devices to let the system board choose which one will be master and which on will be slave.
keep us posted on any evolution if you will...
Posted on Jun 22, 2009
Lord_Necron
  • 15 Answers
SOURCE: SATA device not found
Go into the BIOS and switch you SATA drives to IDE mode.
Posted on Aug 18, 2009
Testimonial: "Thanks for the tip. The Primary and Secondary SATA devices were already IDE."
  • 468 Answers
SOURCE: primary IDE port does not work. My main hard disk
It is Biostar http://www.biostar-usa.com
Posted on Oct 12, 2009
Laptop currently has three 4GB RAM sticks, is it possible to use another 8GB stick to upgrade it to 20GB?
It should. But RAM slots have a maximum RAM per slot. Have you checked with manufacturer manual to see what the max ram per slot is? And the max ram per motherboard matters too. Your mobo will only support so much ram.
Dec 07, 2012 | MSI Gt70 0nc-051us
What's your problem?bit ix38 quad gt motherboard with 2 gig of ddr2 ram i want to add a 1 gig stick of more ram that ive bought how do i do this? thanks windows seven
Top view of motherboard, scroll down. (Thought you might also like to read the reviews, and Comments)
http://www.bit-tech.net/hardware/motherboards/2007/12/06/abit_ix38_quadgt/2
Motherboard User Manual,
http://www.theraptorpit.com/forum/index.php?/forum/124-abit-motherboard-tech-support-unofficial/
1) On the motherboard the Blue ram memory slot that is closest to the copper heatsink, is ram memory Slot 1.
Also known as DIMM 1.
Ram memory ALWAYS has to be in this ram memory slot.
The Processor reads ram memory Slot 1 first.
2) The Blue ram memory slots are Slot 1 (DIMM 1), and Slot 3.
(DIMM 3)
The Black ram memory slots are Slot 2 (DIMM 2), and Slot 4.
(DIMM 4)
To run Dual Channel ram memory, means there are two LIKE ram memory modules ('Stick'), and they are installed in the SAME channel.
This would mean to alike ram memory modules, in both Blue ram memory slots, or both Black ram memory slots.
Since the ram memory modules need to be alike, they are generally purchased from the same manufacturer, and are the same kind.
Running ram memory in a dual channel configuration, is supposed to increase ram memory 'speed', up to 30 percent.
This is Baloney!
May look good on paper, but in actual use in the field it's cr@p.
Actual performance increase is more like 1 to 2 percent.
This has been proven by Tom's Hardware, and many, many motherboards, ram memory, Processors, etc.
So you have 2GB of DDR2 Sdram, huh?
Is it just one 'stick' of ram memory, or are you referring to two 1GB sticks?
If the above holds true install them in Slot 1 and Slot 3.
If not, and it is a 2GB stick of ram memory, be sure it is installed in Slot 1 (DIMM 1)
Install the 1GB stick in Slot 2.
It isn't the same as the 2GB stick.
It is 1GB.
Does NOT go in a dual channel configuration.
(Catching all this? There is NO dual channel ram memory!
It is ram memory that is -> ALIKE, and used in a -> dual channel configuration.
Used in two separate ram memory slots, that support the dual channel configuration.
Sold with the advertising scheme of 'Dual Channel', but really just means the two ram memory modules, (Or four), are -> alike.
1) Same Voltage used
2) Same Ram Timings
3) Same Chip Configuration
4) Same size in amount
5) Same frequency rate ('Speed')
With ram memory in a dual channel configuration, the ram memory modules team up on the task.)
