Question about Canon CanoScan Office Equipment & Supplies
Canon CanoScan 3200 - code 2,178,0
I am getting the code 2,178,0 when trying to start scanning, with the scanner lamp illuminated but it making very little movement (almost a quick ****) within the flatbed when 'start' pressed - a dialogue box then appears: Cannot scan for these reasons: -The original may not be set correctly -The Film Adaptor Unit Protective Sheet may be put in place -The lamp may not be warmed up. (It needs a few minutes for adjusting lamp at lower temperature.) Scanner driver will be closed. Code : 2,178,0 Please help, many thanks!
5 Suggested Answers
SOURCE: Canon PIXMA MP160 problem
i need help getting this going
the error button keeps blinking htis is an new scanner printer
the alram button is blinking on and off
Posted on May 25, 2008
SOURCE: Scanner Canon 3200F using ScanGear
do you scan on automatic mode?
Posted on Feb 24, 2009
cg2010
  • 108 Answers
SOURCE: Canoscan Toolbox returns a TWAIN error with
maybe the software that you download is a 32 bit O.S only that's way it cos you and error. because your O.S
is not compatible to the software that you use. download a 64 bit driver twain
Posted on Mar 05, 2010
SOURCE: My canoscan 8400F suddenly stopped
You have to remove the white protective sheet from the the lid. Once you remove it you will be able to scan film. Also make sure the lock button is not in the lock position.
Open the Canoscan Toolbox.
Click the Save option.
Put a check in the box that states "Display the Scanner Driver".
Click Scan.
Click the Advanced Mode tab.
Make sure Select Source is set to "Platen".
Click the Preview button at the top left
Another thing is this can be caused by a faulty FAU cable. One or more of the eight wires within this cable has fractured
Posted on Oct 18, 2010
CanoScan 8400F Cannot scan for these reasons: -The
You have a bad scanner lamp, but they are not available as a spare part.
Nov 14, 2009 | Canon CanoScan 8400F Flatbed Scanner
2,178,0 When scanning,
Try this
1.Open the CanoScan Toolbox.
2.Click the Save option.
3.Put a check in the box that states "Display the Scanner Driver".
4.Click Scan.
5.Click the Advanced Mode tab.
6.Make sure Select Source is set to "Platen".
7.Click the Preview button at the top left.
If the error still occurs, then most likely it will be a service issue.
One thing to check...see if the inside lamp illuminates when you turn the scanner on using the power button at the back left side of the scanner. If you get no light, then as mentioned before, then it will most likely be a service error.
I’m happy to assist further over the phone at https://www.6ya.com/expert/barbara_87cfe34e34050f26
Nov 06, 2009 | Canon CanoScan 8400F Flatbed Scanner
Canon Scanner 5000F fails when adjusting lamp before scan.
Have the same problem. Suspect a lamp problem but cannot find any info/help to check lamp or to replace it
May 27, 2009 | Canon CanoScan 5000F Flatbed Scanner
Problem with an CanoScan 8400F, just started 2 days ago. I have tried all the usual things pwr off, usb, uninstalled driver, downloaded latest, get the same error each time. Code: 2,178,0. I even hooked...
Try this:
Click Scan.
May 18, 2008 | Canon Office Equipment & Supplies
CanoScan 8400F
Try this:
Click Scan.
May 13, 2008 | Canon CanoScan 8400F Flatbed Scanner
Canoscan d660U filmscan
If the light is not illuminating when positioning the lamp and the scan button turns grey (inoperative) the light source has probably failed in the cover. It is integral with the cover. Costs about $160 AUD to replace.
May 02, 2008 | Canon CanoScan D660U Flatbed Scanner
Error message 2-178-0. What does this mean.Changed drivers but no change in message?
Try this:
Click Scan.
Jan 31, 2008 | Canon CanoScan 8400F Flatbed Scanner
144 people viewed this question
old marine
old marine
