Question about Garden
Trimmer has piercing squeal when running - Garden
    Sergeant:
  • 316 Answers
Hello frank, it is the cable or clutch making the noise,,
Posted on Feb 19, 2012
How to fix squeaking and bag full sign lit on the sebo x4 extra upright vacuum?
Check the main "kitchen roll" filter isn't clogged which is on the left hand side of the bag when the bin door is opened. There could be a clog, either behind the pick out metal grid below the filter roll, or the roll filter requires to be replaced. Can you add more info about the squeaking though? Is it a high pitched squeal all of the time or just intermittent and where it seems to be coming from - it could be excess air escaping from a pierced hose or a drive belt issue.
Oct 30, 2013 | Sebo X4 Bagged Upright Vacuum
Echo srm-210 powers up fine on a flat surface, but it cuts out after a few seconds in the upright (usable) position. I rebuilt the carb, cleaned muffler screen, good gas and fuel filter. tank lines seem...
Make sure you rebuilt the carb with a carb kit. Put a hose on each pipe coming out of the carb and blow and suck on them. One should seal completely and one should provide vacuum. If there is a leak, you need new check valves. If you rotate the trimmer and it runs poorly, you may have a pierced diaphragm.
Oct 22, 2013 | Echo Zama Carb Kit For Shc210 For Rbk66b...
Squealing
Jacob if your trimmer is squealing you may be about to break it if you dont put some oil in with the fuel. If its a small petrol trimmer you will need some two stroke oil mixed with the fuel. You need 40 parts petrol to 1 part oil.
Oct 20, 2013 | Garden
What is conch piercing?
Conch piercing is a type of ear piercing: Inner conch piercing is done at the center of the ear cartilage. Likewise outer conch piercing is done on the outer part of ear cartilage.
Feb 20, 2013 | Health & Beauty
When the tv is turned on, it has a piercing squeal sound. We need to mute it to watch. It also comes on with lines through the picture. Sometimes we can't see the picture at all.
If the squeal is heard on all av inputs and normal channels it would suggest a failure of the internal audio amplifier requiring a visit from a techie,try unpuging scarts etc to try and isolate the fault
Nov 03, 2010 | Polaroid FLM-3732 Television
High pitched squeal from Bose car stereo
Have you or your dealer tried an inline noise reducer? It worked on my truck. Worth a shot. Good luck!
Feb 02, 2010 | Car Audio & Video
High piercing squeal coming from a component on circuit board
if it is squealing most likely the horizontal output transistor is shorted and possibly the flyback transformer caused it to short.
Aug 19, 2009 | Televison & Video
The outside unit is making a squealing noise. It's every now and then; not constant. Just started today. What's wrong? The fan is running fine. The air inside is cool. Just a high piercing squeal every now...
sounds like its more than likely the fan motor. the bearings in the motor are notoriuos for making a squeeling noise. there arent any other parts that would make this noise. unless youre a special case. i doubt it. if youre mechanically inclined there are ways of checking the motor. If you have an amp meter you can check the amp draw on the fan motor. if it reads higher than on the label of the motor then the motor needs to be replaced. if the amp draw is good the you can try to drop some oil in the motors lube port.
Jun 24, 2009 | GE Quiet-Aire Ductless Split System Air...
High Squealing Sound
There is a stand up coil about 1" tall and the dia of a nickel close to the HV transformer, the iron core glue comes loose over usage. This can be cured by replacing it or using a sealer/caulk and re-seal the coil. Hope this helps, it is not an expensive job for service.
Feb 13, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Piercing sound
The high pitch squeal you hear is usually caused by a coil vibrating, normally in the horizontal circuit. I've also seen the ferrite bead on the horizontal output transistor do this, but, it is rare. I normally will repair this by finding the coil and "tightening" it. To tighten a coil, technicians use different chemicals, such as, a hot glue gun, rubber silicone or even finger nail polish. I will find the coil that screams by starting with the usual suspects and using a wooden dowel, barely touch the coil and if the pitch of the noise changes, then, thats the coil that needs repaired. If you do not know your way around the inside of a television, I never recommend you do so, since, this procedure must be done with the set turned on and you poke your hands around the inside of the set by the high voltage circuit. Hope this helps your decision.
Feb 26, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Garden Logo
100 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
