Question about Sanyo 09KS51 Mini Split Air Conditioner
Tempstart mini-split unit
My tempstar mini-split unit that is new and I have only used twice in two years does not work with the remote control. If I turn the breaker off and on it might work one time such as turning on but I can't get it to turn off unless I turn the breaker off. I tried a twin remote from another identical unit and it was successful in turning on but it would not turn off with that remote so I had to turn off and on the breaker and then I was able to turn it off with that remote. What is the problem with the unit, the remotes work fine.
SOURCE: REMOTE CONTROL SYMBOLS?
To be honest.....I didn't think that I'd actually have to pay just to see a photo of the couple of buttons on a remote saying what their function is. A team of experts isn't needed for this. We purchased and moved into the house recently and the previous owners didn't leave us the manual so we don't know what button does what.......
If someone would be so kind as to tell us, that would be great. Otherwise....thanks anyway.
Sincerely,
R.L.B.
Eastham, Ma.
Posted on Jun 14, 2008
  • 659 Answers
SOURCE: I can't change the fan mode to cool mode.
Go to the manufacturer website and try and find their download page for the manuals or literature. If they don't have a download, you will have to contact them either by phone or email. They should be able to mail or fax you one.
Posted on Apr 07, 2009
SOURCE: Remote does not turn on or off the Split System Air Conditioner
take your cellphone and turn on the camera,then put the remote in front of the cell and push any button.if you see the light of the remote to the cell then the remote is ok and the problem is to the eye of the plate.its a small plate in front of the split
Posted on May 29, 2009
  • 89 Answers
SOURCE: I have a Heat Controller heat pump mini split.I
Don't ;ook a gift horse in the mouth.
Posted on Oct 12, 2009
  • 821 Answers
SOURCE: Problem with Sanyo split AC/Heating
hello,i suspect its your air conditioner filter that has clog in it,you have to bring it out to get it cleaned and ensure there are no more dust on it.replace A/C filters normally every 30 days. If recommended longer by the package on replacement filters, keep an occaisional eye to determine when the filter needs replacing.if the problem persist,i would advice you to do a gas refill,it could also happen as a short of gas. wish you good luck,
take care.
Posted on Jul 02, 2011
I want to know that how mini split system automatic work? there is any thermostate or any other device?
Generally, they are operated by a remote control (similar to a television), although some units do have a wired wall control option as well. The indoor and outdoor unit has sensors that measure temperature (to control the operation of the mini-split) and (once the remote is set) the sensors control the system until it reaches the set point set on the remote.
Jul 25, 2016 | LG LS-K1830CL Cool Mini Split Air...
What are color of wires that goes to the temperature line switch that controls the defrost cycle?
PDF]4HP13/14 SPLIT SYSTEM HEAT PUMP - Armstrong Air
www.armstrongair.com/_/.../Armstrong_4HP13L_Install_506318-01.pdf
4HP13/14 SPLIT SYSTEM HEAT PUMP .... indoor unit, outdoor unit contains system refrigerant charge for operation ... may be installed with up to 50 feet of line set (no more than ..... The defrost control incorporates 2 pressure switch .... Note: Sensor resistance decreases as sensed temperature increases. Pins/Wire. Color.Missing: tempstar
[PDF]RESIDENTIAL SPLIT HEAT PUMP SYSTEMS
icpindexing.toddsit.com/documents/086477/42808100101.pdf
This Manual Supports Split Heat Pump Units of The Above Series .... two groups is based on a difference in Defrost controls and/or the .... completes a circuit between µRµ ? µOµ in the the thermostat sub-base. 2. .... before connecting line voltage. ...Wire "S1" is the first stage of electric heat through the outdoor thermostat.
[PDF]Trane Installer's Guide Air Conditioner/Heat Pump 4TTZ0 ...
Jan 18, 2016 | Heating & Cooling
Why doesn't remote control communicate with Fischer heat pump mini split system
It sounds like the batteries leaked and oxidized the terminals. If you cannot get them clean enough then I would suggest getting a new reomote from the manafacturer.
Aug 24, 2014 | YMGI R410A Ductless Mini Split 16 SEER DC...
GE split air unit.remote is intermittent.I have 2 remotes same problem. Should I replace the display board or the pc board it plugs into?Which one controls the signal?
Replace new batteries and check. Switch off ac,remove any dc wire from indoor unit and then re-fix it.Now try. If still problem, repair/replace PCB
Jun 01, 2011 | GE Quiet-Aire Ductless Mini Split System...
Can I purchase a new remote control?
If your remote is problem, don't operate a/c with manual switch in indoor unit or without control. Plz go with new remote. Thanks.
Jan 28, 2011 | LG LS-L1210CL Mini Split Air Conditioner
Remote control for Armstrong minisplit
You may be able to get any make of remote universal remote control and program it to operate your systems.
Mar 01, 2010 | RCA Universal Remote Control
LG Spilt A/C
medev,
there is a lot of reason why your LG split unit would not work by remote control.
first likely trouble is the remote itself. it could have drop from a height and broke the remote, or corrosion has set inside the remote if you left an old battery for a long time and it could have broken it.
secondly which is not more likely to happen is the remote receiver in your unit got broke that is why it can not communicate with your remote controller. it could happen if someone has serviced your evaporator and could have disconnected wires to the receiver , or wires were just left not connected.
you can test the remote if you have an identical unit which is working with a working remote. use the working remote to your unit then you can decide.
i hope i was able to help.
Jun 24, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Stand By Mode
1. use remote properly
2.first off the unit then again the unit
3 if same problem change remote by new one
Mar 18, 2008 | Sanyo 24KS62R Cool Mini Split Air...
Sanyo 09KS51 Mini Split Air Conditioner Logo
76 people viewed this question
Top Sanyo Heating & Cooling Experts
Dennis Boxerman
Tim Whalen
Chuck
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
