Question about Uniden DECT4086 Cordless Phone
Lost instruction My telephone lines does not ring any more in the house it is saying both lines is inuse and on holds. Everything goes to voice mail. What do I do to turn them back so I can hear them ring?
hscarino
  • 131 Answers
SOURCE: i lost my manual on Uniden dect1580 phone. it's
please download your manual here in the list: http://telephones.att.com/telephones_ui/support/dsp_manuals_list.cfm
Posted on May 11, 2010
walesarumi
  • 6993 Answers
SOURCE: my Uniden cordless Z068 goes
Press the answer button on the base (answer off), this will give you up to 15 rings before the answering machine turns on and takes the message.
Good luck.
Posted on Jan 05, 2011
  • 225 Answers
SOURCE: I have (3) Uniden telephones
Sounds like you need to re-register the 2 handsets that are not working properly. Sometimes the handsets must first be de-registered then re-registered to the base unit. Send a comment with the model number of the base unit and handsets if they are not original handsets and I will give specific information for your phone. I have included a link where you can download the manual for your Uniden cordless phone by model number.
http://www.uniden.com/index/manuals_results.cfm?cat=1
Posted on Mar 28, 2011
pgh_pa_guy
  • 2992 Answers
SOURCE: Uniden Dect1560 - For incoming
Your model is a phone only, without an answering machine built in. This means that voicemail is provided by your phone service on your line, and that's where you need to adjust the rings before it picks up. The phone itself has nothing to do with it.
You may have to call your service provider for setup instructions because not all systems are the same, but here's how it usually works. Pick up your phone and call your own number to reach your voicemail. When your message starts, press the * button and the system will ask for your pass code (just like when you call to get your messages). Follow the voice prompts to reach the main menu, then mailbox settings, where you'll be able to change the ring count.
If these steps don't work for you, ask your service provider what you need to do.
Posted on Jul 24, 2011
Testimonial: "Thank you. Great answer."
chris_losh
SOURCE: how to cancel voice message icon
Possibly an internal malfunction. I would try making sure all messages are erased after listening to them, then try the reset. If this doesn't work definately call uniden customer support for further support.
Posted on Mar 09, 2012
GE phone model 29581 does not seem to have instructions for resetting voice mail ...my phone just keeps ringing and won't go into voice mail
Voice Mail is not a function or feature of any telephone set,
nor does the GE 29581 phone have an Answering Machine
System that might be confused with Voice Mail.
VoiceMail is an option offered by some (not all) Telephone
Service Providers. Check with your Telephone Service
Provider to learn how to go about using theirs if it's available.
The original GE 29581 phone User's Manual is available at: http://www.manualslib.com/download/59417/Ge-29581.html
Mar 18, 2016 | GE Lands Phones
How do i turn off the silent mode
To turn the Silent Mode OFF for your handset to ring, press and hold the # key on your handset for about 10 seconds. Your handset will beep and this will indicate that the Silent Mode has been turned OFF.
Jun 21, 2015 | Uniden DECT 6.0 Cordless Telephone...
Can lexmark x4650 be set to recognize fax?
For more details on how to setup your Lexmark X4650 printer for faxing, please refer to the User's Guide found on the Lexmark website.
Additional info:If you have an answering on the same line as your fax:
To make sure the printer picks up incoming faxes, set Auto Answer to On, and then set the printer to pick up after a greater number of rings than the answering machine. For example, if the answering machine picks up calls after four rings, then set the printer to pick up after six rings. This way, the answering machine picks up calls first and your voice calls are received. If the call is a fax, then the printer detects the fax signal on the line and takes over the call.
If you have a voicemail feature associated in the same line as your fax:
Voice mail and fax can share the same telephone line if you subscribe to a distinctive ring service offered by your telephone company. This feature allows you to have multiple telephone numbers on one telephone line. Each telephone number has a designated ring pattern (single ring, double ring, triple ring, or double and triple ring). The different ring patterns let you know which telephone number was dialed, and which device you should use to answer the call.
