Question about Dell 2350dn Laser Printer
Dell 2350dn printer paper jams on pick up from paper tray
SOURCE: dell 1600N printer paper jam
More than likely you need a new pick up roller. It is located at the top of the tray area in the printer. You will see a black rubber roller with white nylon clips on both sides. You can confirm if it is the problem by removing and washing it with soap and water, then clipping it back in and running a few copies.
Posted on Jan 14, 2009
  • 13433 Answers
SOURCE: paper jam ,no paper jam found Dell 1815dn
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 12, 2009
remt23c
  • 78 Answers
SOURCE: Dell 3010cn Not Picking from MPF
When you go to print are you selecting the MPF as the location to print? I have the 3110cn and you must manual select that you want it to print to the MPF.
Posted on Feb 15, 2008
Peoples book
  • 9 Answers
SOURCE: Paper jammed (Dell lase Printer 1720dn
Open the back cover and look for paper wrapped around a roller back there. That is the most common cause of the issues with this machine. The other thing you can try is to push down on the little flaps where the paper comes out of the printer. These get stuck and need cleaning/replacement all the time in the later life of these models (1720's).
Posted on Aug 22, 2009
SOURCE: I have 2 Dell model 1700n laser printers and they
Take off the two rubber rollers, turn them inside out and replace them, Voila!
Posted on Aug 23, 2009
Picking up multiple sheets at once
The most common reasons for jams and misfeeds I run into are over-loaded paper input trays, dampness in the paper, and pages that have not been fanned prior to loading.
Most paper trays have an indicator showing the maximum amount of paper that can be loaded.
Make sure you have selected the correct menu settings for the weight and texture of the paper.
Before you load the paper flex, fan, and straighten the paper.
Don't store you paper on the floor, try to keep shelf and avoid setting heavy objects on top of stored paper.
If the problem is not solved by these steps, you could have dirty or misaligned input rollers. Fixing this may require service at a repair center.
Oct 29, 2013 | Dell 2350dn Laser Printer
Keeps telling there is a paper jam
This particular 'paper jam' error on the Dell 3110/3115/3130 can often be caused by the paper not being picked up from the paper tray. The printer 'expects' to 'see' the paper pass various sensors during it's path through the printer. Each one has a 'time window'. If the paper is not seen to pass sensors at the correct timings, a paper jam is assumed.
Now - to cure the problem.
Just cleaning the (3 identical) pickup/separation/feed rollers in the paper tray area could be enough (they get a build-up of paper dust - can affect their effectiveness).
One of these rollers wears much quicker than the rest, and gets a pronounced flatspot. Replacement rollers are available via 'that' well known internet auction site.
Feb 05, 2013 | Dell Printers:Dell MFP Color Laser 3115cn
Getting a constant "Paper Jam 071-100" error when printing from Tray 1 (no jam found).
You need to replace the paper pick up, feed rollers and separation sub-assebly.
Nov 27, 2012 | Dell 3115CN
Dell Laserjet 1710 - won't take the paper from the tray
clean the paper pick up roller and check any paper pieces is there
Oct 05, 2009 | Dell 1710 Laser Printer
Paper jam ,no paper jam found Dell 1815dn
give this a try
alternative :
Jun 01, 2009 | Dell 1815dn All-In-One Laser Printer
Paper jams when printing
just add some more paper to the tray..and arrange it properly..
i think the paper pick mechanism failed to pick the paper.or there is a long time delay before the paper reach the printing area..
thanks for using FIXYA!
pls let me know if it solve the problem..
May 21, 2009 | Dell 924 All-in-One InkJet Printer
Paper transport does not work; terrible grinding noise
I took mine apart from the back and put it back together and it worked. It is probably due to moving it and the bottom paper tray alignment gets out of whack. I inspected all of the gear train and didn't find any worn or missing teeth. I suspect a paper jam started it and the user turned the printer around to open the back door. Since the handles are on the printer the tray doesn't move with it which allows it to separate and possibly jam a pickup drive gear.
Nov 08, 2007 | Dell 3000cn Color Laser Printer
Dell 2350dn Laser Printer Logo
1,970 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
