Question about Intermec CN70e Handheld Mobile Computer CN70EQ2KCU4W2100 Barcode Scanner
Intermec CN70e does not boot
Device screen all black, battery fully charged
Reset intermec cn70
There are 3 ways to reset the device:
Warm Boot - When an application becomes unresponsive.
Press the Yellow Power button (also referred to as the IO Button) and select the reboot option.
Cold Boot - When device itself becomes unresponsive, will loose any cached data.
Press the Yellow Power Button (also referred to as the IO Button) to suspend the device. Remove the battery pack and press the reset button in the battery compartment (Round rubber button). Replace the battery pack and press the yellow power button or IO button. The blue Intermec startup screen appears.
Clean Boot - When device itself becomes unresponsive and cold boot fails, device will be restored to factory state, all data and installed applications will be lost except for data stored in Flash Storage.
- Firmware 1.50.19.0013 and prior -
Remove the battery pack and press the reset button in the battery compartment. Replace the battery pack and immediately press the yellow power button (IO button) and volume down button (the lower
button on the right side) together until a message box appears on the screen stating the clean boot. Press the volume up button (the upper button on the right side) to confirm the clean boot.
- Firmware 1.62.27.6 and later -
Remove the battery pack and press the reset button in the battery compartment. Replace the battery pack and immediately press the yellow power button (IO button) for 8 seconds. Message box will appear stating to release the power button. Press button number 1 then button number 2, confirm again by pressing button number 1 then number 2 again. Message box will state that the device is clean booting.
Jun 20, 2014 | Intermec CN70 Handheld Mobile Computer...
Screen goes black when unplugged
update bios check battery at conection try using unit without the battery and then with battery some batterys are just not good for long I would change battery but before you do that check and update the acpi, battery driver in device manager
Mar 01, 2013 | Everex StepNote SA2053T Notebook
CK71 stuck on Launching OS
Hi
Please try to Install OS through Intermec Smart System from intermec.com - downloads
and try to install OS via WIFI connection
Note : Make sure about WIFI Connection & Battery Charging power of device
Regards
Aug 22, 2011 | Intermec CK71 Handheld Mobile Computer...
My Blackberry 8310 just "died"
The device is performing on low battery power and requiries full recharge possibly a couple hours. How to perform a device recharge
1. power off completely
2. connect to power source with cables provided, expecting to the last the duration of the full charge
3. a full recharge once the process is complete would display a message on the phone.
4. until then, do not unplug
Dec 03, 2010 | RIM BlackBerry Curve 8310 Smartphone
CK30 is cold booting when I remove the main battery. The supercap battery status is high and I am not depressing the cold boot button in the battery compartment.
Hello jcapsto. It could be that the backup or 'flash' battery isn't totally charged for one reason or another. This little internal battery keeps a minute current going to the units' flash memory that holds settings and other data and allows warm boots. I would recommend putting your CK30 in it's cradle with the main battery in overnight. Then trying removing the battery and it should spring right back to life. If not, then I would pin the issue on your backup battery and would implore you to contact Intermec or the vendor you purchased it from about replacement/repair. I hope this helps to at least isolate the problem. Good luck!
Jan 08, 2010 | Intermec CK30
Unit will not boot. Screen reads
"Check serial Input" is just part of the cycle on boot up. It checks for a key press on boot up so that it can access a hidden menu. A cradle, serial null modem cable and hyper-terminal is required to bring up this menu
You can try and re-install the operating system.
Download the latest image from Intermec (you will need to register) and then load the image onto an SD card.
Remove the front cover just above the scan engine; 2 slot head screws and insert the SD card. Cold boot the device. Take off battery and hit the reset button a few times. Re-install battery.
Image will begin to reload.
Detailed instructions are available with the download.
NOTE: The latest image downloads from Intermec not longer have the Telnet application pre-installed. If you require the telnet client then select a previous version, but then also not that there are usually 2 versions EX25 and non-EX25 scan engine type.
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL 01202 620955
http://www.biastechnology.com/
Oct 29, 2009 | Intermec CK31 Portable Terminal
Gps 260W will not power on, screen is black
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your GPS unit powers down before it can fully boot up, the battery will need to be charged. Please charge the unit with the vehicle power cable or on a computer for at least three hours. After charging the unit, it should power on and function normally. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
The nuvi 200 series, 300 series, 600 series, 700 series, 1000 series and the StreetPilot C300 and C500 series do not have user replaceable batteries. These units must be sent in to a Garmin approved repair facilities if a battery issue arises. Garmin and Raytech are the only Garmin approved repair facilities. Raytech is a repair facility for Canadian customers. To repair your device please contact the specific repair facility for your region. If your device is not still under the 1 year warranty, there will be a cost associated with the repair of your device.
Sep 09, 2009 | Garmin nuvi 260W GPS Receiver
How to do a hard reset on CN3 device
To cold boot your CN3
1 Press the Power button to suspend the CN3.
2 Remove the battery pack from the CN3.
3 Press the Reset button on the back of the CN3.
http://www.isg-service.com/Portals/0/ISGPdf/Intermec/IntermecCN3.pdf
Jan 16, 2009 | Intermec CN3
Acer Aspire 8 inch Laptop. Was wroking fine until we re-booted it. Screen is black and only hear fan noise. No hard drive light appears. Battery is fully charged.
Hi , Boot the PC and keep pressing F . a screen pops up seletc the last known option and enter and then jst boot the system.
Jan 11, 2009 | Acer Aspire 5315 Notebook
Green light stuck on.
Left the ck30 powered off and removed the battery. Replaced the battery with a fully charged one. After a couple hours rebooted the ck30 and it booted normally. My ck30 was tied to the AS400 system. I think this may have been a factor with this issue.
Sep 12, 2008 | Intermec CK30
Intermec CN70e Handheld Mobile Computer CN70EQ2KCU4W2100 Barcode Scanner Logo
52 people viewed this question
Top Intermec Computers & Internet Experts
Computer Repairing
Computer Repairing
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you an Intermec Computer and Internet Expert? Answer questions, earn points and help others
