Question about Acer Aspire 5100 Notebook
Acer Aspire 5100-3583
A cup of tea was spilt on it. Immediately I turned it upside doan and removed the battery and let it dry out. Now, with the power cord connected, it takes overnight for it to turn on and after 15 minutes of normal work it shuts off as if it has no power. I have tried a different power cord and there was no difference. It seems it has difficulty collecting charge and also the power cord does not seem to power the laptop directly. What do I need to do or change? What will it cost?
    Scholar:
  • 42 Answers
Hello Citiboy,
Well it sounds like the power circut is gone. That regulates things like charging and power distribution etc, which would explain your problems. If that is the case then its a new motherboard as it cannot be fixed.
However before you do that try this..........
You would be very amazed at how a single drop of liquid can hang about a board (on a chips leg for example) for weeks and it MAY be that even if there is no liquid on the board that the residue from the tea could be causing the problem...so ..... go get some isopropranol and also some non-deionized water.
Simply remove the motherboard and wash it with the water. The fill a small bowl with the Isopropranol and place the board in it and swill the liquid about it for 10 mins.
Leave it over an hour and then take out of the isopropranol and dab it dry with an absorbaint cloth (DONT RUB). then place the board in a warm area for 2 days to air dry.
I think you will find that when you rebuild the computer and switch on, that its all working fine.....Fingers crossed.
Good Luck.
Posted on Oct 22, 2008
Spilt water on keyboard acer aspire 5542, while it was turned on, some keys have stopped Working. can this be fixed or does it need replaced?
Hello, I think it can work somehow. Loose the key board and look for a dried place to keep it, so that when it dries, you can take a look At the key that is not working
Mar 25, 2011 | Acer Aspire 5542 Notebook
Matthew.,
Before you declare the keyboard dead and unusable please do the following. Use the hairdryer without heat to blow cold air into the keyboard. This will remove all traces of water that may be shorting the keys. Do it for quite sometime as you have to ensure that there is no water left under the keys.
All the best
Mar 25, 2011 | Computers & Internet
I have a friends laptop, which he spilt a cup of tea over, he wants it repaired, when i got it it would not come on at all, but after a few hours of playing about with it, i got it to boot up into...
First thing is to not try powering the laptop on after the liquid fell on it. Next, you should remove the battery off the laptop immediately. When this is done, you should fully disassemble the laptop & thoroughly inspect its inside. Look for any traces of liquid on the circuit boards & on other components. On circuit boards, liquid damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
Check all internal connectors & make sure that no liquid seeped into them. Dry them if needed.
Check the hard drive's connector to the motherboard for any liquid damage & clean it.
When you are done, re-assemble back the laptop.
If the liquid fell on the keyboard & you found out that the keyboard is no longer working, then you will have to replace the keyboard.
Aug 26, 2010 | HP Pavilion dv9000z Notebook
I spilt a cup of tea on my laptop and i left it for a couple of weeks and now it will charge but wont turn on but i have had the motherboard out and cleaned it with cotton buds
You should removed the battery, dismantle the laptop now was the parts with distill water using brush and again wash it then keep it in standing position under running fan for a day. Make sure taht all parts are dry now assemble and put it on it should work.vikram00rathore@yahoo.co.in
Jul 11, 2009 | Computers & Internet
Tea spilt on Laptop
If you can put up with the sticky keys and they still work then it is OK.
Otherwise you need to replace the keyboard.
Mar 01, 2009 | Acer Aspire 5735 Notebook
Laptop keyboard needs cleaning
I had a client with that problem--we removed the keyboard and tried to clean it. Turns out that our cleaning job was less than perfect because the laptop keyboard is mostly sealed. There was liquid that seeped down onto the motherboard as well--that we could clean up. The long and short of is--you will probably need to replace the keyboard. Of course, with nothing to lose, you could wash the keyboard and let it dry out thoroughly, plug it in, and see if it works. The key here would be the thorough drying. If you decide to try this chancy procedure, don't dry it with high heat. A hair dryer set on low might be the answer.
Feb 04, 2009 | Acer Aspire 3634WLMi Notebook
I spilled tea on my packard bell easynote
Two things to check.
Open the laptop up and re-connect the keyboard connection. It has a locking mechanism so be sure to unlock that first. Also when you're doing that you can see if there's any water (tea) still in there to dry off.
If that doesn't work, then plug in an external keyboard mate, cause the only other way to fix this is to replace the keyboard, the parts to open up the laptop keyboard itself are intricate and it's much too compicated, plus I've never done that (Seeing as that it's all glued together).
Hope this helps, be sure to rate!
Jan 03, 2009 | Toshiba Satellite M45-S165 Notebook
Keyboard not working
What a drag! Did the tea have any sugar in it? Anything except water or plain tea won't wash off too easily. Dirt, dust and moisture don't clean off easliy. The question is, did any moisture get onto the motherboard? I've had to wash off a few contaminiated circuit boards and it took a few good soakings in warm water and a tooth brush over all the contacts to really remove the residue. From Coke to salt water I've gotten stuff to work but it has to be very clean. I suggest getting a new keyboard if the laptop is worth it and seeing if that works. It is probably salvageable but all the contacts need to be inspected.
Oct 24, 2008 | HP Compaq Presario v3000z Notebook
Tea spilt ok Thinkpad Keyboard
I'm sorry, but there are no alternatives, and you may have bigger issues than just the keyboard. If the tea seeped past the keyboard, and onto the motherboard, which is directly bellow the keyboard, then by trying to start it you may have fried the motherboard. You would be surprised how long it takes for a laptop to dry out, 6 hours is not near long enough. You will also want to clean it, the sugar in the tea can cause corrosion of the circuitry on the motherboard. I'm going to recommend that you take it in for a professional diagnostic and cleaning. This way you will know the exact extent of the damage.
Sep 03, 2008 | IBM ThinkPad T30 2366 Notebook
My keyboard
If you've spilt tea down your laptop you could have shorted something out.
You could try a new keyboard, or take out your old one and see if you can clean it up a bit, and try and clean the tea from inside.
Mar 26, 2008 | Acer TravelMate 2300 Notebook
Acer Aspire 5100 Notebook Logo
83 people viewed this question
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
