Mobile home furnace
Coleman 7900 series propane furnace cycles on and off every 2 minutes
4 Suggested Answers
  • 70 Answers
SOURCE: Coleman Presidential II mobile home
Is this furnace standing pilot or electronic ignition. If standing pilot i would check furnace filter then the thermastat. To test themostat first turn power off to furnace. Take thermostat off wall and take wires labled R & W and connect them together. If you have electronic ignition I would start with cleaning the flame sensor with steel wool or wire brush.If you have and more questions i will be glad to help.
Posted on Jan 17, 2009
  • 11 Answers
SOURCE: Furnace not cycling properly.
you might want to check the filter, if the filter is restricting the airflow the furnace will over heat and it will shut down. if you turn it off and on it will reset it and it will try again. Pull the filter out half way and try that, if it runs fine then clean the filter or get a less restrictive one.
Posted on Feb 11, 2009
  • 1015 Answers
SOURCE: my coleman 7900 furnace blower cycles on and off
I would look at fan limit switch. They are normally located in electrical cotrol compartment. If your are lucky you will have one thats adjustable. It would helpful if I knew is your home a mobile or modular home as they usually use a button type limit on fan and hi limit. It sounds to me like you may be having problems with fan limit which controls temp. that fan comes on . Often what happens is that switch scenses temp to turn on and then draws cold enough air on return air to shut back down until temp.rises again.If this occurs when unit first comes on or continues after burner shuts off you can get a limit switch with a higher temperature rating or one that has adjustable temperature range. Hope this helps you.Thanks.
Posted on Nov 06, 2010
Do I need a outside cooling unit for a Coleman 7900 Presidential lll gas heat and cooling unit
Yeah, youd have to look at the model on the Indoor coil box, furnace will be setting on top of it. Youll need the model off that coil box to get the correct tonnage of the outdoor condensing unit, you can go 1/2 ton smaller on outdoor for greater efficiency.
Feb 12, 2015 | Coleman Heating & Cooling
Coleman furnace runs a lot
You did not indicate the year or size of the mobile home, but, having lived in several in cold Michigan, here are some things.
Be sure all the windows are well sealed.
At first, I used to put a strong clear plastic sheet over the insides, and tape these in place.
Later, I bought foam insulation board at a lumber yard and cut pieces to fin the window openings, and taped them in.
When it is really cold, feel the walls, the floor, and the ceiling.
If you find cold to the touch, you are losing heat there.
If your floors are cold, put insulating panels and skirting around the bottom of the trailer.
If your extreme cold lasts for months, some people consider putting a small electric heater under the trailer that is temperature controlled.
Some people do a "roof-over" by setting poles or posts alongside the trailer and adding an additional roof above the trailer.
That step would enable you to add insulation above the top if your ceiling is cold.
God bless your efforts.
Oct 27, 2017 | Coleman Propane Forced Air Heater...
What color should the flame be on a coleman
hi the gas goes along aburner tube then comes out of the burner then it hits a baffle in side the heat exchanger as long as there is not sooting the flame will look yellow , i would say the best thing would be to contact the makers of the furnace direct they should have a technical department , they might be able to offer more help or have there own people to look at the heater most of these companys have a warrenty on there heaters
Jan 09, 2010 | Coleman Propane Forced Air Heater...
Feb 06, 2009 | Coleman Propane Forced Air Heater...
Need replacement glass for pilot cover of Coleman Presidential II
the glass is there as a service tool to veiw pilot and flame or relite just get a peice of sheet metal and cover hole with it ,it will work short term or long term
Feb 05, 2009 | Coleman Propane Forced Air Heater...
Coleman Presidential II mobile home furnace. When burner lights the blower cycles on and off instead of blowing constant through burner cycle.
Jan 17, 2009 | Coleman Propane Forced Air Heater...
Short cycling
There are a few reasons why your furnace is restarting after it reaches temp. and shuts off. First, if you have a mercury bulb thermostat it needs to be level and the heat anticipator needs set properly. If you have an electronic thermostat then you need to make sure the DIP switch settings inside are set properly for propane. If you have a digital thermostat there are also settings to be made for your type of heating. These settings will be explained in the thermostat installation instructions. Also, Make sure your furnace filter is clean. If this does not help then there are some other things to check which may need to be done by a technician depending on your mechanical aptitude. Hope this helps!
Dec 08, 2008 | Coleman Propane Forced Air Heater...
Pilot light is out of our coleman 7900 mobile home furnace and we can't get it re-ignited
The thermo couple or the gas valve itself is most likely bad. Cheap enough to start with the thermo couple.
Sep 04, 2008 | Coleman Heating & Cooling
Mobile home furnace
you probably have a bad thermostat if it wont shut down id replace the thermostat first and then have the thermocoupler checked...replace the thermostat
Aug 20, 2008 | Heating & Cooling
Heating & Cooling Logo
51 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