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 31, 2012 | Computers & Internet
Can't install kvr800d2n6/2g x 4 on aw9d max
What you have purchased is Kingston VALUE RAM. It is budget-priced RAM for generic use. It works well in most cases. I was unable to find an actual 4x3 GB "Kit" on the Kingston site, although I found 2x2 Kits. The problem here may be in matching. The specs for RAM are fairly stringent, but they have variances, and the cheaper RAM is more likely to have such variances. I would try first installing each stick separately in the primary slot and confirming that each is detected. Next place one stick in DIMM 1 and one DIMM 3 slots. This puts one stick in each channel. Each channel operates independently so matching is not an issue. If that works, try adding one stick to one channel or the other. If it fails, swap it to the other channel. The idea is to try to get the sticks matched up as best as possible. Hopefully you will find a happy match-up. Also, check the memory voltage. These sticks operate at a standard 1.8V, but having four installed could be loading down the power supply some and you may need to manually bump the voltage up a tenth or two. Don't go over 2.0V though.
Jan 29, 2012 | Abit AW9D-MAX Motherboard
I want to upgrade my RAM on my eMachine t3504. I currently have 256 in each of my 2 slots. Can I upgrade one of the slots to 1 GB and leave the 2nd at 256 or do I have to upgrade both slots?
Yes you can upgrade 1 of the slots to 1GB, as long as 1GB stick of memory is the 256MB stick then you can have both, to check the memory you will have pull them out of the slots and have a look on a little sticker on one side of them. You are looking for i.e DDR400/333/266 if the 1GIG memory matches one of the values mentioned above, say it is a DDR400 and the 256 is a DDR400 then they are compatable if not you will have to just leave the 1GIG stick in by it self in DIMM socket 1.
Apr 03, 2010 | E-Machines T3504 PC Desktop
I am using this ASUS (asus M2N-MX nvidia mcp61p chipset
According to the manufacturer's web-site:
http://usa.asus.com/product.aspx?P_ID=0pKBwEIE8tqMT4j7
this motherboard has 4 x DIMM sockets,
supporting a maximum of 4 GB
of DDR2 800/667/533/ Non-ECC, Un-buffered Memory
and supports Dual Channel memory architecture.
So, add one 512MB DDR2 533 Mhz RAM into one of the slots,
being sure to leave *ONE* *EMPTY* slot between the two sticks,
in order to enable the high-performance "dual-channel" option.
Try your computer -- it should feel faster.
If you still think that need more RAM, buy two 512MB (or two 1024MB) DDR2 533 Mhz RAM, putting the 2 sticks into the two empty slots.
Dec 26, 2009 | ASUS M2N-MX Motherboard
Memory
Ok well there could be a few things going on here. It is possible that A: your third stick is damaged which I'm assuming you dismissed through your installation of one at a time, B: the third dimm slot is damaged and is unusable, C: the dimm slot is turned off in your bios.
Now looking at the Shuttle A161 motherboard it would appear you have a primary dimm slot and then expansion dimm slots (technically these are called the controller dimm slot and the estensions)
The controller slot which is offeset from the other two should have your largest ram, make sure the ram you stick in this slot isn't a stick that requires dual recognition. Some ram is designed to work in a pair even in the early PC100 class ram. Most PC100 ram you'll find now requires the sticks to work in pairs and the ram is coded for this. (Especially since PC100 is on its way out very fast.) The expansion slots can be fitted with a pair that will work together. I doubt that your third and primary slot is turned off as it is the controller slot. If none of your ram works in this slot replace the old ram in to this slot and just use the two expansion slots. It may not be as much ram as you want but the motherboard has presets that are just problematic.
My general advice however is, that if you're running this motherboard which is fairly out of date, I'd upgrade to a new computer. Buying a cheap Dell desktop or even a barebones off of newegg.com and transfering your current Harddrive and what not over would probably be easier for you and will carry you for the next five years or so.
Sep 12, 2008 | Shuttle Computers & Internet
8GB G.Skill F2-8500CL5D-4GBPK in Gigabyte GA-P35-DS3L rev. 2.0
If they are not a matched pair it will not work. If you have two sets of matched pairs. Each pair will have to go into the right pairing slot. Example one set you go in slots 0 and 2 and the other in slots 1 and 3. If you have stickers on the memory sticks look for a group of numbers and letters one group will match it's mate.
Apr 03, 2008 | Computers & Internet
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
