Question about Nokia 9300 Handheld
How to restart nokia 9300 - Nokia 9300 Handheld
  • lodesthar Nov 30, 2008
    I CAN'T CONNECT TO INTERNET USING MY N9300 AS A MODEM,I WAS SUCCESSFULLY INTALLED THE DRIVER...PLS..HELP ME
  • robers_rober Mar 01, 2009
    real player ,avi files and theams
TAKE OUT THE BATTERY AND IT WILL RESTART
Posted on Nov 05, 2008
How to format of nokia 9300i
Welcome to Fixya
This process erases from your Nokia 9300 all of your user data and settings, including your phone book, calendar, email, downloads, recordings, and certain factory installed programs such as Instant Messaging and BlackBerry Connect.
REMEMBER: Create a device data backup or synchronization before formatting.
You can restore device data and settings later. See the Nokia 9300 User Guide for further instructions.
STEP 1 - Format the Nokia 9300 memory
* Remove the battery for 10 seconds
* Replace the battery
* Open the Nokia 9300 to view the inside display
* When you see the screen with "NOKIA" in blue text,
* Press and hold the following four keys until a Format Message is displayed:
CRTL + Shift + F
* Confirm the process by selecting Format
* Formatting will begin
* After formatting is complete the Nokia 9300 will reboot with some basic settings. If prompted, accept the request to reboot
* Follow the instructions on your Nokia 9300 to set the time, date and city and to enter your contact information.
STEP 2 - Download the install-cingular-default-603.SIS to a compatible PC.
STEP 3 - Prepare a Multimedia Memory Card (MMC)1
* Transfer the .sis file from your PC to your device using MMC, data cable, Bluetooth or infrared. For instructions see the Nokia 9300 User Guide.
STEP 4 - Install the file install-cingular-default-603.SIS to your Nokia 93002
Note: This step is required to install Cingular specific settings and programs to your Nokia 9300.
* Insert the Multimeda Memory Card created in Step 2 to your Nokia 9300.
* Replace the battery cover (so the Nokia 9300 can read the MMC)
* Open your device, then open the File Manager:
Press the Desk application key
Scroll to and select Office
Scroll to and open File Manager
* Using the arrow keys, scroll to Memory Card
* Highlight the file install-cingular-default-603.SIS
* Press Open to start the installation process
* Follow and accept all prompts and requests
* Reformatting is now complete
(1) You may choose to install the file above using Nokia PC Suite. Please see the Nokia 9300 User Guide for general instructions to install software using Nokia PC Suite, and follow those instructions instead of Step 4 above.
(2) CAUTION: The .sis file above is ONLY intended for use with a Nokia 9300 with the appropriate software version. DO NOT install this file to a Nokia 9300 with any other software version. DO NOT install this file to any other model device.
Have a good one!
Mar 26, 2011 | Nokia 9300 Handheld
How code format nokia 9300 comunicator
Inorder to format your set,you can use following tips; FOR HIGHER ORDER PHONES(LIKE N,X,E series..): Dial *#7370# then your phone will ask a securitycode,there you can type your code.then it wil format and restart.
FOR OTHER MULTIMEDIA NOKIA PHONES: Here you can't format yourphone,but you can reset it; For that,go to;SETTINGS-RESTORE FACTORY SETTINGS- AFTER CLICKING IT, your phone will ask a securitycode there you can type your code.then it wil format and restart. "IF YOU THINK MY SOLUTION IS HELP FULL TO YOU,THEN DON'T FORGET TO RATE ME"....THANK'S
Nov 09, 2010 | Nokia 9300 Smartphone
How do you increase volume on a nokia 9300
Here is the link to the user manual for your Nokia 9300. It will tell you how to control the volume.
http://nds1.nokia.com/phones/files/guides/Nokia_9300_UG_en.pdf
Oct 19, 2010 | Nokia 9300 Smartphone
How to format my nokia 9300i
CRTL + Shift + F
Oct 14, 2010 | Nokia 9300i Cellular Phone
I'm using nokia 9300, & i turned it auto restart
Looks like you have a corrupt firmware. You need to reflash it with a new firmware. take your fone to some softwre repair person.
Mar 03, 2010 | Nokia 9300 Smartphone
NOKIA 9300 FORMATING CODE
this code is not working
Feb 28, 2009 | Nokia 9300 Handheld
I need usb driver of nokia 9300 for windows xp.
The USB driver is (was) available from the nokia website.
You haven't said which OS you are using - I've had a quick look on the site but can't find anything now.
If you check in the Nokia connection software, ensure the USB ports are ticked. I know I had terrible problems getting my 9300 recognised over IRDA to my laptop until I found these options.
Jan 24, 2009 | Nokia 9300 Smartphone
No direct restart method is provided by the manufacturer.
The best method for restart is to switch off the telephone(Cover)
then remove the battery and re insert it as quickly as you can to prevent the time to get resetted.
If the phone is not started automatically, press the switch-on key on the cover and wait for it to start.
you can also install applications like appman to be able to restart the phone by the press of a button.
Please rate.
Oct 22, 2008 | Nokia 9300 Smartphone
Mmc card on my nokia 9300
make sure the phone's back panel is in place, 9300i does not detect the mmc if back panel is removed
May 29, 2008 | Nokia 9300 Handheld
Software is corupt
you can move to nokia.com and select the support and specify the model of mobile. you will get all system softwares and utility for nokia 9300 and by connecting cable & using pc suit you can upload any software even O.S to mobile also
thanks ==
Oct 25, 2007 | Nokia 9300 Handheld
Nokia 9300 Handheld Logo
585 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
