Question about Krups Small Appliances Espresso Machine
I have krups xp7245. It just happened today after 2 yrs daily use.
The Coffee is not dripping out and the coffee cakes are seem like not coming out..more..it is leaking from the bottom out of the machine...would you help please?
  • Krups Master
  • 1,238 Answers
These coffeemakers are not the easiest to work on, contact Krups and locate an authorised service agent in your area and run the fault by them, they will likely need to open it up to properly quote you. There are lots and lots of potential problems inside one of those machines. If you wish to look at yourself you are going to have to remove the top, sides and back covers. Side & back is one part. Even when you have it all exposed to not expect the fault to be immediately obvious, I have covers with cutouts so I can run it and look inside at the same time.
Posted on Mar 09, 2015
  • 17 Answers
SOURCE: Hi. I have a Krups XP7245 combination
I had the same problem with the XP7240. The rubber seal in the plunger that pushes out the coffee cake after brewing is worn or dirty. You need to romve the cover by taking of the top (screws in the bean collector and cover tray for cleaning tablet). You have to be rough because parts are clicked together. The face of the machine comes off by pulling it upwards (it is just clamped with plastic nudges). Once that is done you remove the 4 screws that were hidden by the stainless steel face. Then remove the electronic board (leave connections on except for bean grinder and boiler). Grinder can then be removed followed by the cream cover. Remove the 15mm steel nut on top of the arm. Remove the front and display. Then use a torix on top of the brew plate and an allan key on the bottom of the plunger. Unscrew, remove spring and seal (very small cup). Let me know if you need more instructions (take a rainy sunday afternoon to do this)
Posted on Aug 15, 2010
  • 79 Answers
SOURCE: FME2 Coffee Maker
From page 9 of the manual:
Setting and Adjusting the Clock
• The machine must be “off“.
• Press and hold the prog button (o) for 3 seconds: the hours will blink “88 _ _“.
• Adjust the hours in steps by pressing the h/min button (n).
• Press the prog button : the minutes will blink“ XX 88“.
• Adjust the minutes in steps by pressing the h/min button.
• Confirm the setting by pressing the prog button.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Manuals/ResultManuals.htm?SelectedService=Manuals&SelectedGuIDService={FA4AA2D9-9799-4F8F-8136-8FEB029407FD}&SelectedProdRef=FME2
Posted on Aug 28, 2008
  • 22 Answers
SOURCE: A Krups KM7005 coffee maker/grinder doesn't heat or drip water .
Mine had the same problem ... all the lights are on, grinding works fine, but no heat on the plate, and no dripping of water.
After a weekend on the workbench, I mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. To date, I have helped 13 people on this site fix this exact problem.
I'll be happy to advise you to fix this, or fix it for you. Write me at KM7005@flightsystems.biz.
Posted on Jan 31, 2010
  • 4 Answers
SOURCE: KRUPS XP7240 leaking water
My XP7240 has the same problem. I went through all cleaning cycles and the filter in the boiler still gets clogged up with coffee oils. This causes back pressure and blows the boiler seal out. Easy replacement if you can turn a screw driver.
Part number for Seal: MS-5015004. You might as well change the Jack too. (the part that slides into the boiler that compresses the ground coffee. (this is a redesigned double seal unit) Part Number MS-0697072.
Both these parts you can get at http://www.krups.com/Tools/Contact/Contact.htm choose your country and email the parts list. Mine cost in Australia $27.00 including shipping.
Good luck.
Posted on Sep 16, 2010
SOURCE: Error code 07 on my Krups XP 7220 coffee machine
Error code 07 on my Krups XP 7220 coffee machine what to do? Nick
Posted on Oct 24, 2010
How I fix if it not make coffee any more
If it's more then 4 yrs old I'd start looking 4 a new one. Nothings made to last today.
Oct 02, 2016 | Krups XP1500 Coffee Maker, Espresso Combo
XP7240 not draining properly
Replace that pressure valve and also inspect it for leaks from directly under the boiler, from that pressure valve and from the top of the hydraulic ram. If when you buy your valve you find the white housing will not fit where the old one came from you can just use the piston into your old housing. Check this before removing the hose clip from your old piston housing. If your old piston housing is leaking badly before you even do this job then you will need to replace the whole distributor as sometimes a piston housing retaining lug can fracture, there are 3 of them and they are part of the distributor.
Jan 26, 2014 | Krups Small Appliances Espresso Machine
Error 06
Look for a water leak, it may be to the base of the machine and will release out the vent UNDER the drip tray if you tilt the machine forwards. There are many places for it to leak, not easy to find, I have an outer housing with cutouts to allow me to see inside while it's running. Hydraulic ram and the distributor are the most common places to cause error 6 but there is also a tricky one where the valve on the pump releases to the drip tray. A leak is the problem, finding where/which is the hard part.
Nov 29, 2013 | Krups XP7245
I had some water problems with mij krups and try to solve it. Now it gives an error 0D. What does this mean?
I have a Krups XP7240 that came with the same error code (0d). I believe that the XP7240 and the XP7245 is pretty much identical inside. The sollution for me was that the connector to the front was loose. After pressing down on the connector, the machine worked perfectly again.
RuneBune
Feb 11, 2011 | Krups XP7245
Hi. I have a Krups XP7245 combination espresso/coffee maker that leaks when I make coffee. This is a recent problem. It's out of warranty (of course), and I'd like to disassemble it to try to resolve...
Aug 13, 2010 | Krups Small Appliances Espresso Machine
Door popped off my Krups FME4 drip coffeemaker.
Just had the same problem today so I thought I would share with you how to fix it. The spring runs up through the door that opens, pop off the silver top and the wire where it makes a L, lock it into the top and put the silver top back on. The switch on the right is only to hold the door open. Good luck.
May 06, 2010 | Krups FME4 Coffee Maker
Krups KM7005 coffeemaker/grinder does not heat or drip the water
The heating plate is actually your hot water heater for the unit and it has most likely failed. The water flows through the heating plate and heats the water for brewing. Krups replaced my whole coffee brewer.
Dec 15, 2009 | Krups Small Appliances Espresso Machine
It wont brew drip coffee
What are the simptoms? Once you pour the water and add the coffee it should start when you press the coffee button.
Jun 02, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups Espresseria Automic XP7200 coffee machine
As this is an automatic espresso machine, I suspect that the cake container is where the "used" pucks of ground coffee drop into after your espresso is extracted. The container may not be fully seated in position. See if there is a door on the machine that the container may be hiding behind.
Good Luck.
-Steve
Sep 27, 2008 | Krups XP7230 Compact Super Automatic...
Krups XP2070 coffee machine - new - espresso side - water goes straight into the drip tray & not thru the filter.
This will most likely happen when the pressure valves become defective. Replacing the two valves (they come in pairs) should fix the problem.
Aug 03, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups Small Appliances Espresso Machine Logo
314 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
