Question about DeLonghi BAR 14 Espresso Machine
How to clean bar 14
Howtoclean bar 14 coffee machine
Cleaning the calcium carbonate accumulated inside the boiler.Put only 200 ml of water in the water tank then add a 100 grams of citric acid cristals.Do not use coffee holder and open the machine and wait the heater ready lamp .Start the pump .Collect the pumpes acidic water in a cup.When the cup is filled stop the pump and recyle the water collected in the cup to water tank.Ater repeating this recycling 2 -4 times all crystals will be dissolved and the boiler will be filled with this weak acid solution.Wait the machine closed 2 hours.Then put fresh water and run the pump and remove the solution.Now your machine is free of scales inside the boiler. You will notice less noise during boiling of water inside the boiler(not pump noise).After some usage if you notice again that high noise of water boling it is time for another cleaning.
Posted on Jan 15, 2009
Clean keeps flashing even when I've cleaned
External visual cleaning is not enough.
The coffee maker needs internal cleaning.
Please descale the machine to remove the error message.
Mar 03, 2015 | Kitchenaid Coffee Maker - 14 Cup - Empire...
Poor performance
Maybe the screen is clogged with coffee oils, or the boiler needs to be descaled, or the pump is going out.
May 20, 2010 | DeLonghi BAR 14 Espresso Machine
Cleaning of saeco royal cappucino machine
The user manual shows you how to clean your machine. If you don't have it you can download it from the Saeco site:
http://www.saeco-usa.com/en/products/household-automatic-machines/1/automatic/0/royal-coffee-bar/17/royal-coffee-bar.html
Hope that helped! Thanks for using FixYa.
Apr 09, 2010 | Saeco Royal Cappuccino Espresso Machine
Delonghi bar 18 oump driven esp maker won't pump water
It may be a stupid suggestion but have you checked the strainer in the reservoir? It Could be blocked. And if you haven't removed the brew head sieve recently? It could be gunked up.
For cleaning it's best t use citric acid packets sold in stores as it hurts the metals inside the tank the least, but in a pinch you can use vinegar, although it's much more corrosive and could hurt the machine.
When using a cleaner remove the brew head sieve, as a lot of junk will collect and can block the sieve, with resulting no flow for brewing.
Hope this helps!
Jan 30, 2010 | DeLonghi BAR 14 Espresso Machine
My espresso is too watery. Any ideas?
You should add more coffee so the resistance of the running water thought it to more. The running of the coffee should be arount 20 -25 sec for 30 cc of coffee. Coffee dose of about 7-8 gr for a sinlge espresso
Dec 20, 2009 | DeLonghi BAR 14 Espresso Machine
Espresso machine will not make Espresso.
Try this remove the portafilter and press the brew button, if water comes out of head, machine is fine but the grind or the tamping(packing pressue) used on the coffee is not right. If you are grinding the coffee just before using it, try a coarser setting. If you pre grind at the store then try tamping the coffee lighter.
May 29, 2009 | DeLonghi BAR 14 Espresso Machine
RE: NEED MANUAL
Hi Visit this link and see if your machine is here. The possibility is that BAR 4 and BAR 14 could be one in the same machine:
http://www.delonghi.co.uk/pdf.php?key=Coffee%20Machines
Apr 12, 2009 | DeLonghi Cafe Sorrento Espresso Machine
Cuisinart 14-cup coffee maker won't put out coffee
Clean it out with 1/3 caraffe worht of vinegar and 2/3 caraffe full of water - just brew the solution as if it were regular coffee - you may have to repeat this process up to 3 times.
-Tha Mp3 Doctor
Dec 21, 2008 | Cuisinart DCC-2200 14-Cup Coffee Maker
Automatic dispenser
Clean it, especially the window for the barcode reader
Aug 08, 2008 | Braun Tassimo Espresso Machine/Coffee...
Expresso machine
descaling gonna improved the pressure = stronger coffee and clean the inner boiler =warmer coffee but use descaler only not vinegar descaler melt calcium vinegar remove some calcium in littlt piece 1 part descaler 1 part water fill the water container open valve for a few second close it leave it for 15 minute and repeat untill empty after rince very good that stuff is corosif
THANKS FOR USING FIXYA
FROM MONTREAL CANADA PIERRE
Feb 18, 2008 | DeLonghi BAR 14 Espresso Machine
DeLonghi BAR 14 Espresso Machine Logo
591 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
