Question about Magic Chef Dryers
What size is my Magic Chef dryer (cubic ft.) model# CYE4000AYW?
What is size (cubic ft.) of my Magic Chef electric dryer CYE4000AYW?
SOURCE: MAGIC CHEF ELECTRIC DRYER DOESN'T
you at all/r time clock or the start button is bad. do you here anything?
Posted on Jan 15, 2009
smartr10U
  • 1305 Answers
SOURCE: My Magic Chef Dryer stopped working mid cycle last
Check the circuit breakers for the dryer first. Remember when you reset the breaker, to turn it all the way to the OFF position firmly and then back on.
Posted on Jun 08, 2009
  • 7 Answers
SOURCE: magic chef dryer quit working
There is a thermal fuse inside the dryer usually located behind the back cover on the upper part of the combustion chamber. When this fuse "blows" it turns off power to the whole dryer. This keeps your house from burning to the grown, and you from dying. The fuse "blows" for a reason, most likely to is lint build-up in the dryer and/or dryer vent system. The good new it only cost a few dollars to get a new one. The bad news is you need to find out why it "blew", the dryer got to hot for a reason.
Posted on Mar 04, 2010
  • 3074 Answers
SOURCE: my magic chef electric clothes
this should help:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Posted on Oct 19, 2010
Jahn27
  • 1554 Answers
SOURCE: How do you install a thermal fuse kit on a Magic
The thermal fuse kit is accessible from the top of the dryer. Disconnect power and using a putty knife, release the two spring clips holding the top cover to the cabinet. Insert the putty knife in the seam between the top cover and the cabinet at about 4 inches from the sides. Lift the top cover when the first spring clip is released while releasing the second clip then lift the top cover to the rear of the dryer.
The high-limit thermostat is located on top of the heater housing at the rear of the dyer. Remove the screw that secures the high-limit thermostat bracket and replace the thermostat.
The thermal fuse is located on the right hand side of the heater housing and is mounted on a bracket. There's a 1/4" hex-head screw that holds both the heating element and thermal fuse brackets. Remove the screw and the thermal fuse bracket can be lifted off.
The thermal fuse bracket has two locating tabs, one at the bottom and the other is half-way up. Lift the bracket to clear the tabs then remove it and replace the thermal fuse. Reinstall the thermal fuse and high-limit thermostat brackets in reverse order of the removal steps. Press down on the top cover against the cabinet to reengage the spring clips.
Posted on Apr 06, 2011
Cubic feet of magic chef refrigerator model number CTB1521ARW
14.96 CUBIC FEET. Most manufactures would call this a 15 CUBIC FOOT.
Generally anything over a .5 like 10.5 10.7 or 12.6 would be marketed as the next size up.
Oct 12, 2015 | Magic Chef Refrigerators
Magic Chef RB15FA0AA Refrigerator I have this refrigerator and it still works fine. I would like to know it's total cu ft capacity. Also what the refrigerator and freezer each cu ft capacity is.
After some work online...I found this advertisement buried among a bunch of other ads:
Magic Chef RB15-1A: Top-freezer style with 14.6 cubic ft. capacity and optional ice maker -- $439.
So, as I suspected the "15" in the model number is the cubic feet (total I would say). The 14.5 is probably actual, with the unit "rated" as a 15 CF.
Naturally, to find the cu. ft of the freezer, measure in inches then multiply the width X height X depth and divide that resulting rather large number by 1728 to get your cubic feet of the freezer.
You could also do the same with the refrigerated section, and add the results together and they should be near 14.5 total.
Aug 03, 2015 | Magic Chef Refrigerators
Model# FRT17B3JW6. need to know cubic ft. for selling
Normally the first two numbers in the model number are the cubic feet. You have posted 2 model numbers, on appears to be 21 cubic feet and the other is 17 cubic feet.
Jan 21, 2013 | Magic Chef CTF2125 Top Freezer...
I have a Magic Chef refrigerator Model # GT17Y7A that I want to know what cubic feet it is? Can you help me?
I believe if you look under magic chef with the model number and serial number on google it will tell you, my sq ft is not written in the fridge.
Feb 23, 2011 | Magic Chef Refrigerators
Dryer stopped working - cye4000AYW
The answer is likely yes. Look on the back of the dryer, for an open hole that seems to serve no purpose. using a flashlight, peer inside this hole, and any others like it, and look for some sort of button.
Also make sure power is disconnected before doing any of this.
Dec 16, 2009 | Magic Chef Dryers
How many cubic feet (what size) is my fridge?
Need the cubic feet on our 16 year old Amana BX22A2W.
Jun 23, 2008 | Magic Chef CTF2125 Top Freezer...
plumber, pop the top on the dryer by pushing on the two clips just under the top on each side. In the back you will see the heater. You want to check the high limit thermostat (this one sits on the top side of the heater) and the thermal fuse (sits on the side about 4 inches down. Unplug the dryer and check them with a meter. If either shows open (no continuity) replace them. Make sure your venting is not clogged up and the heater is not grounded or fractured. Part number for the high limit is 53-0771 and for the thermal fuse is LA-1053. Check these first...Catriver...post back. Unable to find your exact model, but I do have cye4000ayw. parts should be the same.
Oct 12, 2006 | Magic Chef CYE4000AWW Electric Dryer
Dryers Logo
66 people viewed this question
Top Magic Chef Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Roderick Scott
Roderick Scott
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