If you do not have distinctive ring service, then set the printer to receive faxes manually (Auto Answer Off). This setting lets you receive both voice calls and fax calls, but works best if you use voice mail more often. You need to turn off voice mail whenever you are expecting a fax.
Feb 16, 2012 | Lexmark X4650 InkJet Printer
Fax won't answer
If you have an answering machine connected to the same line as your fax:
If you have a voicemail feature associated to the same line as your fax:
I hope this helps.
Should you need further assistance, please contact Lexmark Technical Support Center.
Feb 14, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
Even though my answering machine indicates it is on, noone can leave a message.The response is that the mailbox has not been set up.Can you help? Thank you.I have had this system for quite a while and have...
A "mailbox not set up" message is coming from your telephone line voice mail system, and not from your telephone answeringmachine. What this means is that the voice mail on the phone line is picking up before the answering machine has a chance, and since the mailbox hasn't been set up it can't take any messages. So there are two things you'll need to do.
First, you'll need to set up your voice mail. You may need to contact your telephone service provider for setup instructions since not all systems are the same, but here's how it usually works. From your home phone, call your own number so you reach your voice mail. You should get the message that your mailbox hasn't been set up, and will be prompted for an access code to get to the setup menu. The access code is usually the last four digits of your phone number, and you'll be prompted to change it to something else as part of the setup. Through the setup main menu you can record your greeting and set up other options like the ring count before the voice mail answers. Set it for a number larger than the setting on your telephone answering machine. (I have my answering machine set to 4 rings, and voicemail set to 6.)
Step two is to verify the ring setting on your answering machine. Four rings is a common default setting, but it's adjustable on the phone. Most newer phones have menus that you access from the handset to set change settings, while older models have a switch on the base unit.
Once the mailbox is set up and you have your answering machine set to pick up first, everything will work as you want.
Aug 14, 2011 | Uniden DECT 6.0 Cordless Phone
How do I send a call to internal voice mail?
Use feature 986 (transfer to VM) then enter in the co-workers extension number. That will bypass the extension and send the caller directly to his voicemail.
Jun 29, 2010 | NorStar M7324 Telephone
HOW DO I GET VOICE MAIL OFF MY COMDIAL 120 PHONES
Methinks the welcome message is stored in you telephone set. Try another set, or enter a new welcome messsage. Could it be that the telephone line carries two different lines. Check with you telephone company. Older service may have not been deactivated.
Just a few (possibly farfetched) leads for you to investigate.
Sep 04, 2009 | Comdial Avaya Partner ACS with Voice Mail...
Voice mail recording for my new panasonic digital phone
For voice mail service subscribers
If you subscribe to a flat-rate service
package that includes Caller ID, call
waiting, voice mail, and unlimited
local/regional/long distance calls, please
note the following:
L To use the voice mail service provided
by your service provider/telephone
company rather than the unit's
answering system, turn off the
answering system (page 30).
L To use this unit's answering system
rather than the voice mail service
provided by your service provider/
telephone company, please contact
company to deactivate your voice mail
service.
If your service provider/telephone
company cannot do this:
- Set this unit's "Ring count"
setting so that this unit's answering
system answers calls before the
voice mail service of your service
provider/telephone company does.
It is necessary to check the number
of rings required to activate the
voice mail service provided by your
company before changing this
setting.
- Change the number of rings of the
voice mail service so that the
answering system can answer the
call first. To do so, contact your
company.
Jan 13, 2018 | Panasonic KX-TG4322B Twin Cordless Phone
Misplaced manuel, how do you set voice mail to come on after 3 rings
Go to http://www.rca4business.com/products/pc/viewPrd.asp?idcategory=11&idproduct=11 and click on the Download Instruction Book link.
Jul 19, 2007 | RCA 25414RE3 Corded Phone
Uniden DECT4086  Cordless Phone Logo
16 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
